Question about Casio KL 750 Thermal Printer
Lost directions I lost the instruction sheet on how to install a new ink tape. It keeps wraping itself around wheel before cutter
  • Raymondk005 Oct 09, 2008
    lost instructions for casio kl750 label printer cant load caset tape
How do i load the caset on casio kl- 750 ez-label printer
Posted on Oct 09, 2008
    President:
  • 1,114 Answers
You can download the manual from the link below: http://ftp.casio.co.jp/pub/world_manual/ds/en/KL_750_E.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Sep 04, 2007
SOURCE:
How do I insert the cartridges in my printer HP Envy 4512
HP has excellent support pages. The following link offers illustrations plus a video which will cover cartridge replacement for this model as well as a number of others in the HP line.
https://support.hp.com/us-en/document/c04708949
Jun 16, 2018 | HP Office Equipment & Supplies
To install new ink no instructions about what to remove before installing?
You pull off the tape that keeps the ink form leaking before you install the cartridge or it will not print.
Jan 16, 2016 | HP No 61 Black Ink Cartridge
1600mx wont run in forward over load light comes on
Most common reason is that there is paper would around the cutters, imposing an additional load on the machine. You will need to access the cutter assembly (disconnect all power) and manually remove all of the paper that has impinged between the cutters.
If you have run any labels or paper with gummed strips through the cutters, you may wish to consider throwing this one away and buying new. (In all fairness, it "can" be cleaned, but it is going to be a real dickens of a job to do).
If you decide to keep your shredder and clean the cutter assembly, remember to oil it on a regular basis per the instruction manual.
As for me, I use Fellows shredder oil
Fellowes Shredder Oil 12 oz Bottle with Extension Nozzle 35250
and oil my machine every time I dump the cuttings. I run a bead of oil in a serpentine pattern over a sheet of paper and then just shred it. (If you have never oiled the cutters, it may be too late to do so now. Something you need to do on an on-going basis).
Jan 23, 2015 | Royal 150MX Cross-Cut Shredder
How to replace the radio with a cd player
It depends on the make and model of the vehicle but typically u need a new cd player dash kit for the vehicle wiring harness adapter specific to the vehicle a screw driver wire cutters and electrical tape
Oct 17, 2014 | Cars & Trucks
How do i change the tape on it?
This machine uses the Brother TZ tape, which is available in a variety of colors and three widths (1/4" (6mm), 3/8" (9mm) and 1/2" (12mm)). A TZ tape is supplied with this machine.
1 Press in on the rough area at the top end of the machine and fold open the back cover. Should be the exact process as loading batteries.
2 If a tape cassette is already installed, remove it by pulling it
straight up.
3 If the ink ribbon in the other tape cassette is loose, use your finger to wind the toothed wheel in the direction of the arrow on the cassette until there is no slack in the ribbon. Also, make sure that the end of the tape feeds under the tape guides. Note: If you are using a new tape cassette provided with a stopper, be sure to remove the stopper.
4 Insert the tape cassette firmly into the compartment, making sure that the entire back of the cassette contacts the bottom of the compartment. Note: When inserting a tape cassette, make sure that the inner ribbon does not catch on the corner of the metal guide.
5 Securely close the back cover, making sure that it snaps into place.
6 Feed the tape by holding down CODE and pressing PRINT once, and then push in the tape cutter lever to cut the tape.
You can also get a copy of the user's guide here.
Thank you for using FixYa! Don't forget to rate our service.
Feb 10, 2010 | Brother P-Touch 1180 Label Printer
I install a new ink cartidge color into my LexMark Printer is P4350. Its keeps telling me I have a error of 1203. What does this mean?
Bad or mis-installed ink cartridge. Open the printer and remove the ink. Clean around the ink carriage and the under the ink with alcohol and a cotton swab. Pay special attention to areas with copper contacts. If the printer has a cleaning option either on the printer itself through the menuing system or on the machine through the print driver, you can use that afterwards. Some printers will let you re-run the cleaning utility several times. Keep in mind too that some printers will not print, even with full ink, if the exact type of ink it expects you to have is not installed. This will give a similar error. Double check that the ink is correct against the manual or written instructions inside the printer. Not every cartridge that fits the printer necessarily works.
Nov 08, 2009 | Lexmark P4350 All-In-One InkJet Printer
Epson d78 printer
Usually the new cartridges come taped at places where the
ink is supposed to come out of, for shipping purposes.
Before installing you should have removed all those
tapes. There may be in more than one place per
cartridge too. Your little cartridge instruction booklet
should show you where they are and how to remove them
From what you are saying I suspect you did not
remove those prior to installing?
I am getting mine from
http://www.inkfilling.com
and they come with instructions as above.
If you did remove them then you may have not
installed the cartridges correctly perhaps did not
place them completely in their socket.
If you did then you must have something clogged
possibly printhead but i doubt that, most likely to be
one of the above.
May 01, 2009 | Epson Computers & Internet
Brother MFC-3360C cyan ink cartridge replace ment
On the front of the cartridge there is a sight tube for the ink, the fax shines a light through this tube to detect the ink.
I wraped a piece of paper around the tube to block the light beam on all the cartridges.
I dont need a processer to tell me if the machine is out of ink, I can work thay out when it stops printing!!
Now tell me you are out of ink you peice of electronic ****.
Jun 27, 2008 | Brother Multi-Function Center MFC-3360c...
Need copy of start here sheet
Printer is fairly new....have changed the inks once.....lost the
book, I guess,,,,,anyway, I THOUGHT I changed the black also,
but I have no black ink. I got a new cartridge, but don't know
how to install it......menu?? instructions? feel ignorant???
HELP! Thank you. Joyce
Feb 18, 2008 | Epson Stylus CX6000 All-In-One InkJet...
Casio KL 750 Thermal Printer Logo
218 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
