Dryers Logo
Posted on Apr 05, 2009
Dryer won't get hot. I need directions for changing the heating element.
Anonymous
Level 1:
  • Contributor 22 Answers
  • Posted on Apr 05, 2009
Anonymous
Contributor
Level 1:
Answers
22
Questions
Helped
9279
Points
83
Have you checked the thermostat
Whirlpool dryer overhead I change termo fuse all the thermostat but is still overhead is cabrio steamer dryer
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
The dryer is getting very hot and then the timer appears to be sticking at 20 mins to go. I have changed the thermostats already.
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
My Kenmore Dryer starts but when I go to check it has stopped. The clothes are hot so it has run for some time I think maybe the safety switch to prevent over heating. I have changed programs and i
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Oct 17, 2014 • Dryers
Why is dryer over heating after changing 3 prong to 4.?
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
1helpful
Changed out rear bearing and heating coil now something smells like its burning
see this causes and fix it. God bless you
Heating Element A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Heating Element Assembly A defective heating element assembly can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element assembly to inspect it. The coils should not be touching each other or anything else.
Air Flow Problem Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
1helpful
Whirlpool dryer overheats element high heat all heat settings
First check the heating element for short to frame. If it is not shorted remove the filter chute and clear it out. The control thermostat has 4 wires. 2 small wires come from the timer and power up a small heater inside the control thermostat making it shut down faster for perm press and knit cycles. Over time this bimetal inside the control stat won't shut down fast enough or not at all. If it won't shut down then the element will gl;ow reed and the base 250 stat on the heater chamber will shut down. If it fails to do so then the smaller one up top will trip at 300f. If it fails to trip or the filter chute is clogged the fuse skinny white plastic thing next to the control tstat will met and shut down operation.
Here is my HOME MOVIE ROPER DRYER NO HEAT
It shows the various components and how to check.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 31, 2012 • Dryers
Dryer spins but won't get hot. Bad heating element? If so , where is it located?
Check your circuit breaker. It may not be your dryer at all. 220 dryers run on two separate circuits one to run the motor the other to run heating element.
Dryer won,t heat, put in new element and still won,t heat.
check you thermal fuse for continuity if none change it and the high-imit safety shut-off fuse(closest to heat element)
Apr 08, 2009 • Dryers
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
