Question about GE WBSR3140DW Top Load Washer
Burn Smell (electrical) from my GE WPSE4200A0WW
Hi, My washing machine is running fine. However, during the spin cycle there is a burning smell (electrical). What could possible be going wrong with the washing machine? Thank You for your assistance.
  • 1 more comment
  • Anonymous Aug 28, 2008
    about my 4th load of laundry,before the spin cycle the electrical breaker will trip. When I open the door it smells
    like burnt rubber.
  • lbasinger200 Sep 02, 2008
    My washing machine (whirpool ultimate care II) runs, but smells like burning/smoke. We need a clearer solution as to how to fix this problem. Can I have step by step instructions on what to do? Thank you!
  • abharvey Mar 17, 2009
    My husband and I noticed a burned rubber type smell during the spin cycle as well. The clothes appear to be fine and they don't smell, but the smell seems to be lingering long after the wash is over.
We have the same problem, and found out the the electric motor is running very hot. Replacing the motor seam to cure the problem, but the motor is not inexpensive. $200 to $350.
Posted on Aug 01, 2009
  • 641 Answers
There are a lot of things could cause the burning smell. Best thing will be to remove the service panel and to try to find out the smell source. Good luck!
Posted on Sep 04, 2007
SOURCE:
My washer was smoking during the spin cycle what could the problem be.
hi Bill.
The pump may be belt driven, motor driven or have its own electric motor. A burning smell coming from the washing machine during or after the spin cycle can indicate that the drain pump has become seized, preventing it from turning.
read up some more at this link.
https://www.partselect.com/Repair/Washer/Burning-Smell
Dec 12, 2017 | Washing Machines
Maytag Performa clothes washer. Model LAT2500AAE. Made screeching sounds during spin cycle also burned rubber smell. Turned off. Removed and replaced belts. One belt was shot. Ran a test run and still...
Check to see if your water pump is spinning. It could be seized up and the burning smell could be the belt spinning on the seized pulley. Good luck Friend.
Oct 10, 2017 | Maytag Washing Machines
Burning smell during spin cycle on frigidaire washing machine
Open lid as you would load clothes and hold the inner drum with all the holes in it. Give it a manual turn left, then right. If it spins in both ways the main bearing is gone. This is not a DIY because the new bearing has to be pressed on at a machine shop, or an appliance repair shop.
Dec 29, 2009 | Frigidaire FWS445RF
It made a quite hum during the spin cycle, instead of the normal (much louder) spinning sound. When I turned it off I noticed it had a rubber/electric burning smell.
If it's a squealing sound, your belt is probably bad. If it's a humming noise with those smells you listed, it might be your transmission going bad.
Nov 02, 2009 | GE WBSE2090A Top Load Washer
1 yr machine. Won't spin but has burning smell
The reason to this problem can be due to the
brake rotor.It need's to be replaced.
Sep 01, 2009 | Maytag Centennial MVWC500V Washer
Washer spins but won't drain, electrical smell
HI, the smell is coming from the pump housing. the pump impeller may have slipped of the drive stud, in return, jamming itself in side the housing. this will cause the pump to burn out. Check the following before you replace the pump.
1. Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
Jul 09, 2009 | Kenmore 24032\24036 Top Load Washer
GE Wizard Top-Load Washer - Burning Smell
sounds like an over heated motor. motors tend to do that before finially hitting a brick wall. please e-mail me for any other assistance. good luck :)
Jul 07, 2009 | Washing Machines
Washing machine spins slowly and smells of burning rubber
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
Apr 21, 2009 | GE WBSR3140DW Top Load Washer
Burning smell + Screeching sound but Belt is not the cause, then WHAT is?
A lot of people may be searching for help with horrible sounds and burned belts for Maytag and Admiral washers only a few years old from Home Depot etc. They used a cheap pump that has a corrugated sheetmetal ring that holds the bearings. Well as it runs the vibration and friction cause it to slip down and grind on the pulley as well as not turn easily. If you put the washer on it's back and turn the small pulley and it turns with a gritty feel or you can actually see a loose metal collar type ring thing that looks like a cookie cutte; then you have a bad pump.
There is a small access panel on the back of the washer. Three screws and two spring clips on the hoses and you're done (use big pliers on the hoses). Put the belt back on (just push motor to one side, it's not tight), then check for leaks and reinstall the cover. VOILA! You can find the pump on ebay for $25 or your local GE parts dealers for $50.
Sep 11, 2007 | Maytag SAV5710 Top Load Washer
GE WBSR3140DW Top Load Washer Logo
1,256 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
