Question about Kenwood ProTalk XLS TK-3131 (15 Channels) 2-Way Radio
Keylock how do i get the keylock off
You are a God! I have been trying to find this out for and hour on the internet as I lost the manual. Thanks a million! The light key also doubles as the lock key.
Posted on May 04, 2009
    Brigadier General:
  • 6,966 Answers
Hin, On most new models of Kenwood two-way radios, the user can lock the MENU and up/down buttons. To lock/unlock, press on the menu button (a second or 2) until you hear a beep or till the lock icon in the display appear/disappear. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Posted on Sep 04, 2007
6ya staff
SOURCE:
I have a Fisher Paykel 605 double DD. I have an F2 error message. There was a frozen rotor, likely from disuse over the winter. I replaced the rotor and it still stops and shows the F2 display. There
Not sure if you have fixed the F2 problem yet. The rotor cavity may look clean but sometimes there is a piece of bone or seed stuck inside the channel connecting rotor cavity with pump sump. Take the rotor out and the drain filter out. Take a rigid thin wire and run it inside the channel connecting the two.
Also get some white vinegar and with a tooth brush rub it inside the rotor cavity to ensure all dirt is removed. The rotor speed sensing is done by the hall sensor sitting underneath the cavity. It is not visible from top. The sensor could be reading incorrectly. IF still no luck then Run in diagnostic mode - (but make sure you do not try any other function than what is mentioned here otherwise you could damage dishwasher).
DishDrawer Diagnostics can
only be entered in Power Off mode, ie. When there is no display on the LCD or the
badge LED's are off. Diagnostics is entered by holding the
Keylock and Start/Pause buttons simultaneously for 5
seconds. Ensure that
Keylock is pushed first.
All LED's and LCD segments (except keylock) are illuminated. Press Power button and display shows HO in red background. Press Start/ Pause. You are now in hardware diagnostic mode. Open drawer so that you can see inside. Press Start/ Pause a few times until FU shows on display. At this point press Keylock and water should flow in. Press Keylock to turn inlet valve off after water is collected under the wash arm (don't cover wash arm). Press Start/ Pause again and P1 will display. Press Keylock to turn rotor motor on and water will swish around. Press Keylock to turn motor off within a few seconds otherwise flooding could occur. Next press Start/ Pause once so P2 displays. Press Keylock to run rotor again but this time it will pump out. Let it run until the water is pumped out. Press Keylock to stop pump. This should test the rotor in both forward and reverse direction.
PRESS POWER BUTTON ANYTIME TO EXIT DIAGNOSTIC
If the hardware test worked ok then turn mains power to dishwasher off and on and start normal wash cycle. If there is still an F2 problem then hall sensor is faulty and needs replacement. Not easy to do and best left to technicians. By the way each dishdrawer has separate controller - so one drawer could be working fine and the other not.
May 10, 2014 | Fisher and Paykel Dishwashers
I have a Palm Z222. I cannot deactivate the keylock, which makes it impossible for me to use the Palm. Regards, Renate
spacer.gif spacer.gif How to preserve battery charge by preventing your Palm handheld from accidentally turning on via keylock Your Palm handheld is equipped with the Keylock Activation feature to prevent the device from accidentally being turned on (while in your pocket for example) and thereby preserving the battery charge. To access the Keylock Activation settings, follow these steps:
  1. Turn on your Palm handheld
  2. Tap on the Preferences icon
  3. Tap on Keylock located in the General section
  4. Tap on either Automatic or Manual to activate the Keylock functions
Sep 01, 2008 | Computers & Internet
My Uniden walkie talkie keeps saying L very time I push a button
You've set the keylock feature on your walkie talkie. From the Uniden manual...
KEYLOCK
ON/OFF Press and hold the call/lock key until the "L" appears. After 1 second, the LCD will return to the channel display. To exit Keylock on mode, press and hold call/lock again. Note: While in keylock on mode, it will still receive transmissions.
Feb 10, 2014 | Uniden GMR-1035-2 2-Way Radio
Uniden walkie talkie says L every time I push a button
KEYLOCK
Feb 10, 2014 | Uniden Radio Communications
Security code
Mostly all nokia phones have a full phone lock along with a keylock.
To enter a security lock, you need to activate it first.
for this,
go to your settings-> phone settings and scroll down to security keyguard. Then switch it on in case it is off.
Note: in case your phone locks at this moment, the default keylock is 12345 to unlock
After this you need to put in a new password to the security keylock
For this, Go to Settings-->Access codes--> Change Security code
Enter the default keylock i.e. 12345 . Then enter a new password which you will remember. Verify it by entering it again.
After you have done this, go back to settings->phone->Automatic Keyguard
Switch it on and enter the time for the keylock ( can be 5,10 or 15seconds depending on your choice)
After all this is done, you are good to go. Just remember your passcode.
Apr 26, 2013 | Nokia C3 Cell Phone
Key stuck in ignition pontiac sunfire
ignition keylock cylinder broke. you have to remove ignition switch and remove keylock cylinder and replace ignition switch keylock cylinder with new ignition key then you have to reset theft security system which dealership has to fix.
Jan 27, 2013 | 1999 Pontiac Sunfire
Unlock Sharp XR-10X-L Notevision Proj. says keylock function on
According to pg. 45 in the owner's manual, you turn Keylock function ON by holding down the ENTER key on the projector for about 5 seconds while the projector is being turned on.
To take the Keylock off-- Hold down the ENTER key on the projector for about 5 seconds. If the projector is in standby mode, you can release the keylock by holding down ENTER and STANDBY/ON keys simultaneously for about 5 seconds.
Apr 27, 2010 | Sharp XR-11XC DLP Projector
How to keylock the phone
Press the power on button and then select KeyLock.
Its a stupid way of having to do it though...
Feb 23, 2008 | HTC MTeoR Smartphone
How do you turn off keylock
Power off your display monitor then hold down the down arrow key on the monitor at the same time you power on the monitor. This should unlock the monitor keylock [email protected]
Mar 20, 2007 | Kogi L7CH Monitor
Keylock
Hi, The Hw6500 dont have any keylock/display lock. thats why we released it with the hard plastic cover over the display, so you can have it against your ear without pressing the display all the time.
Sep 08, 2005 | HP iPAQ hw6500 Pocket PC
Kenwood ProTalk XLS TK-3131 (15 Channels) 2-Way Radio Logo
367 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
Jason
Jaime Hernandez
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
