Question about Samsung HCL4715W 47" Rear Projection Television
Will not Turn-on
I too have a power up problem with my Samsung HCL4715W but slightly different from others. Mine does power up shortly with the Timer LED turning ON then blinks 3 full blinks and at the 4th blink it shuts down. During that period the high voltage does come on (I can hear it) and the audio for a split second as well as the inital relay. I'm wondering if this TV worth saving. I will open the back up shortly but thought to see what area I can pin point the problem. Any help is appreciated. Thanks.
  • Richajem Nov 22, 2007
    Thanks You for your post with the area of the problem. I actually took the board and reflowed the solder around the power drawing components (Transistors, Resistors, etc) and the problem is gone. Perhaps just by removing connectors and remating also solved it. All in all I'm back in business. Thank You.
That makes good since my tv is doing the same thing the guy I got it from put over 300 bucks into it and no dice I unpluged all the boards from it got the unit to power up then being dump i pluged them all back in with the unit powered up I watched a movie on it the picture got blured then the unit powered down
Posted on Nov 14, 2008
    Sergeant:
    Champion:
  • 375 Answers
The deflection/convergence board requires replacing.the set is checking itself and found a problem and went into shut down.
Posted on Sep 05, 2007
I Have a Sumssung HCL4715W Tv timer flashes 40r 5 times and Tv turns off
A constantly blinking light means shutdown.
The most common issue in this model is convergence-----if the convergence circuit has railed (this means shorted parts) it can cause the set to do what you describe.
Before I suggest a course of action----what is your skill level with electronic repairs? Can you solder and or do a visual inspection?
SD TECH
Oct 28, 2011 | Samsung HCL4715W 47" Rear Projection...
My Samsung HCL4715W will not turn on.....can it be reset or does it need to be replaced.
Your problem is do to shorted Convergence Ic's which will not let the set power up until problem is rectified. You have a very reliable set there. The Ic's will cost about $25.00 for the pair and a tech can install them reasonably cheap. I do recommend repairing it.
Nov 26, 2010 | Samsung HCL4715W 47" Rear Projection...
Turns on and turns off
BE SURE THAT THE TIMER HAS NOT BEEN SET FOR AUTO ON/AUTO OFF... THIS IS COMMON AND MANY PEOPLE DO ARE NOT AWARE THAT THEY HAVE TURNED THIS FEATURE ON OR THEIR KIDS HAVE DONE IT.
Oct 08, 2009 | Samsung HCL4715W 47" Rear Projection...
Power light flashing
unplug the convergence yokes then try powering up the set. If it powers up the ICs are bad.
Jan 29, 2009 | Samsung HCL4715W 47" Rear Projection...
Anyone need any parts for the HCL4715W? Parting mine out.
More then likely set has 2 burt resistors on convergence board 2.7ohms
Jan 27, 2009 | Samsung HCL4715W 47" Rear Projection...
Tv will not turn on
If your convergence ICs are bad set will not come on 1 of the ICs controls Off/on STKs big black ics replace both STK392-020s use 040s For Parts call 1-800-223-3205. www.electronix.com
Jan 03, 2009 | Samsung HCL4715W 47" Rear Projection...
HCL4715W Red timer light on nothing else.
Thats a common problem for that chassis You will need the P54A sud deflection board. You can get a new one at the following link with free shipping. Here is the link.
http://servicemanuals.vstore.ca/
Jul 09, 2008 | Samsung HCL4715W 47" Rear Projection...
TV won't power on
Disconnect the convergence board and see if the set comes on. If it does, and it probably will, replace the convergence board or the convergence amp IC's. Good Luck
Jul 26, 2007 | Samsung HCL4715W 47" Rear Projection...
Samsung HCL4715W 47" Rear Projection Television Logo
89 people viewed this question
Jerry Greenberg
Jerry Greenberg
