Question about LG 24 in. LD-12BW5 Free-standing Dishwasher
Error code E1 on LG dishwasher
I have a LG-14AW2 which displays the E1 code - sometimes immediately it has filled up and at other times later in the rinse cycle. I have taken the machine apart and there seems to be no leaking (as suggested in the handbook). Other suggestions from this site focus on the motor / impeller, but on closer inspection there appears to be no problem, i.e. no broken shaft, all the impeller vanes are intact. Any other suggestions?
  • 5 more comments
  • Anonymous Jun 01, 2008
    Same as the above - pump whirrs for 2 minutes on 1:37 min cycle before E1 appearing.
  • Anonymous Apr 03, 2009
    Only had the E1 problem since they replaced the pc board 3 moths ago. Rang LG and they said to replace pump which we did and still get the E1 error code, there is NO leak in this machine - I feel it is the pc board.
  • Anonymous Apr 27, 2009
    The latch on my LG dishwasher broke and after the tech put a new one it it beeps randomly during it's cycle, for some reason it seems to beep more when it is in it's drying cycle. He thought the new latch was faulty so he came back and put a second one in, but after a few days it still does it, oh by the way he also replaced the board too?
  • Jessica Somur
    Jessica Somur Oct 28, 2013
    I am having the same error for a few months now. The technician is confused. The motor was changed, a new capsitor was put in but the E1 error still appeared. So he put in a new pc board. And we still have the problem. I did however now now find out that tge E1 error doesnt appear on a quick wash.
  • Sakkie Schoeman Jun 16, 2017
    Mine doing the same.Stripped machine,check everything.No fault found.Start up running smoothly through whole cycle.Start up again....after few min e1 showing.I want to burn it!
  • Brad McGrath
    Brad McGrath Jan 10, 2018
    Hey all, I have had this problem with my LG dishwasher and I found that the fresh water 8nlet screen was plugged. After removing the capture plate i was able to access the screen. I cleaned as much of the debris from the screen and then gently pryed out the stainless screen to fully clean it with a toothbrush. After reassembly all codes went away and our dishwasher runs smoothly and quietly once again. This repair took about 30 minutes for a guy who had a broken finger...lol and now we live happily ever after, at least till the next time it gets plugged up.
  • Brad McGrath
    New Friend:
I have this sometimes where E1 is reported and the pump remains on. The following voodoo has worked for me.
1) Make sure there is not a real drain problem.
2) Cancel any cycle or turn the power button off then on.
3) Run a rinse cycle (15 minutes).
4) If pump continues to run, turn off the power to the dishwasher, let stand for a minute, then repeat steps 2-3. If still not working, leave power off over night and leave the door open then try again.
In each iteration, it is important to curse your LG product and/or threaten it with replacement.
Posted on Jan 12, 2010
  • 5 Answers
Hi Im a tech from LG, your outlet hose is too low or too far down the drain, it is losing water while it is washing making it think there is a leak...
Chris
Lg Durban
031 7165444
Posted on Feb 02, 2009
  • Siacci Mar 17, 2011
    Its not the drain hose thing, I replaced the pump ( $100 ) and the circuit board ( $140 ).
    It still just fills, sits a bit, flashes E 1 beeps at me and pumps out.
    Any more ideas.
  • francis
    francis Jun 18, 2019
    I got the e1 several times. I raised up the hose in the back and that solved the issue! I ended up cutting a higher hole into the side of the cupboard to go to the disposal.
    New Friend:
Just throw it away and never by LG again. I spend $400 on repairs and still shows E1 message. Wasted money and angry cursing wife.
Posted on Jan 28, 2012
If it is a 240V machine, you need Wash Pump (5859DD9001A)
I had the same problem, machine would pump out, fill & then run the wash pum & stop at about 1:37 with an E1 error.
The impeller on the pump has come loose on the motor shaft so when the motor runs, the shaft spins inside the impeller & it won't pump the water around.
The machine will fill & empty OK.
I'm in Australia & I was able to get the pump online from the BigWarehouse spares.
Posted on Jul 16, 2008
I ended up pulling the front door and found a gray wire that was broken. It was in the bottom of the door where there is a plastic harness that wraps around the bottom of the door. I had to disassemble the plastic harness to get enough wire to solder it. The washer was good to go after replacing the door. My only advice is to look long and hard for a broken wire, it wasn't obvious as it was behind the harness.
