Question about Panasonic PV-V4530 VCR
Panasonic code for PV-V4530S
Hi. I am trying to find a code for my panasonic vcr to program into my cable remote, but I cannot seem to find one that works. Does someone have a code that works? Thanks. Alicia
Have a panasonic vcr model # pv-v4022-A and need code to add on my cable remote
Posted on Dec 14, 2007
SOURCE:
Remote code for Panasonic TV/VCR combo
Use the RCA universal control programing the code 109 in vcr funtion and will work..... i try and work....
Feb 09, 2010 | Panasonic Televison & Video
I have a Panasonic TV/VCR combo my kids deleted all the channels out of it, and we don't have the remote. Tried getting codes from the cable company but didn't work. Model # PV-C1321A Model # 120V AC60Hz...
A universal remote can be programmed for your tv/vcr. Then you can access the menu to auto program your tv. Otherwise there should be a button on the front that allows you to access the menu and then auto program the unit.
Feb 18, 2009 | Panasonic PV-C1321 13 in. TV/VCR Combo
Need remote control code for Panasonic PV-DF2703
I found a newer Comcast PDF file that shows a 5 digit number for tv with vcr ( no mention of DVD) but the code worked to turn on the tv and cable box together. My problem is it won't work the volume, yet
https://www.comcast.com/MediaLibrary/1/1/Customers/Customer_Support/Digital_Cable_with_OD/Digital_Cable/remotes/Remote_M1067BX3.pdf
Dec 24, 2008 | Panasonic PV-DF2703 Triple Play 27 in....
Need remote code to control a Panasonic Omnivision VHS PV-M2079 TV/VCR combination
You need to program the VCR (which turns the sey on/off) as an aux, then program any Panasonic TV type for TV, and then set the STB button to control STB, TV and AUX and you should be set.
Jan 03, 2008 | Televison & Video
Remote code for PV-M1349
The secret is that the VCR code turns the set on/off and the TV code controlls the volume...try this:
Program the Verizon remote AUX button using the panasonic VCR codes until it turns the set on/off, program the remote for TV using the panasonic TV codes until it controls volume, then program the STB button to control all 3... STB, TV, and AUX. If you are missing any VCR or TV funtions try another respective panasonic code until all functions are available.
Panasonic VCR codes are 1089, 0062, 0189, 0252, 0643, 1062.
Panasonic TV codes are 0277, 0078, 0677, 1437.
To figure this out, I had to use the "what if none of the codes worked" section and figured I'd try the VCR codes since the TV codes would not turn it on/off.
Good Luck!
Nov 25, 2007 | Panasonic PV-M1349 Combo
Manual code to program remove for panasonic pv m2023
The remote control for Panosonic model 2023 does not work from a distance. But it works close by
Can you help?
Soundar
Nov 15, 2007 | Panasonic PV-C2061 20 in. TV/VCR Combo
Panasonic pv-v4021 VCR
Actually George, You should read the supplied Operations manual. In that you will find a chapter for using the Remote as a Universal remote, and a list of codes will be give. Check out the code for Misubishi TVs and feed that.
Mar 10, 2007 | Panasonic PV-V4021 S-VHS VCR
Panasonic PV-V4530 VCR Logo
235 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
