Toshiba color tv 3409xh
Switch on but no display
Toshiba 42HP66 42 in. LCD Television Color Problem
se cablesdry joints or loooossibly the ribbon cables check for
Sep 19, 2012 | Toshiba 42HP66 42 in. LCD Television
My tv will only display color screens when on
tried with re seat the LVDS cable at the t-com board, it was attached covered with metal shield which transfer signal to the panel display.
Sep 02, 2012 | Toshiba 15LV505 LCD TV
Why won't my toshiba tv model 43a10 display color
It is by the model number a rear projection tube set--Look to see first if when a DVD etc is played you have color or not (via audio video jacks on rear of set)
If you do the set's color circuit is ok.
If using a box unplug it and wait--plug it back and let the box boot up.
If none of this helps the and the set has no color on all inputs you have some problem in the color or chroma circuit in this set---it is very rare for this to be a circuit problem.
May 28, 2012 | Toshiba Televison & Video
Connected my laptop to Toshiba 27AF45 tv with VGA cable and RGB but it does not display properly - shows color and rolling black lines. Any suggestions?
Hello
VGA [Video Graphics Arrey] and RGB [Red-Green-Blue] sockets are not compactable, and will not get a proper display. You must have a converter [VGA=>RGB] is needed in between. Ok
Oct 19, 2010 | Toshiba 27AF45 27" TV
Toshiba 32A35 Color TV Flickers & Scrolls w/ light colored images
My Toshiba 27" tv has the exact same problem any solutions out there or is it time to toss the tv?
May 24, 2010 | Toshiba MV19H1 Combo
Is this an hdtv?
No. Toshiba once again sets the standards for color television excitement and performance. From the largest projection TVs, to compact portables, you can count on Toshiba to dazzle you with the utmost in picture quality, audio enhancements, and easy-to-use convenience. Innovation, advanced technology, and convenience are built into each Toshiba color television. Toshiba brings you technology that is sure to **** the senses.??Toshiba's 27A51 color television offers a ColorStream component-video input and stereo MTS sound with dbx noise reduction. For added convenience, this TV includes a front AV input (great for a camcorder or game console), glow-in-the-dark universal remote, and trilingual color onscreen display. With the built-in V-chip control, you make sure young eyes don't take in the wrong TV shows. Hope this helps. Let me know if I can help you with anything else. JimmyC
Oct 03, 2009 | Toshiba 27A51 27" TV
No color picture on Toshiba CF36G40
You need to go to the menu screen where the contrass, color etc are located. Scroll each option and one of them will add the color, one of them is probably at 0 so you need to ensure that it's added
Feb 15, 2009 | Toshiba CF36G40 36" TV
Green line on each side of the plasma display.
Anybody knows how to reapair about vertical color- stripped lines appeared on screens and some trace of greenish images exist after each images changing, my TV is Toshiba Plasma Color 42HP83, I appreciate , thanks
Jun 05, 2008 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
