Question about Gigabyte GA-M55SLI-S4 Motherboard
Problems with Mobo? Or CPU?
I took my computer home from college for a little bit and it worked fine before I left and while I was home. When I came back I plugged in the power and nothing happened. This has happened before but after a few days of resting it started right up. But this time nothing has happened a week later. The light on the LAN connection briefly lights up and then dies, and sometimes it will turn on, run for 1 second and shut off. I got a new PS and hooked it all up and still nothing. So it has to be my MoBo or my CPU. Both are fairly new ( 2 months ) My CPU is an AM2 64 4200+ . This was all installed professionally so I don't know what my problem is.
    Novelist:
    Champion:
  • 231 Answers
Hi, have you checked your RAM chips? Could be they have worked loose while traveling, make sure they are firmly seated, otherwise you may have to take it to a technician. Goodluck mistyman
Posted on Sep 04, 2007
How do I switch/upgrade my motherboard from a 32bit to a 64bit please
Having a 32-bit or 64-bit operating system mainly depends upon the operating system that is loaded on your primary hard drive (generally drive C:). However, your motherboard's components, i.e., processor and amount of system RAM, will be a major factor in determining whether you can only run a 32-bit operating system, or upgrade to a 64-bit system.
Sep 22, 2014 | Computers & Internet
2004 chevy trailblazer electrical problems
Get rid of it, Let somebody allse deal with it.
Oct 23, 2012 | 2004 Chevrolet TrailBlazer
Dell Dimension 3000, splashed liquid from canned air, mobo fried?
The spray on the MB should not be a problem - unless it was plugged in when you did it. Yes, you should be able to put in a new Dell motherboard. As long as the processor is of the same class, the Dell license should work fine. However, you may need to download new drivers for the machine to run.
If you really want to check the power supply, I would suggest you buy a tester. They are fairly cheap: $10-50. You want to be sure that your board is getting the right power at the right places. 12 V to the fan is fine. However, 3.3 v or 1.5 v?
It sounds like you have done a fairly good test of the motherboard. I've definitely seen bad Dell motherboards with the light on with/without a bad power supply.
If you have another case (an ATX), I would buy an Asus or other motherboard and put your equipment in it. The cost of a Dell motherboard is excessive. Of course, you will have license problems with XP.
May 22, 2010 | Dell (E210882) Motherboard
I have problems with a new PC build. When computer powers on the screen stays blank. There is no prompt. Case, psupply, and cpu fan all work fine. DVD drive opens and closes. There is no beeps but not sure...
take the battery on the motherboard out. the little disk battery. leave it out for about five minutes. that should reset the bios and cmos to default. also , make sure you plug your monitor into it a default monitor slots on your computer, not to the VGA card if you have one.
Mar 21, 2010 | MSI K9VGM-V Motherboard
My PC sometimes hangs on booting with red dotted lines only shown on dispaly, and sometimes after logging into windows with cloor bar code lines.always it hangs up.chasis fans are nto working.recently took...
Seems to me that your computer has an overheating problem, and shutsdown as a selfprotecting meassure.
Probably the heatsink is not well attached to the CPU, or the heat release compound on the CPU is fresh.
Make sure they are ok, and your problems will go away.
PLease don't forget to rate this answer if it helps
Sep 22, 2009 | Acer TravelMate 2300 Notebook
Cpu can not boot
I don't think it is a ram issue.Try this when the computer is booting,hit the F8 key. That boots you into safe mode where only the most necessary drivers and programs load. If it loads in safe mode that is good. A little bit of daignostic work can locate the problem after that.
Dec 03, 2008 | Computers & Internet
No signal
try taking out a gig of ram and then start computer.
Jul 03, 2008 | ASUS P5N-E SLI Motherboard
No boot, continuous Beep
I would take the CPU back out. Remove the excess thermal compound, you should only use a very thin layer. Make sure the CPU is oriented and seated properly.
Jun 06, 2008 | ASUS AI Lifestyle P5N32-E SLI...
Emachines C2825 problem
If you know the motherboard is bad as well, you have two options. You can salvage the existing case and parts, and replace the motherboard and PSU. Plan on spending around $100-150 for both together. This assumes the CPU and RAM are undamaged. The second option is to buy a different "bare-bones" system, and transplant the parts into that one (CD/DVD drive and Hard Drive). Unless you have an exact replacement for the motherboard, you'll probably need to reinstall Windows. The easiest way around this is to install Windows onto a new hard drive, and attach your old hard drive as a "slave" or "secondary". These two options are centered around off-the-shelf parts, rather than buying a "brand X" computer. If you prefer "brand X", which includes an 800 # you can call, look at Dell. eMachines and Dell both produce low-cost low-quality systems, but Dell is better at it. For ideas on parts, look at an online retailer like NewEgg. For compatability, this is mostly a matter of using a tape measure and/or counting pins; they have low prices because they aren't there to hold your hand; if you would feel more comfortable with some hand-holding, which is fine, buy a new "brand X" computer. Lastly, keep in mind, the difference between a $500 computer and a $1500 computer is more than profit margin. If they don't say exactly what a part is, it's whatever was cheapest at the time. A $500 computer may be all you need, but it will have problems like this; whether that's best for you, is for you to decide.
Oct 01, 2007 | Intel D845GVSR Motherboard
Gigabyte GA-M55SLI-S4 Motherboard Logo
Top Gigabyte Computers & Internet Experts
Alun Cox
Computer Links
steyr1
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
