Question about Tatung V30DMTT 29.6 in. LCD Television
Can get reception
T.V. turns on but I only get a blue screen. I will not transmit sattelite signal or dvd through the inputs like nothing is connected. Under the channel number on the screen it says mono and that is it.
It sounds like the input signal got changed to one of the other inputs like PC, AV, SV or CV. Click your menu button and under picture click for main display and change to TV. Hope this helps scott
Posted on Jan 31, 2008
I keep getting a blue screen on my Insignia TV. Cable box still shows the channel and I can change channels but nothing on screen. No sound either. This TV is not even 3 years old yet.
A blue screen indicates no video signal, if you change the video input to a DVD player is it still a blue screen? If yes then the TV is defective. If no then some how the signal is being lost to the TV from whatever source you use for watching broadcast TV
Apr 05, 2017 | Televison & Video
Gv 42l power blue screen no signal
Yes, a cap will rarely cause this issue.
If blue screen set is ok power wise.
If blue when connections are made to rear inputs also it means it is not the tuner in the set---a good idea is to hook a DVD up, turn it on and then the set--select that input with the DVD already on--
That aside you may want to make the effort to call Vizio and see if this is a known issue or if a software upgrade is available for this issue.
If I had to "guess" it will be the main board that processes all signal inside the set.
Do some research with GOOGLE by model number "known problems" blue screen only etc.
Apr 01, 2012 | Televison & Video
Screen has gone to blue screen.....
OK A Blue screen, indicate that there is, or the TV "Thinks" there is NO SIGNAL. Please Check your Antenna Connection. Unplug the TV, for 5 mins or so. You MUST prove either the TV or it's "Signal Source" the Antenna. Try the antenna on another TV, if possible, try another antenna,on the TV, Try feeding in a signal via the EXTERNAL inputs. IF ALL Inputs are proved OK, and the TV, still will NOT display any signal, then it would appear that you may have a "Tuner" fault, or some other underlying condition, that affects the reception. In my professional opinion, in that case is to get the unit looked at by a Toshiba, recommended service center, VERY IMPORTANT to do that. Ask for a "Quote" from that service center, and go from there.
Apr 16, 2010 | Toshiba 37AV500U 37 in. LCD TV
Tv has no reception.
Make sure you have a signal to the tv, dvd player, cable or game console.
Press the input button on the remote or the control panel on the tv.
You may have to press it several times until you get a signal. Let me know if this helps and please rate this solution.  Lone99star
Jan 25, 2009 | ViewSonic 27 in. LCD TV
Hitachi 26LD6600 no signal coming up
You have to switch the Television to the correct input line. This can be done by pressing an Input, or AV of function button on the television remote control.
Nov 08, 2008 | Hitachi 26LD6600 26 in. HD-Ready LCD...
Durabrand TV/DVD dct1481
The blue screen is fairly common and is displayed when inadequate signal is present.
In other words, 'no reception.'
The weak BBC1 signal is kind of a confirmation of your poor signal strength.
Aug 20, 2008 | Durabrand DWT1905 TV
Toshiba Model 42HM66 DLP Projection TV
I strongly doubt it's the lamp assy since you can actually see the blue screen. If the lamp failed, you would not see anything on the screen. This blue screen indicates to me that either the tuner is no longer decoding the signal, in improper input has been selected (ie: input 1 is selected while actual signal is on composite 1), or something of that nature. If you are getting audio then the input is selected properly but the video decoder has failed.
If your cable signal is going through a VCR or DVD, disconnect it from there and go directly to the TV (ie: bypass the VCR/DVD). If your picture comes back, there's some kind of problem with your VCR/DVD player.
If you have multiple inputs, try connecting an input signal to another input (ie: video 1, or aux from a dvd player) and see if you get a picture there. If you do get a picture, the whatever input you're currently using has malfunctioned.
Mar 08, 2008 | Televison & Video
Only see a blue screen ...
Hi, The bluescreen is an indicator of "lack or absence of a video signal". In TV mode this would only come on if your reception quality is so poor that the TV "thinks" there is more interference/noise than intelligent video signal nd therefore mutes the video. In all other modes, (S Video, A/V Video etc), again, this muting action will result in the bluescreen if the TV "thinks" it is not receiving any video input. To try and fix this would either be: 1. Check and verify that you have a video signal coming into the TV by trying your video source (DVD, cable box) into another TV unit; or 2. Check and verify that your connectors at the back of the TV and the source are properly connected and are snug/fitted properly. If both fails, it is possible that you have component failure inside the TV and that would require the services of a qualified TV professional. Hope this be of help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 15, 2007 | Polaroid FLM-1517 15 in. LCD Television
Tatung V30DMTT 29.6 in. LCD Television Logo
80 people viewed this question
Top Tatung Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Tatung Televison and Video Expert? Answer questions, earn points and help others
