the first thing, some programs that don't show in desinstall list, can sometimes be desinstalled by using a simple link that is in the start menu, name of the app (in this case, adobe)
doing what you did (deleting the folders or files ) is the worst thing you can do, because breaking the registery, leaving orphans entries...!!!
the only way without format and reinstall all, is tring to clean the registery, but even that way, it is not 100% sure you be able to reinstall !
SOURCE: java install 1101 error
Download Full Manual Install here
http://java.com/en/download/manual.jsp
Disconnect your internet. Then install. Works like a charm now. I had the same issues with Vista. :)
SOURCE: unable to uninstall Photoshop 7 on Vista
Try deleting all the files from the Photoshop folder in the Adobe folder in Program Files.
Then download a free program called ncleaner. just type ncleaner into google. after you install it, run it and press the Clean System button, then Clean Now. Just click yes when it asks you. Then click back to the main screen, and click find junk. that should get rid of any leftover files from the photoshop install.
chris
SOURCE: The Japanese Language Support Package is required
The PDF document contains data in Japanese and needs the support package to display the correct Japanese characters. This is common with files on websites of Japanese companies even thought the document may contain English language also. You can simply cancel and then view the document English text but the Japanese text will not be displayed and you will see various garbage and blank spaces instead. Alternatively, you could simply install the support package. This will then enable Acrobat reader to correctly display Japanese characters. Note: you can also get a similar message if you access a document in Chinese which will then prompt you to install the Chinese support package!
