Question about Creative Labs ZEN V Plus MP3 Player
Frozen or dead
I had my zen plugged into the computer, and when i unplugged it, the "docked" screen stayed up. i tryed plugging it back in, and the computer didnt register it. then the screen of the zen went blank and it wont start or charge on anything. i've tryed plugging it in to several different computers, and tryed it with different cables. i thought it might be bent in the usb port on the player, but the cords fit fine.
Had the same problem. there is a reset hole on the side of the zen, it fix'd mine
Posted on Feb 12, 2008
Just push the reset button. it worked for me
Posted on Nov 17, 2007
Complain with te company and make them give you a refund!!!
Posted on Sep 06, 2007
Thanks for the suggestion! I had the same problem and the reset button on the side (same side as power button) turned it off, I pushed the button and it came right back on, said it was rebuilding the library, and returned to normal.
Posted on Jun 22, 2008
SOURCE:
My Creative Zen seems to have frozen up on me.
Use a paperclip to push the reset button throught a small hole on the bottom of the Zen. If the battery is dead, you may need to plug it in for a minute and then push the reset button while it's charging.
Jun 02, 2009 | Creative Labs Zen Digital Media Player
Creative zen v problems-frozen
If a reset does not work using the reset hole, then try this: First, back up all of your music and do this: Turn off the player and disconnect it from the computer. Then press and hold the play/puse button and turn it on simultaneously. The player should be in recovery mode. Scroll down and select format (all) and let it format. Then reload all of music back onto your player and it should work like new. Hope this helps!
Aug 25, 2008 | Creative Labs ZEN V Plus MP3 Player
My Creative Zen Frozen in Docked Screen
The following worked for me. Go to the Creative Zen Support warranty info page of their site:
http://www.creative.com/products/mp3/MP3PlayerRecoveryTool/welcome.asp?
I ran the recovery tool with my zen connected to the computer and it changed from being in a docked state to updating firmware, after it had done this it worked fine again.
Aug 02, 2008 | Creative Labs Zen Digital Media Player
Says it is docked and when I unplug it nothing changes - it seems stuck
Push a pin into the tiny reset hole on the bottom of the player.
Aug 01, 2008 | Creative Labs ZEN SLEEK MP3 Player
there is a restart button on the bottom but it is a very small hole so maybe use a toothpick to push the button
Apr 12, 2008 | Creative Labs ZEN Vision:M Digital Media...
Black Screen, Not turning on but charges?
If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Q. How to reset Zen v +
http://www.youtube.com/watch?v=22T_gkkZjmM&feature=related
Feb 06, 2008 | Creative Labs ZEN V Plus MP3 Player
MY Creative Zen V Plus is frozen and wont reset
or try this:
Jan 18, 2008 | Creative Labs ZEN V Plus MP3 Player
My mp3 seems to be frozen
if you have the instruction manual get it and see if theres a way you can reset it. like on an ipod you hold the center button and it reboots much like when you hold the power button on your computer. hope this helped
Jan 16, 2008 | Creative Labs Zen V MP3 Player
I Recently bought a Zen, and it works great. The only problem I found was that it freezes itself from time to time, and the best solution to this problem is on the bottom of your Zen, there is a very small Reset hole. With a needle or a toothpick, gently stick it in, and push lightly. This will allow the Zen to unfreeze, and return back into it's regular mode. All your files will be saved, and kept on to the Zen, so you don't need to worry about losing any of your files.
Any additional help, I'll be glad to answer!
-bananaboy101
Dec 04, 2007 | Creative Labs Zen V MP3 Player
Creative Zen V Plus MP3 player not working
Zen V is dead
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Sep 09, 2007 | Creative Labs ZEN V Plus MP3 Player
Creative Labs ZEN V Plus MP3 Player Logo
139 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
