Question about Shinco SDP-1750 Portable DVD Player
Display light is dark
The display monitor can be turn on when the power on, but the screen becomes dark after that. The image can still be seen but not bright enough. The light adjustment is not working.
  • 2 more comments
  • allanxlz Sep 04, 2007
    Sorry, the model is Shinco SDP-6820.
    May I have some detail on the solution? Is it a component failure or cable issue?
    Without the schematic, it is hard to measure the voltage. I can not open the monitor cover even all screws are unscrewed. so the continuity of wires can not be measured. Very sad. Do you have any idea to continue the troubleshooting without schematic?
  • allanxlz Sep 05, 2007
    Thanks.for your time to explain so detail to me. Sorry I didn?t let you know I am an electronic engineer :). I fully understand what you said. I have opened the unit and desoldered a SMT switch (I suspended it was failed in the beginning). I have not opened the display panel as I felt the chance of cable failure was very low. I have Oscilloscope, multimeter and SMT soldering/desoldering station. If I have schematic, I will raise the different question to you, definitely not like this. Why I still throw this simply question to you?
    1. Sometimes a standard circuit will be used on the similar products, like LCD display. So even I don?t have the specified schematic for this product, I may still be able to do some troubleshooting for this small portion with the standard schematic, like stepper motor amplifier.
    2. When I bought this DVD player one year ago, it cost me double price compared to now. And the repair shop will charge me at least 25% of a new DVD player price excluding components fee (maybe 50% or above if including components charge). So it is not worth to send it to a qualified repair shop.
    3. And the more importance is this is my hobby. I love to repair things. This is main reason why I don?t want to send it to repair shop. If I really need it, I can buy a new one.
    Anyway, thanks again. I will donate it to school.
    Genius:
  • 1,139 Answers
I have seen this problem before this is caused by a failure of the backlight which provides illumination for the LCD screen. You may also want to check the inverter also since it fails often and interacts with the backlight.
Posted on Sep 04, 2007
  • Henry McKelvey
    Henry McKelvey Sep 04, 2007
    The flex cable might cause this. I would suggest that you take an ohmmeter and test the cable for open traces. This will take some time but it has to be done to eliminate it as a possibility. Now if the cable is good I would take voltage measurements to see if a component might be bad.
  • Henry McKelvey
    Troubleshooting without a schematic is never a good idea. This is because you may miss something vital to your analysis. So the best bet would be to take the unit to a qualified repair shop to avoid any damages.
    Now we can look at this from a different point of view, we know what might be causing this issue the only problems are getting a schematic and opening up the unit. You could take the unit to a local vocational high school and donate it and take a tax write off. These suggestions go very little into repairing this unit because of what you will see once you open the device up. Let me tell you.
    You will see a switching power supply, an optical drive with a carriage, drive motor, and a laser control board, and finally the main DVD video/controller board. All of these will have surface mounted components which are very small and require a magnifying glass to look at them, along with specialized desoldering tools. This along with an Oscilloscope, laser power meter, and a multimeter. Now if you have all of this you will still need a schematic to know which test points to look at and where those test points are located.
    Are you begining to see the magnitude of this repair job, that is why in all of my post I try to get folks to see that working on these devices past the mechanical aspect, is not impossible, but you have to have the proper equipment for the job. Even as a certified technician, If I run into a main control board problem I troubleshoot it to component level and then once my technical curiosity is satisfied I contact the DVD player company and order the actual DVD controller module, and replace it, do the laser alignment and then charge the customer the cost of the module and labor.
    That is the raw truth about these device, they were designed around throw away technology, that is why one can cost 69-199 dollars at a pop.
    I know this is not what you want to hear and you may give me a bad rating, but I feel that by telling you the truth about these devices, you can make an informed choice of repairing this device or getting another one and donating the old one as a learning tool for future technicians or using it to educate yourself about the functions of the DVD player (once you get the schematic from the DVD player maker).
    I hope I have not offended you.
    Thank you.
    Shuttle83
SOURCE:
St2410b no display
When the following conditions, namely the need to replace the LCD inverter:
No image on the screen, but the power light stays on
Dark display but still readable
Between the screen flashes on and off 1/2 to several seconds
Power light stays on, but no display and sound
No image on the screen, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
http://www.lcdinverter.info/dell-n26397-lcd-inverter-p-5754.html
Aug 22, 2013 | Dell E173FP 17" LCD Flat Panel Monitor
Erratic display
So your Gateway is brand new or a refurb?
Aug 02, 2008 | Computers & Internet
My screen is all black with the words no database what does this mean ?
When the following symptoms, the need for LCD inverter with a: No image on the screen, but the power light stays on
Aug 04, 2013 | Sceptre Computers & Internet
Desact monitor
When the following symptoms, that is, to replace a laptop LCD screen:
Jun 07, 2013 | Computers & Internet
I have lenovo g550...my screen flickers in every 5minutes...
