Question about Samsung Digimax S630 Digital Camera
Will turn on, then beeps 3times & turn off in 5 seconds w/ the shutter still out
My baby dropped my samsung digicam s630. When i tried to turn it on it would turn on then in 5 seconds or 3 it beeps 3 times and turns off and the shutter or lens won't close. I love this cam and i really feel bad for not being able to use it again.
I had this same problem and it was driving me crazy. I looked the camera over carefully and noticed that the lens was a little crooked. I gently pulled the protruding lens piece a little and it popped into place. After that, the camera worked fine. I guess if the lens is jammed the camera won't turn on if the lens can't move. I hope this helps you.
Posted on Oct 06, 2007
I had the same problem and was told by the tech support guy to go to the website and follow the instructions there. That doesn't work I searched the FAQs for some kind of return address and found nothing so I used the same solution that someone else posted about the video camera I also have and it worked for me. All I did was turn the camera on and just as the screen lit up tapped it with my hand and that made it stay on then zoom in as far as it will go. When I did it wasn't focused so I zoomed backout and cut it off and back on again and it was working again.
Posted on Sep 22, 2007
The view screan on my Samsung S630 camera is all blurry
Hi Guys
Every time I'd try to turn my camera on, it would give three beeps and then go off.
I decided to search your Fixya tips, and I found it. All I needed to do was press and Hold the OK/Menu button while I turned on my Samsung S630 camera and it worked!!!!!!
Thanks for the tip, and I hope Someone else will get the same benefit
Elizabeth Flood
The view screan on my Samsung S630 camera is all white looking and blurry! The photos that I take look the same.
Any tips will be most appreciated.
Elizabeth Flood
Dec 04, 2009 | Samsung Digimax S630 Digital Camera
My S630 Samsung shows a code on the screen evry time I try to take a picture. The code is F2.8 1/45 and the little eye on the left that indicates the flash blinks for a few seconds.
your carera is set on shutter priority,,,
change it to auto
what its telling you is,, its set at a lens opening of F2.8 ( thats wide open ,,,so little or no depth of field in photos) ,(and a shutter speed of 1.45 of a second?) witch means its realy dark were you are??
the little eye flashing tells you to use the flash,,,
i bet you have left it set on flash photos only?
switch it over to auto mode and out of flash mode!
Oct 28, 2009 | Samsung Digimax S630 Digital Camera
Camera Stuck with lens out. Beeps
I dropped the camera on the table a couple of times, twisted the front of it. Suddenly the lens retracted into the camera, the beeping quit, and now I can take pictures again. The Samsung website is horrible.
Jun 03, 2009 | Samsung Digimax S630 Digital Camera
Samsung S630 camera says "low battery" then shuts off
This camera needs rechargeable batteries usually lasts about a week with much use. I thought what a waste of batteries then tried these rechargable and the situation hasn't occured . it is probably because it is small digtal camera which uses alot of power.
Dec 31, 2008 | Samsung Digimax S630 Digital Camera
Camera shuts off after a few seconds
i had that problem with another camera i toggled with the lens it went in and works like a charm. Dont be to gentile it will go in
Oct 08, 2008 | Samsung S630 Digital Camera
Samsung s630 problem
i placed my camera on the counter top of my bathroom went to get it and it dropped and hit the floor. And now when i cut it on it stays on for a few minutes and then it beeps and shuts off. i even tryed using brandnew batteries and that does not seem to be the solution. Hope you guys can help!!!!!11
Jun 25, 2008 | Samsung Digimax S630 Digital Camera
HELP! dropped camera, lens won't go back in, shutter won't close
$100 is hardly expensive, and at that cost it would be cheaper to replace it than have it repaired. In future, keep it on the neck strap.
Mar 15, 2017 | Cameras
S630 camera not working !!!!!!!
If the camera was dropped, then it's really causing those kinds of issues.
You could still try these steps below:
First, do the POWER RESET:
- Turn off camera
- Remove batteries for a minute
- Reload batteries
- Turn on camera
Second, do the MASTER RESET
- Press on MENU button
- Press on the right button until you see SETUP 2
- Scroll down until you see RESET
- Press the right button to pick up on YES or NO
- Press on OK/MENU button for changes to be saved - Turn off camera for a few seconds so that settings will be refreshed
Third, you could try cleaning the lens with a soft clean cloth.
Make sure you are wiping gently.
Fourth, try to take a picture using this way:
- Press and hold the shutter button halfway first for 3-5 seconds,
and then press it all the way down
Fifth, if it still does the same thing, then your camera needs to be repaired by a technician.
If you want to know where you could send it, just call the hotline of the manufacturer of your product so you could get assistance
about this matter.
Jan 10, 2008 | Samsung Digimax S630 Digital Camera
Samsung Digimax S630 Digital Camera Logo
199 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
