I'm looking for a electrical manual for a 1990 Fleetwood pace arrowI'm looking for a electrical manual for a 1990 Fleetwood pace arrow
AnonymousMar 27, 2014
Have an idea problem where it won't start is in lack of fuel getting to injectorsHave an idea problem where it won't start is in lack of fuel getting to injectors
You can't post conmments that contain an email address.
defintely sounds like fuse or relay. also could be relay for your headlights thats runs to the ignition switch as well. trace your wires from ignition switch out through the firewall and see where they go. may need to have second person help. Wherever the wires go is prob your problem. Most likely a relay. also check for any hot wires loose touching thats shortening the circuits.
460 engine? I dont think the white wire is used if it has an internal regulator, you mean WHITE/BLACK WIRE??? IF it has an EXTERNAL VOLATAGE REGULATOR it goes to that (white/black)
If you're getting spark and cranking replace the starter solenoid, if no spark and cranking replace the ignition module, if nothing is happening but have power replace the ignition switch.
Hello! Here are two vacuum diagrams for the 460 engine...#1=1987-89....And #2=1990-95...Depending on manufacture date of your motor home's engine I'm sending both diagrams...Guru.............Saailer
Thanks,
It was on the left frt fender apron.