Failing Inverter An inverter, typically found inside a laptop computer, consists of a small board, which has impregnated electronic circuits stamped on it. Inverters look like thin boards about the of two sticks of chewing gum. The inverter and its bulb control the intensity of the liquid crystal display, which lights the screen monitor. The computer can control the output voltage of the inverter and either lighten or darken the screen. A special type of inverter can adjust the brightness of the screen by using an internal sensor to judge the room brightness, and then adjust the screen accordingly. Failing inverters give off some specific warning signs, which can be recognized by observing different screen characteristics.
Short Intermittent Display Upon turning on the laptop, the screen flashes on in the normal mode for a short period and then blinks to black. A very faint image appears in a dark background, which will be very hard to see almost invisible. After shutting off the laptop and restarting, the same mode occurs, where the screen appears normal for a few seconds then fades to black. This condition points to a failed inverter. To confirm this, plug in an operational external monitor; if the external monitor functions, the inverter has failed. b> Total Blackout with Ghost image b> The laptop turns on, as indicated by the power supply button, but the screen comes up black. The screen comes up black after restart. You might be able to detect a very dim or ghost-like image on the monitor. When you plug in a known functioning external monitor, the external monitor operates normally. This mode of display indicates a failed inverter. b> Long Term Periodic Operation b> With this failure mode, the laptop screen illuminates normally upon start-up and remains that way after several minutes, hours or even days, until it goes very dark again. Brightness controls or restoration attempts do not work. Most often, the screen will function normally with a computer restart, but will eventually return to black. Faint ghost images might appear, as seen in the total blackout mode. b> Dark With Color Variation b> Upon computer start-up, the monitor shows black or dark gray, accompanied by very faint images. The screen might have an intermittent color change, or remain on with a non-standard color variation, like pink or red. b> Auto Control Switch b> If the screen appears black, with no faint or ghost images, look for the lid switch near the back hinge. The switch, when depressed with a closed lid, shuts off the computer and monitor functions. Sometimes the switch becomes stuck in the closed position, disallowing the computer and monitor to turn on when opened. Pushing the switch manually several times can often free it up. If the switch tab has broken or jammed inside the case, it needs replacing. b> Loose Connection In this mode, the display looks normal upon start-up, but tapping the side case of the computer turns the screen black. More tapping results in the screen functioning normally then cutting out again. This condition points to a loose wire connection from the inverter to the LCD backlight lamp, or the video cable. The connectors can be accessed by removing the monitor bezel screws and pulling the plastic retainer off. Both connectors can be cleaned and refitted.
Feb 10, 2013 | Lenovo G550 PC Notebook
Screen keeps t going blank but still have power
It may be the internal backlight that is failing. When the display has failed but still has power, take a flashlight and hold it close to the screen, move the flashlight all around the screen and check if you can see anything. The display will be dark, but you should be able to make out the image that is there with the flashlight technique. If you can see an image on-screen, then your backlight has failed and you will need to replace the monitor. Weather or not you see an image is not a critical issue, but a tool to verify if the backlight is off or some other issue is causing the problem.
Note, it may be difficult to detect an image on the un-light display, for example if you have a dark image as your desktop background. So make sure to fully scan your display (top to bottom, and left to right covering the entire screen) with the flashlight technique in order to see any image on-screen.
Mar 24, 2011 | Xerox XG-91D 19" LCD Monitor
Dell ADAMO 13 w/Vista 64 Random power failure...goes dead in 1 second. Battery fully charged. Happened with external power and when on battery. I have latest BIOS v6.0. I ran pre-boot diagnostics...
If the power totally fails (i.e. power is cut off, LEDs turn off, fans stop, ... etc), then this more likely to be because of a short circuit developing in a failing semiconductor component, or a power supply problem.
However, if the laptop is still running & only the display on its LCD is cut off but the laptop itself stays powered on, then your laptop might be experiencing a failing screen inverter board, a failing screen backlight lamp, or a failing LCD screen cable.
TYPICAL INVERTER FAILURE SYMPTOMS
1. When you turn on the laptop, the screen lights up for a short period of time and then goes dark. You still can see an image but it is very dark, almost invisible and definitely not usable. When you restart the laptop, the screen lights up and then goes dark again. The laptop works fine with an external monitor.
2. Your laptop turns on but the screen remains dark all the time. You still can see a very dim image outline. The laptop works fine with an external monitor.
3. The laptop screen works fine for hours or even days, but sometimes it goes very dark as it mentioned above. When you restart the laptop, the screen works fine again.
Inverter failure symptoms are very similar to backlight lamp failure symptoms and in most cases you cannot tell which one is causing the problem until you replace either the inverter board or the backlight lamp. From my personal experience, inverter boards fail more often than backlight lamps. If you have to guess, replace the inverter first.
