Question about EliteGroup P4M800-M7 Motherboard
Absolutely No video
I have had it with this motherboard, I have checked and rechecked all of the onboard jumper settings. All connectors are properly inserted. I have switched memory twice (DDR2/533MHz, i Gig. My memory modules and video card are inserted properly, yet, there is no video on my monitor. What is the problem with this supposedly good MB? HELP! modsec1
  • modsec1 Sep 05, 2007
    I would love to try disabling the onboard video in BIOS, but like I've mentioned, there is no video nor POST (that I can tell).
Did you use a p4 connector? I had the same issue. Had to connect to the p4 Video slot. If your power supply doesn't have one you can get an adapter for about $3.00
Posted on Feb 10, 2008
  • 12,061 Answers
Have you disabled Onboard Video in BIOS if you have it?
Posted on Sep 04, 2007
Jumper setting for video on the motherboard
Unless you are working with 1980's vintage motherboards, there are no jumpers on the motherboard for video. Most motherboards today, if they have onboard video and an expansion video slot, have a BIOS/CMOS option for which video you want to initialize first (onboard/PCI). A few may actually have an enable/disable capability, but few do anymore. It is all automatic.
Mar 13, 2015 | Computers & Internet
I get no video on my x8dt3
VGA Enable
Jumper JPG1 allows the user to enable
the onboard VGA connector.
Make sure this jumper is between pin 1 and pin 2.
The jumper is at the bottom of the motherboard, just about in the middle of the bottom edge.
If this jumper is between pin 2 and pin 3 it disables the onboard video.
Dec 12, 2012 | SuperMicro X8DT3-F Server Board -...
I Need the jumper settings for the fic k8mc51g motherboard from a emachines desktop computer. Putting the motherboard in a custom case.
There is a 4-Pin Speaker connector that is not used by Gateway on the motherboard (right beside) the CMOS jumper settings (Pins).
The clear CMOS settings jumper block is right beside the speaker pins. You can use this jumper block to clear the CMOS RAM, which is powered by the onboard real-time clock button cell battery.
Pin 3 is indicated by the markings on the board.
Settings: Pins 1 and 2 covered = Normal Operation Pins 2 and 3 covered = Clear CMOS enabled.crazyeyes746.jpg
Jun 26, 2011 | Computers & Internet
This is going to sound vague, but currently a friend and I are working to get this desktop PC working that has a KN9 SLI motherboard installed on it. Currently, the issue is: The computer turns on, a red...
Try checking the jumpers on the motherboard. A lot of the SLI compatible boards have jumpers that need to be configured properly. You can find out the positions by checking the motherboard manual. Are you using an SLI capable video card or is the video onboard? I just ask because I had the same problem once while trying to install an SLI video card. I had no picture on the monitor and I couldn't figure it out for the longest. Finally I found the answer in the motherboard manual and it turned out to be a jumper that was set wrong. Hope this helps.
Mar 23, 2011 | Abit KN9 SLi Motherboard
How to turn off the builtin video on QDI Winnex 1E motherboard?
Check your BIOS - there should be a setting in there to disable the onboard video. You shouldn't need to use a jumper to disable this.
Dec 18, 2009 | QDI Group QDI WinneX 1E Motherboard
Is there a jumper to turn off the onboard video
The choosing of video is normally done with the BIOS setup. Use whatever access key is needed to get into the BIOS and then find the page that sets video, and select onboard or PCI, or AGP, or whatever the choices are. No Jumper.
Nov 03, 2009 | PC Chips P23G Motherboard
Intel motherboard d865gbf I can not use my ide
check the jumper settings.. if properly done.. and still not detect the other one.. check the cable
Sep 06, 2009 | Abit KD7-G Motherboard
New motherboard no output
Try resetting the cmos with the onboard jumper.
Make sure the video card is properly seated.
Jun 18, 2009 | EliteGroup ECS A780GM-A Motherboard - AMD...
Speakers doesnt play
check the motherboard manual and see if it requires a jumper to enable the audio onboard ( if so get the jumper from your motherboard box and seat it on the correct jumpers in the correct position to enable onboard audio ( assuming its onboard audio that you are using ) If not then ensure your sound card is seated firmly and install the correct drivers ( for either the onboard audio or the dedicated sound card ) and then ensure that the speaker cables are connected to the correct connectors on the sound card ( whether onboard or not ) and make sure windows audio is not muted for any of the auxilary lines ie wave etc and if its realtek ensure that you have 2 speakers selected in the HD Control panel and not head phones.
May 08, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Open Questions:
See all EliteGroup P4M800-M7 Motherboard Questions
EliteGroup P4M800-M7 Motherboard Logo
61 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
