Question about Logitech FreePulse Wireless Consumer Headphones
Power on/off Turning On Unit
The headset will not turn on, though the transmitter is fine. I squeezed the earpiece with the power button in on itself, and then firmly pressed and held the on button, and it popped on. This only worked once. I banged the earpiece with the On button while washing my car, but there wasn't even a scratch on the unit, and it seemed to work just fine. Any advice?? thanks david z
  • 6 more comments
  • Anonymous Dec 09, 2007
    Yes I have the same problem.
    Headphones fully charged and adapter is fine but cannot get the headphone to power on.
    Even tried resetting the adapter
  • travisto Jan 23, 2008
    I used to be able to push the power control in at just the right spot sometimes and the would turn on but now they don't turn on at all... If these have a 2 year warranty I will be sending them back for replacements.
  • rj4398 Feb 25, 2008
    Same problem here! The headset is only 2 months old, and I'm having to return them under the warranty guarantee.
  • slautterback Mar 09, 2008
    Same prob, I did get to work by removing the star ***** behind the ear cushion, then sliding the silver band that's just above the R (right side indicator).
    Then I spread apart the plastic carefully until they unsnapped partially and then stayed open.
    then I pushed the power on button and it works.
    Who knows why this problem is present, maybe some can offer a permenant
    fix.
  • ahum151 Apr 05, 2008
    were do you go to send them back to get a new pair
  • deegirl Apr 17, 2008
    same problem. headset not coming on period, but transmitter is fine.
  • sdubya Jul 27, 2008
    Same problem on my Freepulse headset. Got worse over a 2-3 day window until it finally quit turning on or off altogether. Followed seven step process listed by "guest" and I could see that the small push button switch under the power tab was indeed lifting up off the tiny PCB it is mounted to. You will need a very fine tipped soldering iron and be careful not to short the solder to any other parts of the circuit board.
    The pushbutton swith does not have adequate mechanical mounting relief and will likely become a problem for many users after prolonged use. One could try a dot of epoxy or superglue to try and secure the body of the switch to the PCB to help avoid repeated failures.
  • mcg100 Jan 02, 2009
    The solution above my post is truly the best one. I did as he/she said and now everything works! Eventually I think I may replace the support for the power button, but it works now and that is all that matters. Thank you to the guy/girl who offered this solution.
I actually tried the solution offered by "slautterback" and its working. Go figure....
Thanks for your help!
Posted on Apr 17, 2008
I had the same problem, but I fixed it. It's a very easy fix takes about five minutes. I don't think I need to post an instructable on this, but if someone needs photo-illustrated guide, I can do that.
Basically, the symptoms I had was that the on/off button worked but as time went on, i had to press it more firmly and harder. Basically the switch on the circuit board started to come off as I realized when I opened the headphones. Here are the instructions to open your headphones and fixing it.
1. Take the rubber thing that holds on to your ear, followed by the cushion on top of the speaker. They should just come right off by applying a small amount of force.
2. You should see a screw near the neckband, remove that. I believe its a torx six screw so you will need a torx 6 screw driver. Now, if you don't have one you can use one of those eyeglass repair screw drivers and try those.
3. Next, if you look closely near the on/off button (the silver plastic part) you should see gaps in increments. Take a flat head screw driver, and pry those spaces open, They should come right off.
4. Next, near the neckband and the speaker, there is a circular silver piece, that needs to be moved. Just apply a little bit of force or use pliers to push it back towards towards the neckband.
5. Now, slowly very carefully keep prying until the speaker gets separated from the headset pcb board.
6. Now, everything exposed, you should see a very tiny switch, that has started to come off. So taking a soldering iron solder the two ends of the switch.
7. Put everything back, and enjoy!
Posted on Mar 16, 2008
I have the same problem mine except mine just stopped working altogether for no reason. I checked the website and these things are supposed to have a 2-year warranty through logitech so I'm just going to try and get them replaced under warranty and unless anyone has anything better to do i suggest you do the same. Tyler
Posted on Sep 19, 2007
How do i fix power button switch on my wireless bluetooth headset? it the LG tone HBS-700
It is possible you may have broken the power switch off of the circuit board. To find out, you will need to open the earpiece and inspect it. Here is a video on how to open the earpiece LG Tone HBS700 730 repair mod and upgrade. If it has broken off, you may be able to solder it back on to the circuit board. If it is beyond repair, you could purchase a broken earpiece for cheap and use this video to repair it.