Feb 07, 2010 | Office Equipment & Supplies
Heat from monitor
The monitor,screen,adapter or display of a computer is the primary user interface. Monitor problems are some of the most common computer problems since the voltages inside a monitor can be as high as 10 KV. Many of the problems can be fixed yourself by simply changing the settings but in a few cases you may have to either replace or repair the monitor.
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); How to troubleshoot and fix computer monitor/display problems
1. The monitor/display flickers
Check the refresh rate. If the refresh rate is 50 Hz/ 60Hz (depending on which country you stay), it can be affected by interference from electrical power signals like those from fluorescent lamps . Increasing the refresh rate to 72Hz is recommended , since higher refresh rates reduce eyestrain and headaches
2. The display works fine initially, then after some time there are black lines on the screen and then the display disappears
There is a problem with the copper windings in the CRT monitor which are getting heated. It is better to replace the monitor
3. For a new monitor, you get a blank screen or distorted image.
Many monitors, especially LCD monitors, can only handle resolutions which are less than the native resolution, so set the resolution at the native resolution only. The native resolution of a LCD display is lower for smaller LCD screen sizes, typically 1024 X 768 for 15" LCD. CRT monitors have a better resolution than LCD displays
4. The display on the monitor is not steady
This is a result of power system interference from users of the power grid, particularly UPS, power tools and heavy machinery. Try changing the position of the monitor.
5. There is a shadow on the images on the display
Try reducing the contrast setting on your monitor.
6. Monitor becomes blank occasionally
Could be a problem with the display card, check with another monitor. The monitor display cord and power cable should be fixed properly and there should be no loose connection.
7. Dark Spots on the Screen.
Move speakers,USB modem and other magnetic devices away from the monitor.
8. Incorrect Colors - red may become dark brown, blue becomes purple.
Check your video cables and connectors for bent or broken pins and wires. Sometimes there may be a problem with your display card, which can be retuned using a software available with monitor technicians.
9. Run Antivirus to scan corrupt software files.Virus cause distorted characters and images.
10. Set your monitor/display pixels to the software requirements. some softwares require higher pixels to run or to be displayed. some media players, web applications, video games applications and photo editors/view softwares have option to view photos on low or high quality
Jan 29, 2010 | Computers & Internet
TO GET THE DIFFRENT BETWEEN LCD VS PLASMA
LCD
LCD stands for liquid crystal display. These types of displays have been around for awhile and are commonly used with computers. One reason for their big popularity is the ability to produces a better picture than CRT monitors but also being much thinner.
Pro’s
  • Low Energy Consumption – LCD monitors use very low amounts of power. This is why it is very commonly used in battery powered devices.
  • LCD screens also reduce the amount of glare on the screen which can be very beneficial if your TV is in a room with lots of light.
  • If an image is left on the screen too long, LCD screens are less likely to experience the image being burned into the screen. If this does occur, it’s easier to repair than other types of TV’s.
Con’s
  • The viewing angle of an LCD TV is typically not as great as Plasma but the difference is not great enough to make a huge difference.
  • LCD TV’s can sometimes get dead pixels which aren’t typically covered under warranty. Although they are very small, they can become very annoying.
  • Brightness levels aren’t as great as Plasma and it’s not possible to display darks quite as dark.
Plasma
Plasma technology hasn’t been as widely used as LCD in previous years but has become very popular in large HDTV’s. Although they have historically been more expensive than LCD TV’s, they are becoming more comparable in price.
Pro’s
  • Brightness and color are the major advantages of Plasma TV’s. They produce rich colors along with very deep blacks.
  • Their wide viewing angles allow more people to be able to watch TV comfortably.
  • The pixels of Plasma TV’s are lit individually unlike LCD screens. Because of this feature, the pixels can be completely turned off to display truck black colors.
Con’s
  • The lifespan of a Plasma TV is typically shorter than other types of TV’s. The lifespan can be extended by turning down the brightness of the screen.
  • Plasma TV’s are more susceptible to screen burn-in where an image is “burnt” onto the screen when left on the screen too long such as a network logo in the bottom right corner of the screen.
  • Plasma TV’s require a panel of glass to cover it. This glass can reflect light and make it difficult to see the picture. If placed in a dark room, this typically isn’t an issue.
Jun 09, 2009 | LG Televison & Video
Dark LCD Monitor
From what I understand there may be a problem with the power circuitry used to light up a small fluorescent light that is the actual light source for the display. The TFT display itself doesn't produce it's own light, and if you point an external light source to the display and see program windows & other things the display itself is fine. Your problem can be solved with relative ease, but only in a computer service because it demands some components to be changed.
Jan 15, 2007 | Sony VAIO GRV550 Notebook
Shinco SDP-1750 Portable DVD Player Logo
241 people viewed this question
Top Shinco Televison & Video Experts
Marvin
Marvin
Tom Chichester
Brett Duxbury
Brett Duxbury
Are you a Shinco Televison and Video Expert? Answer questions, earn points and help others
