Question about Lexicon Omega Pro Studio External Sound System
Won't play through Computer Speakers
I've installed and reinstalled the software but i can't hear the audio through my speakers when i plug my bass into the Omega. Please help me. I'd really like to try recording some things for fun and to help me along with my playing.
    Novelist:
  • 231 Answers
Hi, go to start, control panel, Sounds and audio devices. You will need to set the audio system up here. Select the connection you have to the system, that should cure your problem. Regards mistyman
Posted on Sep 04, 2007
SOURCE:
Dell Inspiron 6400 E1505 audio not working.
Try system restore to straighten out registry to play audio..
Apr 01, 2012 | Dell Inspiron 6400 Notebook
My speakers used to work. They have only been used a few times. The volume settings on my computer are turned up and I have checked all the wires. I have also tried the speakers on two different computers....
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Feb 02, 2011 | Computers & Internet
My sound hardware work but i dnt hear nothink in my output speack
Question: Are your speakers plugged in and turned on?
First check the hardware of your speakers, that they are plugged in, to the proper speaker port. then check the device manager to see if it recognizes the sound card /speakers, it not then go to add hardware app and run it , remove sound card and replace it with windows Plug and Play running. if it recognizes it then run your program to see if the sound is playing. Good luck hope this solves your problem.
Jul 12, 2009 | Computers & Internet
Computer does not recognize speakers after reinstalling winXP
Install the software for the sound card. XP has no support without it.
Oct 03, 2017 | Labtec Pulse 285 Computer Speakers
My speakers seem to be stuck on a very low volume
I have speaker problem no sound but I know its there because when I turn on volume can hear it turn on it was working before my computer is hooked up to magicjack for my telephone different area code then where I live and the other day when I picked up reciver to make a call could hear my speakers on my phone assastance asap PLEASE
THANKS
Marie
Jun 02, 2009 | Logitech X-240 Computer Speakers
Bass speaker moving in out more then normal
If you can't hear the difference maybe the bass frequency which is moving the speakers is below your hearing range.
I think you may have a "loudness" button on that amp -- if you do, turn off the loudness -- this is a bass booster.
But, in general, bass speakers are designed to move in & out a lot. They have to move a lot of air to produce the bass sound.
May 09, 2009 | B&W ASW1000 Speaker
I cant get the rear speakers to play on my pioneer deh-p3000ib.
Sounds like you have
1) the rear speaker cable is plugged into the wrong colored hole
2) the audio software thinks you have a subwoofer, but you don't? Check on the audio software for ways to configure the speakers, the latest chips auto-detect when you plug in a cable, and ask you what that was you plugged in.
Jan 07, 2009 | Kenwood KDC-MP4028 CD Player
Sometimes make noise
if u play ur speakers with high sounds the speakers gonna give a hit sound and the beep sound what u get actually with the computer what u can do is just play ur speakers in some other system see if the same things happen with ur speakers then ur speakers are not proper if it is playing right with some other computer then there is a problem in ur computer in ur computer go to ur sound drivers software and just turn all settings to default and play if the same problem persissts then reinstall ur audio driver and play then it should play perfectly
Nov 21, 2007 | Logitech X-530 Computer Speakers
Speakers dont work at all
Did you install the audio card drivers?
Oct 29, 2007 | Logitech R-20 Computer Speakers
Lexicon Omega Pro Studio External Sound System Logo
789 people viewed this question
Top Lexicon Computers & Internet Experts
Tony Raia
Alun Cox
Thomas F. Schneider
Are you a Lexicon Computer and Internet Expert? Answer questions, earn points and help others
