Question about GE JBP70BK / JBP70WK Electric Kitchen Range
Oven stays on preheat
When I turn on the oven I can set the tempeture and it goes to preheat, the is it stays on preheat. Can anyone help
aborcass
  • 2651 Answers
SOURCE: low oven temp.
sounds like a bad oven/bake ignitor. very common problem on all gas ranges.
Posted on Oct 21, 2008
jumptrout51
  • 3361 Answers
SOURCE: When everything is set to come on,the oven will not come on.
Make sure the glow bar ignitor is working in the oven.
They can glow and still be bad because of poor resistance.
Posted on Feb 22, 2009
SOURCE: amana ACS3350AS stove temp in oven stays at 100
We had the same problem and it turned out to be a burned out lower heating element. Only the top one was heating and I could never get it over about 150deg or so.
Posted on Mar 24, 2009
SOURCE: Oven will not heat - lights on panel do work
I keep having the same issue with mine, but if I go to the fuse box and flip the breaker off for about 10 seconds and then back on, it works fine. Obviously this isn't a permanent fix but it gets my stove working again for a couple of days usually. I have not been able to find anything on this issue until I saw your post.
Posted on Jan 24, 2010
  • 189 Answers
SOURCE: GE Range...oven problem. Oven turns on but doesn't
Check resistance of lower burner ignitor. Should be above 4ohms. If not, replace. Part 40-75$ + labor. Let me know if info helps- ED
Posted on Mar 02, 2010
How to preheat oven
Hello, Cristina -
Since you have not stated the make and model of your oven, all I can advise is for you to turn your oven on and set it to the desired temperature and wait for 10 - 15 minutes until the oven comes up to the full heat temperature.
You can read the instructions here, if you wish:
https://www.wikihow.com/Preheat-an-Oven
Best wishes.
Oct 29, 2018 | Ovens
Oven kicks on gas lights runs for 10 sec then beeps showing preheat is done then kicks off
I had to replace my igniter to get mine to work. I did it myself for $65.00 Mine the gas just would not stay on to heat up.
Mar 13, 2015 | Maytag Ovens
Oven preheats but will not maintain heat
Hi you have a bad thermostat for the oven , I would guess that everything else is working ok on this unit correct ? if you send information i will look up the part for you this is easy to replace , as always turn the power off before service or unplug
Nov 25, 2011 | Maytag Ovens
Oven takes along time to preheat to desired tempeture
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jun 06, 2011 | Tappan Kitchen Range
Kenmore oven model 665, oven temperature goes up
need to check oven sensor probe located inside of oven will be in left or right hand corner. the tech sheet should still be on the back panel of oven it will have instructions how too...
Sep 30, 2009 | Kenmore Kitchen Ranges
Magic chef oven/stove top range not staying hot
Hi, It very well could be the ignitor. Sometimes they work at first and then will not open the gas valve later in cycle. You can set the oven to heat and watch the ignitor. If it glows and the gas will not ignite in 30 to 45 seconds, the igniter is getting weak. I jope this helps.
Please let me know if I can assit you further.
Vic
Jun 20, 2009 | GE JGRP17 Gas Single Oven
Kenmore Ultra bake self cleaning oven is showing code E0 - F2
My oven will not stay on, when started to preheat it will come on for a few seconds and they it will make a beeping noise and the codes E0 F2 will appear. The codes stay on even if the oven is off.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Hotpoint oven
does the display go to 425 or are you putting a dial thermometer in it?is the new control doing the same thing as the old control?
Oct 23, 2008 | Hotpoint RGB745 Gas Kitchen Range
GE JBP70BK / JBP70WK Electric Kitchen Range Logo
277 people viewed this question
Top Kitchen Ranges Experts
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
