Question about Refrigerators
Frigidaire side by side overheating
Excessive heat coming from bottom, and the wall dividing the fridge and freezer is very warm and is transferring heat to the door seals that touch it when closed. Is this repairable or on its last leg?
  • 2651 Answers
SOURCE: Excessive heat coming from bottom, and the wall
very repairable, the unit is tryin to release exessive heat from lower compartment, pull unit out and vaccuum the coils,as well as underneath the unit, when pulled away form wall, make sure that the fan behind the unit(next to compressor) is running.
Posted on Aug 25, 2009
0 characters
1 Points
Center divider between refrigerator and freezer is hot to the touch
Check the cooling coils under the fridge..most likely need a good vacume ckeaning insufucent cooling/warming due to being clogged...remember your fridge has cooling and heating to control frosting up...coils need cleaning periodily especially if you are a pet owner...good luck.
Feb 22, 2015 | Frigidaire Refrigerators
The center dividing face plate of our side by side fridge (which we just got from a friend) if warm to the touch. Only the front of this divider is warm, from top to bottom. The inside walls are cool. Is...
Hi, welcome to FixYa.
I`ll start by letting you know first the heat between the doors is normal, a degree, and done by design to help prevent moisture along the "breaker strip"/divider.(where the doors come together when shut)
If all else appears fine (temp. Ok, fans running, no significant frost build up on freezer back wall) it's likely nothing to be concerned about.
**Just be sure the condensor fan isn't jammed and still turning.** The fan at the back next to the compressor...In fact that is what I`d look for based on your post.
But just so you know, the amount of heat can be determined by several factor's such as,
1) temperature setting - lower ( colder ) the temperature is set the more the run time the hotter the strip.
2) The ambient temperature - hotter the environment the more the unit runs to compensate, hence the hotter the strip.
3) The amount of "fresh" content added to the unit ( especially freezer section if unfrozen items added ) - new items add a lot of warmth thus demanding the unit to run more to remove this heat (btu`s or british thermal unit`s )causing the strip to be hotter.
4) Build up of dust & dirt on the condensor coils - this also causes the unit to run excessively which in turn makes for more heat on this strip.
These are all things which can and do determine the amount of heat between the doors.
Another factor to always consider is of course If it is hot where you live the unit may just be running more to compensate as with other factors I mentioned.
Hope this answer's your question and let me know if I can assist you further.
Thank's for coming to "fixya" and good luck moving forward.
Please take a second to write a brief testimony and rate the info provided here.
Macmarkus :)
May 30, 2011 | Kenmore Side by Side Refrigerator
Divider between the fridge and freezer is hot to the touch, only from the outside the inside walls of both the freezer and fridge is cold, but the outside facing you as you open the door divider is very...
This is usually normal for these units it can depen on how long the unit is running in a cooling mode.
the other thing to check is the condensor fan in the bottom back side of the fridge and make sure it is running if it is not the it needs to be replaced this will also cause alot of heat on the fromt of the unit
Jun 03, 2010 | Kenmore 53642 / 53644 Side by Side...
Refrig temp not cold enough..drinks are almost warm
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Aug 27, 2009 | Frigidaire FRS26H5AS Side by Side...
Aug 25, 2009 | Frigidaire FRS6R5EMB Side by Side...
Whirlpool Side by Side - Overheating
HI thanks for your question. the heat between the two doors is normal. its heated there to stop moisture, from hitting a cold surface , and turning to water, so its normal. but pull fridge away from the wall. remove the back panel by the compressor. clean all coils. thanks the appliance doc. please rate my answer. thanks
Oct 13, 2008 | Whirlpool Refrigerators
Side by side frigidaire
check the evaporator fan motor, behind the back wall of the freezer. If that is turning check if the damper is opening, top lt of the refrigerator compartment. I hope this helps you.
Jul 09, 2008 | Frigidaire FRS3R5EMB Side by Side...
My Frigidaire side-by-side fridge (model: FRS24XGCW2) never reach freezing temperature in freezer though both side are colder than room temperature. The compressor and fan keep working forever.
1. Check and clean the condenser where system heat is transfered to the air. Located in back behind removable panel, after cleaning make sure you re-install the panel for proper air circulation.
2. Check the back wall of the freezer for ice or frost. If you have frost buildup on the back wall you have a defrost system problem. This would be lated to the timer, heaters, or defrost thermostat.
Jun 02, 2008 | Frigidaire Refrigerators
Frigadaire freezer cold but fridge compartment is warm
i need the complete model number to narrow it down they still make the frs20zrg to this day the last two numbers like frs20zrgwo or frs20zrgw9 is what will tell me what kind of defrost system it has the serial plate is in the fridge side up by the light bulb or on the left hand side or right hand side of the fridge compartment up near the top sorry to be a bother but its necessary
Mar 30, 2008 | Frigidaire FRS26ZSG
the inreasion of heat is normal if you recently add food to froze.Let it work for some hours without open it and check it again
Nov 06, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
213 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
