Question about Sony PlayStation 2 (PS2) Console
Please help me.
Hey i need some help. i plugged my ps2 in to the tv and power outlet. when i hit the power button it just goes to a blank screen. wat am i checking it for....there doesnt seem to be anything wrong with the audiovideo cable. i did get it to work once. i must have hit the reset button as i was putting it back on the tv, and it stopped working. where u plug the cable into the ps2, the is a little black cylinder thing, it is loose...if it is a mother board fraud do i have to replace it?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 78 Answers
The input AC socket of your PS2 is loose for which you can replace only this socket if some dry solder is not there. Note: This AC Socket is totally seperate from Motherboard.
Posted on Sep 07, 2007
SOURCE:
I hit the source button, and now my screen is blank with hdm1 in corner
No problem. Keep pushing the "source" button until it goes back to "tuner". You should see "component", "s-video",etc.. also. These are the various "sources" that can be plugged into your TV. To watch regualr TV, you need "tuner"...
Good Luck.
Apr 21, 2014 | Emerson Televison & Video
How can I hook up my ps2 to my Philips Magnavox TV?
First, you'll need a PS2 composite AV cable (Red, yellow, and white cable). If you don't have one, you can get one on Amazon for pretty cheap. (http://www.amazon.com/PlayStation-2-Composite-AV-Cable-PlayStation2/dp/B00004U8QX)
Next, plug the flat end of this cord into your PS2, and the red, yellow, and white plugs into their corresponding outlets on the TV. There may only be yellow and white outlets on your TV (in which case they will be on the front). Then, turn both the TV and the PS2 on and see if its working!
If you don't have red, yellow and white outlets on your TV, you will need an RF adapter for the PS2. (like this one on eBay (http://www.ebay.com/itm/RF-Unit-Adapter-by-Komodo-NEW-for-Playstation-PS2-PS3-/390624177322)
Hope that helps.
Jul 16, 2013 | Philips Televison & Video
I need the code to my tv,viewsonic,i have a power plus universal remote control.ref number 4028 can any one help me out please
Hey it's easier to just do it manually that try to look all over the world for a number. On your remote- hold the set code button until it stays on then hit the T. V button once. The light should still be steady. Now hit the power button repeatedly. You can also hit the Chanel +\- the pwr. Bttn is more accurate I think. But as soon as your tv shuts off hit enter. Be sure not to pwr. Smash the pwr. Bttn
Feb 06, 2013 | Televison & Video
We plugged in a small electric heater in the room with our Vizio plasma tv. All lights everything went out. I hit the breaker and everything came back on except the TV. No power at all. NO money must...
Hey Juuuudd..lol...not beatles...
Plug your tv into another outlet some where in another room and see if it works.
Check your tv owners manual and see if it has a "reset" button.
Usually, if this happens it because of the electric heater.
They tend to pull alot of power and blow power to your fuse box.
IE...if you have a 15 amp breaker and run 20 amps per say through it
it blows....or shuts off the power.....this happens alot at work with people
running heaters, lights etc.
if your problem persists let me know...good luck.
PS....don't run that heater...
Jan 26, 2011 | Televison & Video
Alba TV LCD4288DF 1080P Sound but no picture. On switching on get a very brief flash of the picture then screen goes blank, tried on all inputs with same results. It did sort its self out for a while but...
1. Check to see if the TV power outlet has power. Plug a lamp or something small into outlet to test for power. If there is no power in outlet, check your circuit breakers or power fuses.
2. Check to see if you have pressed the power button on the TV or on the remote controls. Check to ensure batteries are placed in remote correctly.
3. Check the setting of the picture brightness or contrast.
4. Check to ensure you have proper cable connections from your source going into your TV.
5. Check the volume settings on the TV.
6. Check to ensure the mute button is not pressed on.
Jan 20, 2011 | Televison & Video
While I am watching TV on my Sony kdf-60xs955, the screen goes blank and the green light just flashes. Sometimes it comes back on and sometimes not. I hit the power button and the red light flashes 5...
Hi Friend,
Please folliow the below steps one by one
Step 1: Turn on the TV
Step 2: Hold the ON/OFF Button for 10 to 20 Secs
Step 3:Without taking the hand from the ON/OFF button unplug the power cable connected to the wall outlet from the TV
Step 4:Without taking the hand from the ON/OFF button put the power cable back to the outlet
Step 5:Now take the hand from the ON/OFF Button and try to turn it ON again and check
Check by changing the Power cable to any other wall outlet in your home
Even after that you are facing the same issue please check with the Display Card in the TV,
If you have any Clarification please feel free to contact us
Regards,
Ayyasam
Apr 03, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
I have a Sharp 32 inch 720p tv, power works, no other buttons do
Unplug TV set from the outlet, wait 30 seconds, plug it back in, select right input with your remote if you using cable box or Punch the channel that you want to watch if you have cable service connected directly to the TV.
Nov 05, 2009 | Sharp LC-32SB23U 32 in. LCD TV
My slim playstation 2 is not working need answer quick
Haha i understand your distress :) if your slim ps2 is not turning on, first check and make sure that all your wires and stuff are all plugged in to EVERYTHING. also, make sure your outlet works too. corroded electrical outlets wont work. Also, make sure your PS2 cooler is not blocked in any sort of way. if you need any more issues, just ask :) ~~RJ~~
Sep 19, 2009 | Sony PlayStation 2 (PS2) Console
G25 steering wheel not working
feeling pretty silly. hadn't plugged in the power supply. usb was enough to drive the buttons and the pedals but not the steering. plugged in the power and hey presto, its all good.
perhaps the gt4 prob is indeed a power supply issue too - might be the place to start...
mine is a 24Vdc at 1.75A
hope it helps...
Nov 15, 2008 | Video Game Consoles & Games
Wont work
Check your AudioVideo cable otherwise it is internal motherboard fault.
Sep 03, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
