Question about Pioneer AVIC-D3 Car DVD Player
Door speakers and tweeters and cuttign off
Whenever I turn the volume to about 25 on songs that have a lot of highs my door speakers and tweeters cut off. My 6x9s don't because they are connected to an amp. Anyone know what can be causing this?
  • jguedea May 19, 2008
    almost the same issue had the avic d 3 installed put the $130.00 box for the chimes an the onstar and the speakers in the front go in and out it has the factory bose with tweeters... relpaced the box 3 times whats the option to fix it or should i just go back to factory.
    Problem Solver:
  • 9 Answers
Your door speakers cannot handle the power being sent to them. get some aftermarket speakers
Posted on Oct 29, 2007
I have a BMWx-309 Nitro Tweeters. Where do i wire? Front speakers on cd player,door speaker?
Assuming you do not have factory tweeters then either is acceptable. Use whichever is easier to get to...door speakers if mounting tweeters on door or cd player if mounting on dash.
Aug 04, 2016 | Cars & Trucks
I have an 2002 Nissan altima and DA display on the radio is working but no sound
Hi candy Love , I love that name ! What Altima ? S ,SE or SL
AUDIO
Revision: May 2004 2002 Altima
AUDIO PFP:28111
System Description EKS002KQ
BASE AND MIDLINE SYSTEM
Refer to Owner's Manual for audio system operating instructions.
Power is supplied at all times
 through 15A fuse [No. 31, located in the fuse and fusible link box]
 to audio unit terminal 6.
With the ignition switch in the ACC or ON position, power is supplied
 through 10A fuse [No. 6, located in the fuse block (J/B)]
 to audio unit terminal 10.
Ground is supplied through the case of the audio unit.
Audio signals are supplied
 through audio unit terminals 1, 2, 3, 4, 13, 14, 15, and 16
 to terminals + and - of front door speaker LH and RH
 to terminals + and - of rear door speaker LH and RH
 to terminals + and - of tweeter LH and RH.
BOSEĀ® SYSTEM
 to audio unit terminal 6, and
 to Bose speaker amp. terminal 1.
Ground is also supplied
 to speaker amp. terminal 17
 through body ground B117.
 to speaker amp. terminals 23, 24, 25, 26, 27, 28, 29, and 30.
Audio signals are amplified by the speaker amp.
The amplified audio signals are supplied
 through speaker amp. terminals 2, 3, 9, 10, 11, 12, 13, 14, 15, 16, 18, and 19
 to terminals + and - of subwoofer LH and RH.
SPEED DEPENDENT VOLUME CONTROL (MIDLINE SYSTEM AND BOSE SYSTEM)
If activated, the radio output volume will be automatically adjusted to compensate for increased driving noises
at higher driving speeds.
The radio receives a vehicle speed signal from the combination meter, and selects the output volume.
Feb 01, 2015 | 2002 Nissan Altima
Speakers cutting in and out at high volume
The amp is going into protect on the two channels powering the speakers. Turn down the gain on those two channels. You also may want to consider crossing over the speakers a little higher than they are now.
The rating on those speakers are way too high. 6.5's and 6x9's will take 50-100 clean watts tops before they start to break up.
The best solution to get it perfect is....unplug the subs. Turn the gain on the speaker channels all the way down. Then turn up the deck 80% as high as it will go. Play a song. Then increase the gain on the amp until the speakers are as load as they go without distortion. Shut off the car, replugg in the subs and do the same thing. Gain on sub channels all the way down, deck then to 80%, find a bass heavy song, then turn gain up until subs become distorted. If you do this procedure your speakers and subs will be "gain matched" to the proper levels.
Good Luck
Dec 07, 2013 | Kicker IX500.4 4-Channel 500 Watt Car...
What size are the tweeters in a 2000 gmc sierra extended cab truck? In the door, there are 2 sets of speakers. The 6 3/4" and another smaller pair. What is the size of the smaller set? I have a 2000...
Hello.. the tweeters in the doors are 1 inch tweeters, but they have a large housing. Every set that I have come across are usually hanging because the 2 plastic nipples that go through the panel break off. They have a self-threading bolt on the back and they all eventually come off. You can rotate the tweeter slightly and run a panhead screw with a stinger tip to keep them up. If you are adding a pair of tweeters, just leave those in the door panel and just remove the metal grille that covers the speakers and add them next to the factory ones. You can just wire them in with the factory wiring. Just be sure to wire it on the door panel clip side so you can remove the door panel without having to cut the wires every time. You will have to remove the panel to gain access to removing the metal grille on the panel. Hope this helps! Good luck with your venture!
20 year car audio/video installer
Bay manager
Mar 17, 2011 | Car Audio & Video
My cerwin vega xls215 tweeters fade out at high volume but not distorted volume
There is a polyswitch in series with the tweeter. when it gets hot from lots of current running through it, it goes high resistance, attenuating current to the tweeter.
Remove and bypass the polyswitch if this annoys you, but then you risk blowing the tweeter if you run it too loud!
Jan 05, 2011 | Audio Players & Recorders
I get no music out of the tweeter
Connect the wires of the speaker to a 1.5 volt battery. Plus wire to plus terminal of the battery etc... Only let it touch the battery for a short time! You should hear a pop from the speaker! Put your ear close to the tweeter and see if does the same. If It doesn't, go inside the speaker and connect the battery direct to the tweeter (disconnect it from the crossover unit that feeds it). If it still doesn't pop it's gone and you will need to replace it. If it does it's the crossover that is faulty.
Tweeters are the first to go when the amp is at high volume. So make certain that the speakers don't have a lower wattage than the amp. If they have you must never turn up the volume very high or you will lose the speaker again.
Jan 31, 2010 | Paradigm Titan Speaker
I dont know how to install tweeters
only if they have a crossover attached if you dont they will blow up!
Jan 21, 2009 | Boss TW-25 Car Tweeter
ZX700.5 cutting out at 60% volume
I figured out the problem, the front right tweeter wire was pinched behind the mounting bracket. everything is now working perfectly.
Sep 22, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Tweeter and door speakers to fit a Lexus EX 300 w/Levinson factory system
I found that they can hold up to 6 1/2" speakers and 2" tweeters. I'm not sure the specific mounting depth but i can almost assure you there wont be any 6 1/2" speakers that require a whole lotta space
Feb 22, 2008 | Cdt Audio Eurosport ES-100 Car Tweeter
Tweeters fading out
Turn on the HPF it will definatly clear up the sound.
Aug 07, 2006 | MB Quart DSD 216 Car Component System
Pioneer AVIC-D3 Car DVD Player Logo
54 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
