Question about Sharp Viewcam VL-NZ50U Mini DV Digital Camcorder
No image during recording -- sharp mini dv VL-NZ50
I discovered that my video camera was in the "record" position but was not actually taping as the pause button was on. However, though I can play back tapes mini DV tapes that I have recorded, I only have a blank, white image when it is placed on the "camera" mode to record. Should I even try to fix it? Or does this sound like a problem where I would be better off just getting a new camera?
  • juray13 Sep 02, 2008
    The camera was recording fine, then the pause button was pushed for a minute, when we tried to resume filming by pushing the pause button, the screen was gray and you couldn't see an image. The playback works fine, when you want to watch what you have recorded, but we cannot record anymore. Is this a problem that can be fixed by the consumer or does it need to be taken in for "technical" repair. If it can be fixed, is it costly?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 206 Answers
This problem can certainly be fixed and is not that expensive : the no image in capture mode when you can playback is caused by faulty CCD sensor and you might even have it done free of charge because it is often a faulty sensor that goes in your camera during manufacture. Sony in particular repairs these faults free of charge, but others do too.
Posted on Sep 04, 2007
SOURCE:
My camera records to minitape now, but how do i record video to the SD card?
HI there remove the mini tape and start recording. It will automatically save in memory card. If not then your camera does not have option to save video in Sd Card. Thanks.
Jan 29, 2011 | Sharp Viewcam VL-Z1 Mini DV Digital...
Inserted a cassette, get the message "cannot record cassette" "protect tab". A little grey piece (probably the protect tab) fell out the camera when I set it down. Not sure where this...
On the mini-DV tapes I have, the protect tab is a slider- it does not come out of the cassette. If you look at the back edge of the tape, where the long label goes, the protect tab is at the right hand end. When it is set to prevent recording it will look like a little square hole, but there should be a tiny edge of the tab showing (mine is green) which you can pull across with a fingernail or sharp object to cover the hole and allow recording.
Nov 29, 2010 | Sharp Viewcam VL-Z3U Mini DV Digital...
I cannot transfer video from my Sharp VL-NZ50 to my PC
I had the same problem with the VL-NZ50. It wasn't the camera, it was the IEEE 1394 interface on the laptop(s) -
I tried two different ones, one XP, the other W7 64; both were HPs with on-board (OHCI compliant) TI
IEEE-1394 chipsets.
Then I tried a Gateway desktop (Vista) with an on-board Ricoh
IEEE 1394 interface: the VL-NZ50 was recongnized instantly, controlled by the PC and transferring video flawlessly.
If you want it to work with your laptop , try an Adaptec PCMCIA card (I've heard they work with this camera), they can be had for under $10.
Jul 11, 2009 | Sharp Viewcam VL-NZ50U Mini DV Digital...
Computer not reading my cam
u need to first install your software that came with your camera and then plugin your camera after restarting pc
Jun 25, 2009 | Sharp Viewcam VL-NZ50U Mini DV Digital...
Mini Cassette to DVD?
you need a firewire cable to go from cam to computer or use a dvd recorder and put tv connections from cam to dvd recorder
Jul 27, 2008 | Sharp Viewcam VL-NZ100U Mini DV Digital...
No display on playback
Try first a Tape cleaner and a new cassette and start from scratch... and check if your camera is not damaged internally and it is actually recording and not just spining the tape to the end and rewind to find nothing on it. You seem to need serious repair. This means it needs a tech to have a serious look at it.
Feb 09, 2008 | Sharp Viewcam VL-Z1 Mini DV Digital...
Sharp vl-nz50
i need the software and the driver for my video camera
Nov 25, 2007 | Sharp Viewcam VL-NZ50U Mini DV Digital...
Camera head has problem
you will ruin the video head for doing that the cleaner is very rough...forward a blank new tape 5 times as you needed......if nothing happen check the video head appearance maybe have crack or weak already....
Aug 10, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
No image during replay -- sharp mini dv VL-NZ50
a cleaning cassette ( the red ' x ' ) will help : if cleaning works ? retire your old tapes , or your heads may need replacement - sooner rather than later ;
Apr 06, 2007 | Sharp Viewcam VL-NZ50U Mini DV Digital...
Sharp Viewcam VL-NZ50U Mini DV Digital Camcorder Logo
174 people viewed this question
Top Sharp Video Cameras Experts
Larry Stiles
Larry Stiles
Marvin
Marvin
abdul rauf
abdul rauf
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
