Question about Lexmark X73 All-In-One InkJet Printer
Printer won't print
Earlier tonite we were printing successfully, then we heard a loud pop and since then it won't print anything. i think it is the cartridge carrier because it won't move back to the middle on its own like it normally does. i've tried the turning it on and off and the booklet says, no paper is jammed, don't know what else to try.
  • 163 Answers
I have had this problem with the X73 and many X85's..... First unplug the power and move the carrier to the center. There is a thin (5mm) Mylar strip that is stretched from L-R behind the carrier. Using a flashlight make sure the strip has not slipped behind the sensor on the carrier. Gently lift the strip up and about 10mm and let it rest inside the "U" of the sensor. If I have not described this properly please email mediaman85@mchsi.com and I can send you some pics. MM85
Posted on Sep 30, 2007
Printer won't print. I went to printer and it says there are 9 items to br pringted in queue but they won't print Printer says it is ready
Good Day Nanawhit!
That happens all the times when first print job encounter a problem and stops printing and it was followed by series of print jobs. Some reasons for stop printing could be a printer out of paper and printer not set as default printer.
The best way to fix it is to cancel all pending jobs. When print jobs window is cleared off pending print jobs, restart your PC and your printer. Then go to your printer and make sure it is the default printer.
After that try printing a test page. Once a test page is successful, you can now print as many as you want.
Jun 10, 2011 | Lexmark X2670 All-In-One Printer
RCA HD50LPW164 turned on TV made a pop
the loud pop you heard was probably a capacitor blowing its top. The grinding noise is likely high voltage arching that was occuring due to rising voltage since capacitor isn't there to smooth it out.
Nov 02, 2009 | RCA HD50LPW164 50" Rear Projection HDTV
Problem printing PDFs on an ImageRunner 3570
Hi - I had a similar problem except my Brother printer wouldn't print any PDFs. I had Adobe Reader 11 installed at the time. I uninstalled then reinstalled a previous version - Adobe Reader 9 and that worked a treat!
Mar 05, 2009 | Canon ImageRUNNER 3570 Copier/Printer
I replaced both ink cartridges for the printer, won' print.
Please follow the procedure your printer has which forces it printer to clean the print heads.
I have experience of other epson stylus models.  I have previously spoken to epson about this exact problem.  Repeating the head cleaning process a minimum 5 times cleared the problem.
Running head clean multiple times in succession builds up pressure in the print heads - causing (usually new) cartridges to work correctly.
kind regards
Jan 27, 2009 | Epson Stylus 880 InkJet Color Printer
Can hardly read print after putting on new ribbon
You have to make a platen adjustment (on the left side move it back).
Jan 23, 2009 | IBM 4247 A00 Matrix Printer
Hp deskjet f4140 not operating
Goto start>Run>type services.msc>try to stop and then start print spooler service
Dec 24, 2008 | HP DESKJET PRINTER, HP OR COMPATIBLE
The printer suddenly refuses to print black but will print colour
try to set it in the default printer settings. it will go back to the original set up
Nov 28, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Acer aspire t180 pc has parallel and usb ports printer does not work help
Did you update the lexmark printers drivers from their site I think if you do this you should have no prolems.
Sep 19, 2007 | Acer TravelMate 8006LMi Notebook
Lexmark X73 All-In-One InkJet Printer Logo
75 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
