Dehumidifiers
Problem for Dehumidifiers
Generic problem for all Dehumidifiers
DeLonghi 50 Pint dehumidifier DE 500P won...
By Jimmypopcorn on Sep 04, 2007
A few days ago my pump on the dehumidifier stopped working...and filled the container; not a big deal. Now, I just emptied the container and replaced it...and it will not turn back on; it appears to think the container is still full. I've manually tried to activiate the shutoff button that works with the float and still nothing.
Any ideas?
Thank you
JimmyPopcorn
Same Problem
Jun 30, 2008
-   I have same problem as Jimmy Popcorn -   Guest
Jun 27, 2008
-   I bought this dehumidifier less than 2 yrs ( after the october storm here in bflo) and it worked great.. I unplugged it for the winter.. and plugged it back in and it started then stopped.. checked the outlit and that is fine. HELP-   swimmer35
Best Solution
posted on Jun 24, 2008
Helpful)
Tech101
Rank: Guru
Rating: 86%, 109 votes
If it is not responding when you try to activate the shutoff button and are still not recieving an acknowledgement that the bucket is full you may hav a defective shutoff button. Try contacting the Manufacturer and see if you can purchase just the button. This i a common part and the price is usually reasonable. If you feel very technical inclined you can remove the button and touch the 2 wires together simulating a closed contact. The dehumidifier should now acknowledge the bucket is full. If you recieve the notification then the button is bad. If you found this solution helpful please rate it.
Thanks - Tech101
Was this helpful?
Yes
No
Solution #2
posted on Aug 30, 2008
Not Rated)
mowmow22
Rank: Apprentice
Rating: 70%, 1 votes
I have the same problem and determined it is a clogged filter. You need to take the cover off to replace it. I have logged onto the delonghi website but didn't see the fileter. I will most likely just put anyold filter on it.
Was this helpful?
Yes
No
Popular Solutions for Dehumidifiers
Questions and Unsolved Problems for Dehumidifiers
Answer
I am looking to purchase an everstar airconditioner/dehumidifier. I was looking to see the value if... (More)
Answer
small basement efficiency that is not occupied during cold months, and accumulates mold and paint... (More)
Answer
Soleus 40 pint dehumidifier... used for 3 years, stopped making water. Recently overfilled, auto... (More)
Answer
does not take in the moisture Fan rotates but seems slower
Answer
A large block of ice formed over the entire front where the vent is. Basement temp was apprx 64... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dehumidifiers:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1204
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
