Question about Brother MFC-5840CN All-In-One InkJet Printer
Not 5840 but 2070
I ahve a 2070N. It won't turn on. Do you know if I can buy a power switch somewhere. Does anyone know? and where?
  • 832 Answers
If a brother printer wont turn on its usally a problem of the main pcb! Due to power or lighting strikes the microdevices might be shortcuted. Its cheaper to buy a new printer than to replace the board!
Posted on Sep 12, 2007
My dishwasher has no power so it won't turn on and I need help fixing it to get power back. Anyone know how? PLEASE HELP
First check the power at connection, bottom right, if you have power here, check the fuse
Mar 29, 2013 | Dishwashers
I have a Big Maxx heater and it won't stop blowing and won't heat. The fan just keeps running! Anyone know what could be wrong?
Your pressure switch may not be activating (ie closing and making contacts) This means you could have a blocked flue, clogged pressure switch tube or a bad pressure switch. The pressure switch is a safety feature to ensure your exhaust is not blocked and operating correctly. Find owners manual. Look at trouble shooting section. Open cabinet and look for error code light. If blinking 3 times, try "jumping" the pressure switch. To jump pressure switch you need to clear code be turning off power. When the unit/thermostat calls for heat the power vent fan starts first, this is when you need to jump the pressure switch. You need to do this in sequence. That is the unit first starts the power vent exhaust thus activating the pressure switch allowing the ignition cycle to the burners and heat. So the power vent fan needs to start first BEFORE you put the jumper on to bypass the pressure switch. Once the jumper is on it will call for ignition after approx 30 seconds. If ignites your problem is one of the 3 stated at the opening of this paragraph
Mar 21, 2013 | Mr. Heater Natural Gas Garage Heater -...
Help me with my 1993 chevy cavalier 2.2L engine. My car won't turn on when ignition switch is in the on position. When I turn it to the on position, my radio cuts on, and my air conditioner turns on,...
what do you mean by "dash lights"? how do you KNOW the pump isnt working? how do you KNOW its good? at the ignition switch the ORANGE and PINK should have power in the RUN position the BROWN and TAN/WHITE should also be HOT in the run position. There should be a red wire near the fuel pump relay, make sure its HOT when cranking. IF its HOT and the fuel pump doenst run, the pump is bad. You can also put 12V on that red wire and power the pump.
Aug 26, 2011 | 1993 Chevrolet Cavalier
Motorola em326g call divert won't go off
hi
what you ahve activated is calling divert it is a simple thing to turn off but handy when you need to divert a call somewhere , you go into the settings menu of your phone , then calling , then call divert press this and then it should say activate , deactivate, or staus press staus to make sure for definate that it is on and then press deactivate then you should get a confermation message appear and its done
Aug 29, 2009 | Motorola Mobility RAZR V3x Cellular Phone
How do I remove paper from paper jam?
To remove paper pull the paper with both hands being careful not to tear the paper . If you're unable to pull it you may need to manually rotate the gears that feed the paper through the printer
Now reset the printer by pressing the power button in on state to turn it off and restart
again thats all just take care that you remove the tray carefully
Thanks and Regards
May 12, 2009 | Brother HL-2070N Printer
Won't power up CPU fan
pine,
It sounds like you have a short somewhere in the motherboard and should have it replaced. The website for this product can be found here.
Also, I found a technical guide for you which may help.
Download
Please let me know if this helps. Good luck!
Feb 29, 2008 | Intel D875PBZ Motherboard
Brother MFC-5840CN All-In-One InkJet Printer Logo
59 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
