Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Sound after washer fills up
When i put in a load of clothes the washer filled up and then it started making this buzzing like sound and no matter were you put the dial it will not do anything
It sound like you may have a bad capacitor. Just like a standing fan the motor uses a capacitor to boost the current to the starting coil to get the motor in motion. This causes the motor to hum and not spin. Hope this helped. Rudy
Posted on Sep 04, 2007
Why does my washer just buzz when it should spin?
out of balance or too much clothes.... try removing half the load you put in and try again ...............Good Luck.
Aug 24, 2014 | Kenmore Washing Machines
Replaced the lid switch on my top loading washer and it fills with water and it still wont start.
There are a couple things that could cause that
1) The water level switch,but if it filled to normal level and the water stopped that is pretty unlikely.
2) the motor,if it just sits there silent and no humming/buzzing noise the motor is most likely not the problem,if a heavy buzzing is heard the motor needs to be replaced.
3) again if it just sits there and wont make any sounds no matter where its set at,the timer is the very probable trouble.
I hope this helps you diagnose your washer trouble,
Gene
Aug 05, 2011 | Washing Machines
Machine filled with water then just began beeping. Never started to wash the clothes. When turned off and then on again, it makes a buzzing noise and nothing happens.
If your buzzing noise stops after a few seconds, it could be the motor failing to start. If it sounds like a signal buzzer, it could be indicating the lid open, or a failed lid switch.
May 18, 2011 | Maytag Bravos MTW6600T Top Load Washer
Can''t get my clothes out... water still inside
does it have a dial that you can manually turn to start the next cycle? You can usually drain the water by pulling the drain hose out from the wall drain behind hte washer....( usually just shoved in the drain not attached) but be aware that when you hold the hose below the water level in your washer it will start to drain. Then perhaps the door will unlatch.
Sep 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
I have a two-year old Frigidaire GLTF2940FSO front loader washer that has stopped in the middle of a load leaving water in the drum and will produce a buzzing sound no matter what cycle you put it on. We...
did you try unplugging it and plugging it back in to see if you can get it to reset? Would it buzz when you try to drain it? Does the door latch lock when it goes into the wash cycle? Usually the door latch locks when it goes into the wash cycle and stays locked. So it filled up, the door latch should lock, then should go into wash cycle. Then you said few minutes later it stops. How did you get the door open? reason i ask is Usually i would see the clothes get stuck inside the washer because the door latch is still locked when it stops. Was the door unlocked when it stoped. If so maybe something going on with the communication from the board to the door latch maybe. Did you try operatin the drain?
Aug 01, 2009 | Frigidaire GLTF2940ES Front Load Washer
Water fills to proper level but agitator doesn't come on instead there is a grinding noise, when I move control to just prior to rinse cycle water drains properly, but still just grinding or buzzing n
Hi, Do you know if the washer spins at all?
It sounds like the coupler has gone bad.
Please let me know if it spins at all.
I can send yyou instructions on changing the coupler.
Vic
May 28, 2009 | Whirlpool LTE6234D Top Load Stacked...
Won't fill
check to see if the water is turned on? do you hear a light buzzing or humm noise?
Jul 26, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washer fills, but won't start wash cycle....makes buzzing sound
Try replacing the timer switch..I had the same problem on my Simpson 175..
Dec 26, 2007 | Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
