Question about Sony DVDirect VRD-MC3 DVD Recorder
Dvdirect signal missing
I am getting a no input signal message when i hook up to the side input terminals of my flat screen tv (with the tv on) as a result i cannot record. the record light on the dvdirect comes on and goes off because it is waiting for the input signal which never comes.
  • 5 more comments
  • Anonymous Jan 27, 2008
    I have the same problem when connecting to the TV. I am connected to the output connections on the TV and the input connections on the recorder.
  • fyrfytr9 May 07, 2008
    No input signal. New unit, new AV cables. Tried on tv/vcr combo and into a vcr.
  • MikeGryn Jun 14, 2008
    brand new unit (Sony VDRD-MC5). hooked up to my DirecTv TIvo (DVR) receiver and successfully transfered 2 saved programs to 2 DVD-Rs. Attempted to make another transfer from the DVR and it said "Waiting for Signal Input"...i re-checked everything....everything was fine. Still not working correctly.
  • Anonymous Jul 12, 2008
    I have the same prob Any solutions
  • rbsmoore Jul 21, 2008
    Have the MC5 connected to the OUTPUT ports of my cable DVR. I have sucessfully recorded 2 shows to dvd. The 3rd show (a movie) would show up on the screen of the MC5, but when I depressed record it wou8ld either display "waiting for signal and the screen go blank, or it would record 2 or 3 seconds then go blank with the same "waiting for signal message. If I depress stop it returns to the previous screen and the show I'm recording shows up on the monitor.
    Very expensive toy to not work. Plese help.
    Barry
  • Benio Nov 03, 2008
    I have just bought this device and have exactly the same problem.
    I succeeded for some videos but others I have "No input signal" message, therefore I could not dub the whole show.
    It is very frustrating.
  • Anonymous May 03, 2009
    I have the same problem with my new Sony DVDirect. It copied some movies successfully and others I received the "Waiting for Input Signal."
    I experimented with a few Disney VHS movies. I was able to successfully copy some non-Disney movies fromthe early 70's that I had recorded to VHS, onto the DVDirect. When it came to the Disney VHS movies, I was unable to copy (they normally contain copyright protection technology).
    I agree with Mike. If the DVDirect detects copyguard technology, it will not record. You will receive the "Waiting for Input Signal."
In my case...DVDirect may have been detecting some sort of copyguard (copy protection) ....not sure.
Posted on Jun 17, 2008
Pls remember folks that the unit is a recording unit, therefore it requires a signal coming into the unit input from the OUT source unit you are recording from.
Posted on Aug 12, 2008
You need to connect a TV out connection (if your TV has one, check your TV specs/manual) like a Scart socket to the DVDirect input connections. Also check DVDirect has the correct input selected via its menu
Hope this helps
Posted on May 28, 2008
Hi if you want to record from your TV my guess is you are connecting the DVDirect input connections to the TV's input connections, that is these connections are for the TV to recieve a signle and DVDirect is also expecting to recieve a signle which is not going to come
Hope this helps
Posted on Nov 06, 2007
I can't get a signal because this tv don't have cable antenna terminal the tv has rgb terminal. I don't know what to do?
RGB is for a computer screen display signal and has nothing to do with TV display of channels. You must have a Component hook up, it is a yellow cable, a red and a white one. Yellow is video signal, the red and white are sound.
Sep 12, 2016 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
How to get a TV picture via the rear terminals.
Probably because the side terminals are IN{PUT} terminals (A/V signals from the source go into the TV) and the rear terminals are OUT terminals. Please read the labels next or under the terminals to make sure.
Feb 21, 2015 | Toshiba Televison & Video
I pluged the tv in and on tne screen it says no signal
You need to set the input on your TV to what terminals you have your TV hooked up to. For instance, if you have a DVD player and its hooked up to your composite terminals then you need to set your input to composite 1 or 2 just whichever one your hooked up to. If you have cable or an antenna and it's hooked up to your coaxial then you need to set your input to TV. And so on. I hope this helps you.
Aug 29, 2010 | Digital Lifestyle FA1B32Z 32 in. LCD...
DVDirect recorder. waiting for input signal? It shows the video on the screen but i push the record button and it stops and says waiting for input signal?! help!!!!
HAD the same problem! Called sony and it was fixed for me. I had a/v wires hooked up from my camcorder and from my vhs. I could see the video on the DVDirect screen. I would hit record and screen would go black and say "waiting on input signal". The fix: 1. turn the unit on. 2. Hold the on/off button for 30 SECONDS. (YEP, believe it or not) When I hooked the wires back up and did the same thing I had been doing. IT WORKED!!!! Hope it works for you!
Sep 22, 2009 | Sony DVDirect VRD-MC3 DVD Recorder
AKAI 27 Model #LCT2785TA
The message you are seeing means that the tv is not receiving a signal from the source. Try hooking up a different source such as a DVD player or a Cable Box to that same input on the tv. If you have picture and sound then the problem is with the original source. If that does not work then you have a bad Main bd.
Jul 10, 2009 | Televison & Video
Insignia 37 inch lcd inputs not working except for hdmi inputs
TV when hooked to Direct TV by HDMI will not work, it must be hooked by RCA cables. I now have 1080i rather than 1080P. The HDMI cable and the direct TV box has been changed. What can the problem be?
Jul 01, 2009 | Televison & Video
"NO SIGNAL" message on screen
You need to press the INPUT button on the TV or the remote control until you've selected DVD as the signal source. Then you'll be able to watch the DVD.
A manual is available for download from the website tv.manualsonline.com. It's free, but they ask you to register. I've gotten many manuals through the site and it hasn't generated any spam emails or caused any problems.
Apr 07, 2009 | Proscan 19LB30QD 19 in. LCD HDTV/DVD Combo
No signal
mine did the same thing...it was on rgb...didn't have ability to plug in computer to tv as suggested previously and I kept trying to hit input button on side of tv after turning tv on..didn't work but when I pushed input button before turning on tv when i turned on tv input screen was up and was able to move input to hdmi...everything works now.
Jan 04, 2009 | Vizio L32 32 in. LCD HDTV
Hooking up game system to flat screen tv
you should have several kinds of inputs options on TV .If you have a surround audio receiver .Simply go direct to receiver on any available input .If using diect to TV , use any available input on TV .More likely VIDEO 1 or 2 (game or camera input)on front or side of flat panel
Nov 29, 2007 | Televison & Video
Open Questions:
See all Sony DVDirect VRD-MC3 DVD Recorder Questions
Sony DVDirect  VRD-MC3 DVD Recorder Logo
2,041 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
