Question about Akai LCT3201AD 32 in. LCD Television
Akai LCT3785TA stereo vs. mono issue
Every time we change the channel, the TV defaults to Mono. Mono doesn't sound as good as Stereo, so we have to change to stereo after each channel change. Can we set the TV to Stereo as a default?
    Genius:
  • 1,003 Answers
No the default (setting is mono) therefore u will manually make this selection.
Posted on Mar 10, 2013
  • 58 Answers
Well the default is to obtain the channels signal. most channels over the world their audio output signal is mono. Rare tvs have the ability to save indivisual channel to their memmoty. Read the tv prospectus!!!
Posted on Sep 04, 2007
SOURCE:
What does a mono status mean on the tv screen?
It does not mean much---sound may still be stereo but channel change often does not allow it to show.
With it on a channel listen carefully and switch it if possible from mono to stereo to see if hear mono or not.
Jun 11, 2012 | GPX Televison & Video
How do I get my rca truflat tv to get out of mono?
Hello
Press the MTS on the remote control handset to select STEREO, MONO or SAP. All the options will be available only when the current TV channel is broadcasting that option. Channels will not always carry programes, that have all MTS options. If "STEREO" appears on the screen when you select a channel means stereo sound is available with current programme. You can hear sound from both speakers. If broadcast is not strong and clear, stereo sound will not be available. Press "MTS" button to change it to "Mono". This will eliminate the noise. If "MONO" appears on the screen when you select a channel, stereo effect will not be availabe, even though you have set it to stereo. If "SAP" appears when you select a channel 'Second Audio Programe' [SAP] broadcasting is available for that programme. Press the "MTS" button to 'SAP' and you can hear that programe in different language or some other kind of audio.
Oct 28, 2010 | RCA TruFlat 27F520T 27" TV
I've been having this audio issue with my LG 19LG30 for awhile now. Only recently discovering what exactly was going on. My audio would go in and out on some channels. There would be sound then muted for a...
to eliminate the problem just select the mono sound disable the stereo signal.so that your tv sound will be stable.this happens because not all tv stations are broadcasting on stereo signal thats why your tv keep on switching to mono and stereo base on what signal it receives.plus the signal being feed by the cable provider sometimes they are not stable enough to give the stereo signal so better select only the mono sound...tnx hope i helped you..
please rate my help!
Jun 05, 2010 | LG 19LG30 19 in. LCD HDTV
Mono to stereo
You can't convert mono to stereo since the TV only has a single input, and not the separate right and left channel circuits needed for stereo. If you are connecting a stereo source like a DVD player, what you can do is combine the right and left channels into one and connect that to the mono input. You need an audio Y-adapter with two RCA jacks going into a single RCA plug. These are available from Radio Shack. If you are outside the US, there should be local sources such as a stereo shop where you can find the adapter. This won't give you stereo, obviously, but you will have all the sound.
Jun 22, 2009 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Audio with digital channels, no audio with analog channels
I was getting a constant mono setting for all channels with no option to set it to stereo. I called Sharp, and they said that in order to receive stereo sound, you cannot use a standard coaxial cable. You need an S-Video or HDMI cable. This not only resolves the mono audio issue but also resolves the analog (vs. stereo) issue. Hope this helps!!
Feb 10, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
No sound on 3 channels
Check if the sound adjustment is in STEREO-SAP-MONO mode
Change to STEREO mode
Jun 02, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Akai model lct2721ad. tv.
Mine does this all the time. It appears to be a factory flaw. The only way around it is to set the channel you are watching to "MONO" and the crackling sound will disappear.
May 11, 2008 | Akai LCT2721AD 27 in. LCD Television
Mono Vs Stereo
Here is what I found out. I had this same problem. I have cable TV and the signal coming into my house was not very strong. They 'boosted' the signal and this problem stopped. Along the way, they tested that the cable line had been passing through a splitter, so that to the house the signal was good, but by the time it passed all of the splitters, the signal was not strong enough. Now all is well and the problem does not happen anymore.
Nov 12, 2007 | Akai LCT3201AD 32 in. LCD Television
Akai LCT2070 Stereo Sound
This tv is kind of got a mind of its own the only time you can adjust it on mine is on cable that comes in stereo actually it usually switches by itsself after it reads the broadcasted sound. Hope this helps.
Nov 09, 2007 | Akai LCT2070 20 in. EDTV-Ready LCD...
Akai lct2785ta Sound Problem
Bear with me...I will start talking about CC, but I think my solution may work for you, too. I noticed that every time I turned on Closed Captioning, when I changed channel, it went off.
I went into the on-screen set-up, and turned on the CC there. Now, when I turn OFF CC, then change channels, it comes back on.
So, it may just have to do with your set up. Go there and set the default sound to stereo and see if that fixes it.
Good luck.
Oct 05, 2007 | Protron PLTV-37 37 in. LCD Television
Akai LCT3201AD 32 in. LCD Television Logo
448 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
KISHORE DESHPANDE
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
