Question about Sharp AF-S120FX Air Conditioner
Sharp Air Conditioner
I have a Sharp window mount air conditioner. It reads "E1" after the power goes out. I've had to go through a certain procedure involving unplugging for a period of time and then plugging it back in and pushing 2 buttons at the same time... I just don't remember the procedure. Can you find out for me?
  • 4 more comments
  • sexeyeyezs Jun 08, 2008
    I have the same problem with the E1 code and don't remember the two buttons I have to press. I' cleaned the vent and unplugged it for a few minuets and reset it and it will run for about 5-10 min and then cut off
  • Anonymous Jun 09, 2008
    power went out air conditioner reads E1 wont go on
  • Anonymous Jun 11, 2008
    i HAVE THE SAME E1 PROBLEM DON'T KNOW THE BUTTONS TO PRESS.I HAVE DONE THE SAME THING AS OTHERPEOPLE
  • kamommy Jul 03, 2008
    I have a Sharp Window Air Conditioner and it keeps reading " E1". We had a lightning storm last night and the power went off and I think this is why I am having the problem. I've tried un-plugging the unit and then plugging it back in and it will only run for about 10 mintues then shuts off again. I need to know what to do to fix the problem?
  • znmatrix Aug 16, 2008
    after a while it shuts off and flashes e1
  • Anonymous Sep 26, 2008
    i tried the 5 second hold the button trick and after ten more minutes of operation the unit stops and E1 dispalys (again and again). So, because of this stupid logic problem I will have to trash this unit. If I could learn to wake up every 10 minutes to run the reset procedure the unit would be just great. I can't help thinking there should be a control wire I could cut to disable this sensor. This is a Sharp AF-S85 unit but the problem is the same.
This is from Sharp's website...apparently an addendum to the instruction booklet. When you get E1:
Unplug. Press and keep pressing the On/Off button on the unit. Plug unit back in. Wait until unit beeps (about 5 seconds) then release On/Off button. Unplug unit. Plug unit back in.
You're good to go.
Posted on Jun 28, 2008
I tried it. Didn't work. Tried again several different ways and then kicked the AC out the window. I wish I lived on a higher floor so it could have dropped further.
Posted on Aug 19, 2008
Http://www.fixya.com/support/p102574-sharp_af_s120fx_air_conditioner/manual-5280
Posted on Sep 04, 2007
SOURCE:
What does E1 code indicate?
Your Air Conditioner Displays E1 (E2, or E3) In The Display ...
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsJul 8, 2010 - Home > Operation? > Your Air Conditioner Displays E1 (E2, or E3) In The Display Panel And Won't Turn On Share on Google+ Share on ...
How To Clear Sharp Air Conditioner E1 "Clean Filter" Error ...
sci.tech-archive.net > Archive > sci.electronics.repair > 2005-08
Aug 5, 2005 - Owners of Sharp air conditioner models ... the error code E1 will appear... following procedure to clear the nefarious E1 indication, and obtain
Oct 27, 2015 | Heating & Cooling
What does the code E1 mean on my sharp a/c
It is a clean filter message. make sure filter is cleaned and reset as follows:
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
Sep 14, 2014 | Sharp AF-S120FX Air Conditioner
We have an E1 code on our Sharp energy star model AF-S100FX air conditioner and the unit will shut off. What does the E1 code mean?
Display Codes:
E1-Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Jul 22, 2011 | Sharp AF-S100FX Comfort Touch Air...
Ac shuts off E1 error message
E1 Error Code -->> Clean Filter
Owners of Sharp air conditioner models AF-S60FX, AF-S80FX, AF-S85FX, and AF-R80FX may experience the following (highly annoying) issue. After 720 hours of fan operation, the error code E1 will appear on the seven segment LED temperature display. This error code is intended as a reminder for the user to clean the air filter. However, because the procedure outlined in the user manual does not clear this error code as indicated, and the appliance has a nonvolatile memory that cannot be reset by simply unplugging it, the user of the appliance will become mightily frustrated, standing in potentially sweltering heat watching the appliance repeatedly shut down in the midst of operation with the "E1" display flashing.
Believe it or not, that is what it does: if you unplug it to remove the "E1" code from the display, and plug it back in and re-start it, it will simply run for anywhere from a few minutes to a few hours, and then merrily shut down again with the same flashing "E1" code.
Many people at this point, having put the manual under the canary or some such, will simply return the unit and never buy another Sharp air conditioner. But for the tech-savvy and search-adept, I offer the following procedure to clear the nefarious E1 indication, and obtain another 720 hours of cooling bliss:
1. Power down the air conditioner using the "power" button on the front panel.
3. Hold the front panel "power" button down and plug the air conditioner in. Continue to hold the power button down as the machine goes through a brief test sequence (fan & compressor each come on briefly, etc). There is a "beep" sound at the end of the test sequence, and the machine will be off. At this point, you can release the power button.
6. Congratulations! You should now be able to operate the air conditioner normally for another 720 hours, but only if you followed the instructions above exactly.
If you doubt the veracity of this information, or it does not work as expected, you can get it directly from the source at: 1-800-237-4277 (Sharp customer service line). You'll need to call between 7 AM and 7 PM US Central time, and have your model number and serial number ready.
May 28, 2011 | Sharp AF-S120FX Air Conditioner
E1 ERRORE COMES IN M Y AC WHICH REASONS
So you will come home to a hot bedroom, living room, etc. unexpectedly,
and you will NOT be amused, as I was not.
panel.
button.
the instructions above EXACTLY.
How To Clear Sharp Air Conditioner E1 "Clean Filter" Error Code
http://sci.tech-archive.net/Archive/sci.electronics.repair/2005-08/msg00472.html
Mar 01, 2011 | Heating & Cooling
How do I reset the e1 on the A/C
I have a sharp and I don't know what model you have but you may check the manufacturers web site for a instruction book
but on my unit you have to do the following
panel.
button.
after following this procedure to clear the nefarious E1 indication, you should obtain
Jul 20, 2009 | Sharp AFR120FX Air Conditioner
Air conditioner is flashing e1
hi..
panel.
button.
thank u
rate me
Jul 18, 2009 | Sharp Heating & Cooling
ARF120
If you have the error code E1 on the LED temperature display. This error code is intended as a reminder for the user to clean the air filter every 720 hours . I have a sharp and I don't know what model you have but you may check the manufacturers web site for a instruction book but on my unit you have to do the following
panel.
button.
Jul 13, 2008 | Sharp AFR120FX Air Conditioner
Sharp AF-S120FX Air Conditioner Logo
518 people viewed this question
Top Sharp Heating & Cooling Experts
Ekse
Perry Mellott
Perry Mellott
Colin Stickland
Colin Stickland
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
