Question about Neff U1721 Double circotherm Electric Oven
Neff single oven
Hi our neff single oven does not work on the fan forced settings (ie light on and makes fan noise but no heat) but it heats and works perfectly well on the other seatings such as grill etc that dont use the fans, any ideas? its is about 2.5 years old so just out of warranty Helen
  • 1 more comment
  • Anonymous Mar 16, 2014
    Oven not heating, everything else works ie. Grill, Fan, Light
    Oven not heating, everything else works. ie. Grill, Fan, Light
  • Anonymous Mar 17, 2014
    The oven works OK but I don't understand how to make the grill alone work to make toast
    Champion:
  • 249 Answers
Fan heating heating element gone replace it ;Ire close bye
Posted on Nov 28, 2007
SOURCE:
Tip
Common heating faults with Neff B1644 single oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Neff fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Neff B1644 Electric Single Oven
Replace fan motor in an electric fan oven
1, If the fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
Jan 13, 2010 | Neff B1421 Electric Single Oven
Oven not heating up! Fan works. Grill works OK. Don't know what model it is? It's stainless with black hideaway buttons. It's a built-in Neff single oven. We had just roasted a duck, everything was...
Hi, The main problem I find with this fault is the fan element has blown. This usually cannot be seen without taking the fan cover off inside the oven. Thanks.
Jun 15, 2009 | Neff B1641 Single circotherm super...
Tip
Common heating faults with Neff B1476 single oven
on Jan 19, 2010 | Neff B1476 Pyrolytic Stainless Steel...
Tip
Common heating faults with Neff B1691 single oven
on Jan 19, 2010 | Neff B1691 Single circotherm super...
Tip
Common heating faults with Neff B1451 single oven
on Jan 19, 2010 | Neff B1451 Single circotherm plus Electric...
Tip
Common heating faults with Neff B1432 single oven
on Jan 19, 2010 | Neff B1432 Single circotherm plus Electric...
Tip
Common heating faults with Neff B1428 single oven
on Jan 19, 2010 | Neff B1428 Nostalgic Single circotherm...
Tip
Common heating faults with Neff B1641 Single electric oven
on Jan 19, 2010 | Neff B1641 Single circotherm super...
Tip
Common heating faults with Neff B1421 Electric Single Oven
on Jan 19, 2010 | Neff B1421 Electric Single Oven
Neff U1721 Double circotherm Electric Oven Logo
591 people viewed this question
Top Neff Ovens Experts
Paul Carew
xxxxxx xxx
Domenico Grillo
Are you a Neff Oven Expert? Answer questions, earn points and help others
