Question about LG WM0642H Front Load
LG Front Loader Filter
I have this front load washer and I do not know where the filter is located? Is it the box on the lower left side?
Yes, the owners manual can be downloaded here http://us.lge.com/download/product/file/1000001248/WM0642owners.pdf
Posted on Nov 28, 2007
Where is the pump filter on an lg washer?
The PRIMARY filter for discharged water in most front loaders is located under the opening of the washer behind a small 'door'. There is usually a small tube which you will need to pull the plug from and drain about 2 cups of water into a bucket BEFORE you remove the filter to clean it.
After you unscrew the filter which is mounted from front-to-back and clean it out, replace both filter piece and plug and replace the small drain tube.
Close the access door and operate your machine.
* Clean this filter every month or especially after washing heavy lint-producing materials.
Jul 21, 2014 | LG WM-2277HW Front Load Washer
Lg tromm front loader will tumble but wont spin
Open the access door at the bottom left corner of your washer. Use the small hose there to drain the remaining water from the machine. Un-screw the big knob next to it and pull out the attached filter. Clean out the filter and re-install. If the filter was clear, replace drain pump motor.
Mar 15, 2011 | LG WM2277H Front Load Washer
How do I unblock the filter and where is the filter located on my Ariston front loader
Remove the lower plastic panel at the front of washer.
The filter is located at the bottom front right.
Unscrew anti-clockwise to remove and clean.
Have some cloths handy as thetre will be some water that will come out.
Jan 05, 2011 | Ariston Technologies Ariston AWD12 Front...
What does a pump filter consist of on a front loader tromm
Get some towels ready for the floor'
Open the small door on the left side bottom
Unscrew the large black cap pull out and clean filter
Jul 02, 2010 | LG WM-2277HW Front Load Washer
Lg tromm front loader washer wm0532hw shows oe error
that's draining error. check the filter cleanout behind lower left panel on front of machine; of course drain 1st via small drain hose. if thats o.k the drain pump itself may be jammed with debris or the drain hose could be clogged.
Jun 24, 2010 | LG WM-2277HW Front Load Washer
LG front load washer has a drain error message
Clean out the filter behind the small access door on the front lower left side of the machine. The small hose is there to drain the water out first. If there is nothing in the filter, you may need a new pump motor. (pump impeller comes off shaft sometimes, requiring pump motor replacement)
May 07, 2010 | LG WM-2277HW Front Load Washer
That's actually DE (Drain Error). Clean out the filter behind the small access door on the front lower left side of the machine. The small hose is there to drain the water out first. If there is nothing in the filter, you may need a new pump motor. (pump impeller comes off shaft sometimes, requiring pump motor replacement)
May 06, 2010 | LG WM-2277HW Front Load Washer
Where is the pump/filter located on my Kenmore Front Loader Washe
It is just behind the lower panel. Remove the 3 screws from the lower panel (the panel just below the door), the screws are on the lip on the bottom of the panel facing the front of the machine. Pull down and toward you to get the panel off. The filter and clean out are in the center. Unscrew the cap to remove and clean out, but have lots of towels ready, there will be water coming out.
Apr 20, 2010 | Kenmore HE2 Plus Front Load Washer
Washing machine front loader has OE error code
Mine did the same and there was a 20 cent piece in the drain filter which is located at the bottom front left hand side you take off the cover - beware that a lot of water may come out - have towels ready. or your outlet pipe may be blocked. OE is a draining error message
Aug 22, 2009 | LG WM-2277HW Front Load Washer
Where is the drain filter and the spin rinse sensor located on
Have not heard of a part called a "spin rinse sensor". Drain filter is located behind the small access door at the bottom left on front of the machine. Use small hose there to drain remaining water out of pump and hoses, then unscrew the big thing on the right side (end of the filter).
Mar 14, 2009 | LG WM1814CW Front Load Washer
LG WM0642H Front Load Logo
145 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
