The problem started with noise and static on the screen only when the TV was cold and first turned on, which faded after the TV warmed up. Slowly the static continued longer & longer. I was able to help or worsen the problem by pulling on the Cable TV input cable. I then grabbed the input connector on the TV where the Cable TV cable connects, and was able to again generate the static / noise with small movement of the connector. The Cable signal to all other TV's is good. How can I fix the issue?
-   OK - I have the same issue as this one: "The problem started with noise and static on the screen only when the TV was cold and first turned on, which faded after the TV warmed up. Slowly the static continued longer & longer. I was able to help or worsen the problem by pulling on the Cable TV input cable. I then grabbed the input connector on the TV where the Cable TV cable connects, and was able to again generate the static / noise with small movement of the connector. The Cable signal to all other TV's is good. How can I fix the issue?"
However, the solution is replace the tuner. But the tuner is no longer available by Toshiba I'm told. Does anyone have any suggestions ????????-   36 inch
May 27, 2008
-   Same problem on32" Toshiba TV 1996 model year
-   bill17932
Jan 01, 2008
-   We are having a similiar problem with an intermediant interference with the BNC connection that goes from the attenae on the tv to the vcr attenae. Could we use the S-Video connection instead of the BNC connection to fix this problem?-   beckernc
Hi, it sounds like ya most probably gonna haveta resolder the Cable Connection Socket internally.. they often fracture, OR perhaps it is the Actual Cable Connection Plug itself?.. maybe you need to remake this input connection? Indeed it sounds as if the Earth Shielding is making bad contact...
my tv wont turn on..there is just a flashing red and green light on the front panel. I have tried to...
(More)
my tv wont turn on..there is just a flashing red and green light on the front panel. I have tried to unplug for half a day, but its not turning on.. Help!!
Cable connector is loose on the back of the tv, and will not work. It's a silver box, with cable...
(More)
Cable connector is loose on the back of the tv, and will not work. It's a silver box, with cable connector coming out of it. It has f860-4A-125V Little Fuse Inc. Mark:Type 251004
We just connected to a suddenlink dvr box and new remote, tv was working fine now all the sudden...
(More)
We just connected to a suddenlink dvr box and new remote, tv was working fine now all the sudden it's not getting audio. Any ideas, i've gone over every bottom on the remote
