I am having trouble getting my computer to recognize my USB that i just bought. I have Windows Vista and i put in the USB. It comes up with 'Insert the disc that came with your Kingston Traveler USB' i selected don't have disc show me other options. Then i selected browse my driver for driver software but it doesn't work. What can i do??
-   i get msg" windows need to install software for your kingston DT 101 II USB device" then when i try to install it i can not locate it.. and i can not use any memory stick with my windows
-   iman_elwasif
May 12, 2008
-   I have 2 identical Laptops, both with Vista Business installed on them... My Kingston 2gb works one one unit and not on the other..... Isn't Vista Great!.
Of course the Laptop I used myself is the one that wont install the Kingston 2gb drive.. BTW it works with the 256mb and the 1 gb, but not the 2 gb..
FRUSTRATED... Yep, I am.-   Guest
May 04, 2008
-   same-   Guest
Mar 11, 2008
-   no hadr driskd formed but only recognizes -   Guest
How to remove the write protection in drive on Volume/Devices/Hard disk/DC6 I need some help.. I...
(More)
How to remove the write protection in drive on Volume/Devices/Hard disk/DC6 I need some help.. I cannot write or move files on My Kingstone 4GB Data traveler. The message notification says it is write protected and ask to remove the write protection. Unfortunately, I don't know where to find the write protection or where to start to remove the write protection.
Same Problem!!! the Error is |X| Cannot Copy the file: Cannot Fine the Specified file Make Sure you...
(More)
Same Problem!!! the Error is |X| Cannot Copy the file: Cannot Fine the Specified file Make Sure you specify the correct path and the filename my USB devise having problem SKYMEDI USB drive 2GB and it cant be reformat the device is empty plz tell me if this device will not be used forever or you can do this problem.. plz help me on this error Thanks!!
I just got a generic 16gb flash drive and just about every media file i copy there gets corrupted....
(More)
I just got a generic 16gb flash drive and just about every media file i copy there gets corrupted. Altough it's not every time it's about 95%. Is there anything i can do to remedy this or does the problem lie with the drive itself? Thanks.