I hope this helps.
Feb 13, 2015 | LG HBS-700 Bluetooth Headset
Why does the myzone headset we purchased not work, as the red light will not turn on?
Not sure how old this unit is but you need to check your battery connections for crud.
If the battery's have been leaking or the terminals are corroded it will not power up. I beleave that unit takes rechargeable batterys.
May 15, 2014 | Lands Phones
I lost my ear piece for my Plantronics Voyager 500A so I am trying to pair a new earpiece. How do I do this?
1. On the base, press and hold both speak volume fine adjust buttons until the blue talk/on line indicator light and red power indicator light (on the front of unit) start to flash.
2. On the headset, press and hold the listen volume adjust + button and call control button until the status indicator flashes red and blue.
3. Pairing is complete when the talk/on line indicator on base illuminates solidly, and the status indicator light on headset flashes blue.
Important: Make sure your headset is not connected to any other Bluetooth device when attempting to pair.
Good luck from Headsets Direct!
Jul 13, 2011 | Plantronics Voyager 500A Deskphone Adapter...
I need to pair my plantronics (voyager) earpiece with my new phone. I don't have my instructions anymore. I cannot get it paired up with my phone. How do I do that if I don't have the numerical code for...
hello, . Press and hold the power button until the indicator LED flashes red/blue. The Voyager Pro headset is now in pairing mode. If you don't see the red/blue flash, press and hold the power button to turn your headset off, and then press and hold the power button again until you see the red/blue flash. try 0000 as the code good luck
regards
shaun
Oct 10, 2010 | Plantronics Radio Communications
Turning the plantronics 510 headset off
Holding down the small black button at the top of the earpiece will power down the headset. Plantronics offers great support too so you can contact them at plantronics.com or check out the Plantronics 510 manual for info.
May 08, 2009 | Plantronics 510 Voyager Headset - PLN-510...
Ear piece does not work. Station top light does not come on
The 500A base station is definitely compatible with the 510 earpiece. If the earpiece is turned off or unpaired the base station's red power light will be flashing. If the earpiece is already off, try turning it on by holding down the little black button on top. The base station will automatically try to find the earpiece and the blue light on top of the base will come on. If the earpiece is already on (slow flashing blue light on the mic boom) turn it off and back on again and wait for the base to find it.
Nov 10, 2008 | Plantronics - Bluetooth Headset Plus Base...
Plantronics voyager 510 headset
Make sure the headpiece is charged. Turn the headpiece off by pressing the little black button on top of the earpiece and holding for about 5 seconds. Turn the earpiece back on again the same way. You should have a slow flashing blue light on the mic boom. The base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
If this doesn't work you may need to manually pair the earpiece to the base by pressing and holding the Listen Volume Adjust + Button and headset Call Control Button on the earpiece until the light on the mic boom flashes red and blue repeatedly. As above, the base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
Nov 05, 2008 | Plantronics - Bluetooth Headset Plus Base...
Headset CS50
It sounds like you need to re-register the earpiece to the base. To do this, use the following steps:
1. Return the headset to the
Headset Docking Cradle
2. Press and hold both the
Speak Volume Adjust Buttons (+/-)
on the back of base unit for a
minimum of 5 seconds. The
Red Power Indicator will then
flash
3. Press and hold the Headset
Mute Switch (black button on top
of earpiece) for a minimum
of 5 seconds. The On-line
indicator (green light on boom)
will then illuminate.
4. Subscription completion is
indicated when the Power
Indicator is fully illuminated
and the On-line Indicator is
extinguished.
5. If subscription fails within 2
minutes the headset will return
to the un-subscribed state.
Aug 19, 2008 | Plantronics CS50 Wireless Headset
No sound comes from my headset
had same problem i found just turning my phone on and off to solve the problem
hope it helps
Mar 03, 2008 | Motorola Mobility H500 Wireless Headset
Logitech FreePulse Wireless  Consumer Headphones Logo
161 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
