Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS25KSWA I bought this side by side refrigerator only 2 days ago, and while the freezer side works fine, the refrigerator side will only cool to 50.
You should also check for blockage in the drain hole of freezer by pouring water into it. If no water, use hairdryer and hot water to unclog.
Posted on Dec 31, 2007
  • 291 Answers
Check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Posted on Sep 04, 2007
SOURCE:
Whirlpool Gold GB2SHTXTS00, I bought it in 2007, but 3 days ago, the cooling suddenly is not working, but freezer and lights are fine
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 06, 2011 | Whirlpool Gold Series GB2SHTXTS (219 cu...
Refrigerator stopped cooling 2 days ago. Freezer works fine. What is broken? Appliance is four years old. Replaced compressor almost exactly 1 year ago.
Check the fan in the freezer and be sure it's working, isn't blocked by product or isn't clogged with ice. If this fan isn't working the refrigerator section won't cool properly.
Jul 18, 2010 | Maytag Refrigerators
My refrigerator stopped cooling and my freezer stopped freezing but the freezer is still cooling
Same thing with our GE Eterna Series - off and on for the last two weeks. Took back panel off, looked around, vacuumed dust build up off of the fan blades, etc.; everything worked fine for five good days. Then frig went out stopped cooling. Off and on for the last week. Unplugging it works for a day then back to not freezing and or colling.
Jul 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Side by side fridge freezer warm on upper levels
the cold coil is in the freezer side at the bottom . the fan moves the air over coil . ck that your fan in freezer is working . mm
Apr 19, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Hola: my GE PSC25PSTBSS sometimes is not cooling in the fridge side. some days it is at ~50F and other days at 37F. one year ago it was not cooling anything and GE technician replaced the fan unit from the...
edtorres: if the freezer side and ice maker are working fine then the problem may be the damper that allows cooling into the refrigerator side is having trouble opening or the controls to the damper are defective.
Mar 06, 2010 | Refrigerators
My refrigerator is not cooling the freezer works
We have this refrigerator and what you described is a chronic problem. (I hate this refrigerator!) Our repairman got tired of hearing from us so often and told us how to fix it ourselves! Take everything out of the freezer side and unplug it. Remove the white back part inside the freezer part. There are 2 screws at the top. The inside will be full of ice. Melt the ice with warm water. It makes a huge mess so get lots of towels. Once all the ice is melted you can put everything back and plug it in. It may take a day for it to get really cool again. My long term advice is to get a new refrigerator...
Jan 05, 2010 | GE Refrigerators
GE Monogram side by side freezer and refrigerator
HI thanks for your question. the problem could have been, a defrost timer, stuck on defrost. or a failing thermostat. keep a close eye on it, if it stops again. get in touch and we fix the problem. thanks
Jul 17, 2008 | GE Monogram ZISx420DR 42-inch Side by Side...
Refrigerator will not get cold, but freezer works
Do you know if the compressor in the back is running? If you can check that out get back to me and we can go from there. Most times if the fan in the freezer is running the defrost timer is ok.
Jul 09, 2007 | Amana ARSE66MB Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
245 people viewed this question
Top Refrigerators Experts
Brad Goodale
R.A. Ellis
R.A. Ellis
Darrin P. De May
