Toshiba Satellite A105 PC Notebook
Problem for Toshiba Satellite A105 PC Notebook
Toshiba Satallite Wont start up
By beckfore on Apr 05, 2009
I have recieved a Toshiba Satallite M35X-S111. It had no hard drive. I pruchased a hard drive and installed it. I assume it will work but when I push the on button...it starts up for about 3 seconds and shuts down. It just wont start up all the way. 3 seconds is all I get out of it. Power cord and battery are fine. Any suggestions? Thanks
Comments:
Apr 13, 2009
- Thanks but did not work.
Solution #1
posted on Apr 08, 2009
Somewhat Helpful)
Cleverer2
Rank: Guru  Computers & Networking  Expert
Rating: 86%, 135 votes
Gently remove and clean (with a pencil eraser) and reinstall your memory, then try again.
For you non-techies, it is very easy to hose a perfectly good laptop by NOT fully releasing the side-latches (some metal, some plastic) BEFORE gently lifting the RAM up 1/4", away from the pin/contact seating area, and OUT of the sockets. Actually, if you do it right and do not physically touch the face, sides or corners of the RAM when you use your Left and Right thumbnails to 'tease' the latches away from the sides of the RAM, it will POP out all by itself.
Now... putting new RAM in is REALLY easy and does not require any force or pressure at all. Look at the socket and the RAM and orient your RAM so the slot in it (the RAM) and the raised portion of plastic in the contact seating area line up. If it is OBVIOUSLY not, flip the RAM over and check again. If it still will not, or can not line up... it is the wrong type RAM for your machine. Take it back. Do not try to 'make it fit' ;-)
Once you have RAM oriented so it WILL slot in, take the RAM between your index fingers and thumbs so the contacts are facing AWAY from you and hold firmly by putting the tips of your fingers into the holes on the sides of the RAM, ease the RAM into the socket and seating area, wiggle a bit side to side and seat in snugly, then maintaining the hold with your 2 Thumbs, tease the latches away from the socket edges with your fingernails (under the edges of the new RAM) so they both clear the sides of that RAM, then gently press down a bit further with your thumbs until the RAM face is below the latches and finally release the latches making sure BOTH are now above the RAM face. Done.
Don't FORCE... EVER ;-)
Hope that helps
Was this helpful?
Yes
No
Popular Solutions for Toshiba Satellite A105 PC
Questions and Unsolved Problems for Toshiba Satellite A105 PC
Do you recommend Toshiba Satellite A105 PC Notebook?
Answer
Answer
fn plus F8 key malfuntioning and can not connect new laptop M550 to AT&T Broadbrand. New... (More)
Answer
I can´t turn it on. I´ve had it checked and everything seems to be OK, although I... (More)
Answer
I am so frustrated. This program feels like a scam to me. I have uploaded the pop several times;... (More)
Describe your PC Laptops problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
in Burnsville, MN
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
