Question about E-Machines eMachines Monitor E15T4
No monitor power, no LED, repeating sound from monitor
This is an eMachines e15t4 LCD monitor, after around one year (with no damaging or harsh treatment) stopped powering on. The power cable is correctly plugged into the monitor and the wall, but it does not power on, no LED light at all. It does repeat a faint "click" or "twinge" sound every second or two like it's trying to power on, but nothing happens. Can you help?
Dot in the center of my lcd modnitor
You may have a bad pixel, unplug and disconnect video cable, now press and hold power for 2 minutes. Now plug everything back in place and start monitor, is dot is gone ? if yes! there was a static charge that caused the dot to appear, but if there was no change! you have a dead pixel no remedy.
Apr 05, 2012 | E-Machines eMachines Monitor E15T4
There is no sound coming from my speakers or when I plug in headphones I have Emachines computer
first check for your head phone. Try to test it to other gadgets. if it is found o.k then if it is o.k, maybe the female connector ( the connector from the LCD monitor) has a defective contact. try to replace the female port of your LCD ask for a technical help. Hope this may help you
Jul 27, 2011 | E-Machines eMachines Monitor E15T4
Emachine Monitor comes on a few minutes and cuts back off
I have the same problem and I think its the circuit board on the power on button and blue led. I unplug the board when the monitor is on and then the monitor stays on and works OK.
It don't make any sence it is only 3 parts switch led connector
anybody else run into the problem
Mar 29, 2009 | E-Machines eMachines Monitor E15T4
Monitor works in dos starup, but fails in Vista startup mode.
Sounds like windows resolution or refresh rate is too high for the 15" monitor. Try starting in safe mode and setting the resolution below 1024 X 768 and refresh at 60. Restart.
Mike
Feb 16, 2009 | E-Machines eMachines Monitor E15T4
Emcahine Monitor sound is low
check the speak rail, the emachine speakers need a amplifier, there should have a power supply plug, that you need to plug it in.
if not, call up the place you brought the machine and ask them, where is the amplifier plug.
Dec 10, 2008 | E-Machines eMachines Monitor E15T4
Emachine monitor E17T4 does not respond when the front switch is depressed
Have you found a solution yet? I just posted the same problem with my E15T4.
ken
[email protected]
Dec 18, 2007 | E-Machines eMachines Monitor E15T4
E-Machines eMachines Monitor E15T4 Logo
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
