Question about HP PSC 1610 All-In-One InkJet Printer
My hp 1610 all in one
My printer will not print. When I restart the printer it comes up out of paper when it is alligning and will not continue. I have put paper in and nothing happens it will not feed paper or print anything.
  • 82 Answers
Is the color missing on the calibration page? Maybe some color or cartridge is empty and the printer can not calibrate... Without calibration no work !!!
Posted on Sep 09, 2007
I installed the device driver software for hp psc 1610, because I don't have the disk, I plugged in the printer when it prompted me to do so, and now it won't stop printing page after page of symbols.
Sir
I suggest you unstall hp printer software and re install your hp printer again with the hp printer cd come with your hp and once you install,take test print and then print your pages ,i hope your hp printer issue solve,in case you still have problem then contact HP printer Customer Support On official HP Printer Website x
Feb 24, 2014 | HP PSC 1610 All-In-One InkJet Printer
I bought an HP 6110 printer and had to put a #57 ink cartridge in.Now it's saying that my paper is too narrow.I have 8.5" by 11" paper in and all my settings are for that.And it won't print if I...
Hi
after changing cartridges printer needs to alligned printheads
and this can hapen only with A4 paper
just put one page A4 in your printer until allignment is done
if i help you pls vote me
Oct 27, 2010 | HP OfficeJet 6110 All-In-One InkJet...
HP 1610 printer photo paper jams
Right click on default printer icon select printing prefrences,click on advanced tab,select the size.or
Click on start menu then click on control panel.
Click on classic view on the left pane.
Double click on printers and faxes from the top toolbar.
Click on add a local printer.
Select the USB 001 virtual printer port from the “Use existing port” and click on next.
Select the manufacturer as HP and printer as Deskjet 990c and click on next.
We are using the generic driver for HP printers.
Use the default name for the printer, or you can change to your printer name and click on next.
Select yes to print a test page and click on next.
Select yes to set as default and click on next.
Select no to “do not share” and click on finish.
Jul 28, 2010 | HP PSC 1610 All-In-One InkJet Printer
HP PSC 1610 All-In-One paper jam 1/2 sheet
Throw this thing out as it is clearly rubbish. HP inkjet printers will **** the life and money out of you. Get a Brother HL-2170W and you will have care free printing for cheap.
Cheers old chap.
Mar 19, 2010 | HP PSC 1610 All-In-One InkJet Printer
My printer got jammed with the paper. i took the paper out and clicked print again. the printer is still not printing. i restarted my computer but it still doesn't work. what do i do??
Power off your printers and remove the cartidge and power on.the printer will re-alligned itself and check if it work.If even some small piece of paper is stuck inside the printer roller,it will still give you paper jam message.If that is the case try to print test print from the printer itself.
Dec 22, 2009 | HP LaserJet 1000 Printer
Hp psc 1610 all in one printer wont print
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 26, 2009 | HP PSC 1610 All-In-One InkJet Printer
Samsung ML-1610 Does not print after a paper jam
after checking no paper left on rollers etc, turn printer of for a while and then turn back on and press the paper release button
Oct 17, 2008 | Samsung ML 1610 Laser Printer
HP 1610 printer
It occurred to me when I was reading your post that photo paper has printing and non-printing sides. If the paper is loaded upside down, it's printing on the non-print side, which would result in what you're seeing. It's just a hunch, but you might want to consider it.
HP.com has a web page that will walk you through the process of checking on this and other potential problems.
Checking image quality problems
Hope this helps. Good luck.
Oct 09, 2008 | HP PSC 1610 All-In-One InkJet Printer
HP PSC 1610 All-in-One paper jam
ur printer paper feeder gears r jammed or misaligned. kindly get ur printer serviced from a good technician.dont worry its a normal problem.wish u success
Mar 11, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
Hp psc 2210 all-in-one
My computer will not allign right. It says paper is too narrow...insert wider paper...then refuses to do task . All the paper is the same. It is not the paper. What do I do?
Jan 09, 2008 | HP Printer/Scanner/Copier 2210 Ink-jet...
HP PSC 1610 All-In-One InkJet Printer Logo
123 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
