Question about Omega 9000 Juice Extractor
Overtemp switch keep tripping
Right out of the box I juiced 3/4 of one carrot and it tripped. I thought maybe something was out of balance so I dis-assembled it and re-assembled it again being careful to ensure everything was center correctly. Just starting the motor and letting it run for about 45 seconds trips the sensor. Should I just be returning this or is there some type of adjustment that I can make? Thanks for any help you can give me.
  • dianevp1 Sep 13, 2008
    I have the same probelm. Any one have any ideas?
    Champion:
  • 356 Answers
REMOVE BOTTOM AND TRY ADJUSTING
RESET BUTTON BY TWEAKING SMALL
SCREW ON BUTTON HOUSING. TURN
EITHER WAY TILL YOU HAVE LONGER
RUN TIME.
Posted on Jun 30, 2009
SOURCE:
After juicing a few carrots[some of which were cut on a slant], or several spinach clusters, the machine seems to get off balance and begins shaking violently and making a racket at which point I have to...
There's nothing wrong. These juicers do not eject the pulp and go out of balance very
easily. If you continue to have problems you may have to go for a different type of juicer.
The Hurom or Omega VRT, expensive, look good if you're really into juicing.
Mar 05, 2011 | Omega 1000 Juice Extractor
I have it for a few years and used very little, today it started to make noise and vibrate a lot, I disasembled it a few times everything seems all right but the vibrations did not stop, i am afraid of...
This is the nature of the juicer, it does not eject the pulp, and they go out of balance very
easily especially with a new blade installed. Only suggestion is juice only hard produce,
and feed it as evenly and as slowly as possible. I juice apples, carrots and celery.
Feb 17, 2011 | Acme 6001 Juice Extractor
My Omega 1000 goes off balance and makes a noise like it is going to blow up so I have to end of turning it off. It doesn't do this all the time but it is getting more frequent. This happens with any...
Yours and everyone else's. Best solution is to get a pulp ejecting type juicer.
I have a 21 year old Acme and know how to maintain and adjust it. Even
then I have vibration issues.
Sep 02, 2010 | Omega 1000 Juice Extractor
Juicer with no "muscle".
I have a brand new one from Costco and it goes through carrots very quickly.
Apr 02, 2009 | Jack Lalanne Power Juicer 250 Watts
Shuts itself off when juicing
FIRST DUMP THE FILTERS, THEY DECREASE YIELD AND MAY CAUSE MORE VIBRATION.
IF JUICER SHUTS DOWN PUSH RESET BUTTON ON BOTTOM. THIS TYPE OF JUICER DOES
NOT EJECT PULP AND REQUIRES SOME TIME TO MASTER. FEED THE STUFF SLOW AND
STEADY. WANT A GOOD JUICE? TRY 1 APPLE, 2 CARROTS, 2 CELERY AND A HALF LEMON.
IF YOU ARE REALLY BRAVE YOU CAN FINISH OFF BY SLOWLY POURING 6 OR 8 OUNCERS
OF WATER RIGHT DOWN THE CHUTE. THIS NOT ONLY DILUTES BUT LEECHES MORE JUICE
OUT OF THE PULP. JUICE SHOULD BE DILUTED AND DRANK SLOWLY.
Feb 27, 2009 | Acme 5001 Supreme Juicerator Juice...
Juicer blade stops intermittently
you are pushing too hard, this machine likes it slow.
Dec 15, 2008 | Champion 2000+ Household Juice Extractor
Looking for downloadable juice extractor book
BOOK CALLED "JUICING FOR LIFE" AT AMAZON.
TRY 2 CARROTS, 1 APPLE, 2 CELERY STALKS
AND A HALF LEMON. ALSO IF JUICER BREAKS,
GO FOR SOMETHING BETTER LIKE AN ACME.
HAVE ONE SINCE 1990.
Nov 26, 2008 | Jack Lalanne KN2047 Juicer
Pulp galore!
are you exceeding the capacity of the juicer? you will get about 2 and 1/2 large glasses of juice before the pulp fills the spinning basket. Apple peels are very tough, apples and tomatoes need to be peeled before juicing. Use the filters, the juice comes out much clearer and the juicer is easier to clean up. I so a lot of carrots, carrots are super food.
Nov 21, 2008 | Acme 6001 Juice Extractor
The reset button
IT'S THE RESET BUTTON AND THEY ARE
ADJUSTABLE. REMOVE 4 SCREWS UNDER
JUICER TO REMOVE BOTTOM. YOU CAN
GET AT THE RESET BUTTON HOUSING AND
ADJUST THE SMALL SCREW EITHER WAY.
YOU WILL HAVE TO FIGURE OUT WHICH
DIRECTION. CLOCKWISE OR COUNTER.
IT YOU GET IT WRONG IT WILL CUT OUT
MORE FREQUENTLY SO JUST GO THE
OTHER WAY.
Oct 06, 2007 | Acme 6001 Juice Extractor
Wheatgrass juicing problems
Hi, I have an Omega juicer, and I've never had this happen. I recommend that you double check to see if you have the right parts attached. It comes with two inserts, one with a small metal screen on the bottom, the other has no screen, it is solid. The solid one is for crushing and proccessing food. The one with the screen is used for juicing. Make sure you have the correct one installed. If that is not the problem, I think perhaps the grass is too dry? Maybe there isn't enough moisture in it to extract much. I really can't say, though. Try juicing something else, like carrots, and see if you can get some juice there. If all else fails, contact Omega at their website. They have terrific customer service. I've tested it already with a warranty replacement.
Aug 05, 2007 | Omega 8005 Juicer
Omega 9000 Juice Extractor Logo
301 people viewed this question
Top Omega Juicers Experts
Andrew Taylor
Andrew Taylor
eyecam
Tom Chichester
Are you an Omega Juicer Expert? Answer questions, earn points and help others
