SOURCE: High oil Consumption, BMW M5
Look for Castrol TWS 10W60 Motor Oil. This car should not burn so much oil, you need to use a different kind. It is recommended by BMW as well. I also heard the VANOS isnt an issue anymore, can be fixed with a different MAFF. Good luck!
SOURCE: Car starts then immediately idles down and shuts off
i have had the same problem at times. my car would start and then shut off. but i found that i needed oil and check my oil and it was a quater low put in some oil and everything went fine i notices that everytime the oil is low the same thing happens also depending on the position of the car being park meaning that if you are in a down hill position or up hill position i will do the same. so you have to accelarate for 1 minute to have the oil go up. i hope this works
SOURCE: X5 Diesel blows smoke can u help?
# PLEASE HELP ME # 005 bmw x5 auto diesel 3.0d. 6 speed auto. when you come to a stop at traffice lights or roundabout or anywhere it jetks harshly at almost standstill speed. as if some one has hit you from behind. Only happens coming to a stnadstill. All other gear changes up or down are perfect. Also it DOES not do this if in DS or Tip tronic. Only does it in D when the car is warm. when its cold its ok. please help!!!!!!!!!!!!!