Posted on Jul 26, 2010
  • Olivia Forsberg
    Olivia Forsberg Sep 27, 2010
    I investigated the grey power cord only to discover a mouse had nibbled through to the copper wiring!
Http://www.yellow-mini.co.za/dishwasherfromhell/ Bad Solder Joints on the pc board......
Posted on Oct 02, 2007
Check the wires in the door panel, the inner door panel gets hot from the hot water and causes wires to melt into ins. coating and they brake. Simply repair wire and wrap with tape.
Posted on Apr 04, 2011
    New Friend:
I solved this issue by going under my sink and pushing the hose more into the hole leading to the dishwasher. I can’t believe this small step was the solution, but it was. Thanks!
Posted on May 23, 2019
    New Friend:
I've got an LG D1452LF dishwasher that I bought in 2013 - already had to replace the drainage pump (18-months ago) just out of the 2-year machine warranty and specific part not covered by the 10-year motor warranty, naturally. Been working fine but couple of days ago it got an E1 error. Switching off and then back on goes straight back to E1 - don't even need to press the power button. Drainage pump is still working as it runs continually while the E1 message is displayed and it is pumping water out. I removed the bottom front panel to take a peep underneath and discovered the bottom tray where all the electrical bits, pumps and hoses are had quite a bit of water in it. This is obviously triggering the E1 water leak alarm. I've tried sopping up the water as much as I can but still the E1 alarm persists. Called the LG repair company who charge a call-out fee to attend - their suggestion is to replace the entire sump assembly as everything is wet. Part of the 10-year warranty apparently. So parts are ordered, to be installed next week - just have to break-out the inlet hose that goes through the masonry wall so the unit can be removed for the repair. Fingers crossed it gets sorted with no additional cost to me.
Posted on Sep 13, 2017
    Sergeant:
  • 107 Answers
Whenever I have issues with my dishwasher I just call an appliance repair place. Mine broke down eight years ago and I tried to fix it myself. Long story short, I made the issue worse and now I'd rather be safe than sorry. Cosmos Appliance Service Proudly Serving Langley the Surrounding Area
Posted on Sep 04, 2015
    New Friend:
Hay please can you help me my dishwasher midea company it new model realise on 2015 and when I bring my midea dishwasher company it only work 2 days after 2 days it start saying E1 I call dishwasher company and they also tried of this dishwasher it's not working dishwasher man check everything but still it saying same thing E1. Please help comment
Posted on Sep 02, 2015
    New Friend:
My LG would start a cycle by pumping out, then filling up, stand for a while and then give the E1 error followed by pumping the water out. I couldn't see anything wrong at first. Took it apart and took out the circulating pump. I took the plastic housing and impeller off from the motor and found that I could not turn the motor shaft by hand. Opend it up and replaced the front bearing (R25, about 3$). Put everything together and it workes perfectly!!
Posted on Apr 22, 2013
    New Friend:
I had a repairman come and he told me that LG has had problems with the intake valve pump on some of the dishwashers but not enough for them to warrant a recall. Therefore it cost me $146.00 in labor (since my warranty on labor just expired) to fix a problem that LG should have taken care of. He also replaced the circuit board since it was still under warranty which makes me wonder if that isn't also an issue with these dishwashers. All I know is that when the parts are out of warranty and something goes wrong I'm going to junk this piece of @##[email protected]#!!.
Posted on Feb 08, 2012
  • John Sheaffer Dec 11, 2013
    LG Model LDF7551ST; I rapidly pressed the power button untl it turn off. Then it restarted and ran. When I called LG they siad that there was no known common issue....then I asked "why is the issue all over the internet."ed
SOURCE:
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    My LG dishwasher when I turn it on it drains the water, then it fills it up with water, about 1 min. later gives me the code E1 and drains the water again...
    LG Dishwasher Displaying Fault Code E1 LDF7810BB/01 LEAKAGE ERROR // Excessive pump motor RPM due to water leakage
    The manufacturer has assigned this error or fault code to indicate that when the drain pump is running it is not experiencing the back pressure it expects. This is usually an indication that there is a water leak in the drain system. Check all hoses and connections. Check under the dishwasher for any major leak. If all checks out, be certain there is a proper loop in the drain hose to prevent siphoning. Finally, if the problem persists, the drain pump itself might be defective.
    Sep 25, 2015 | LG Dishwashers
    Displays E1 code. water is on
    Hi there Dolly, error code E1 relates to water leaking. Its the code the machine displays when the flood switch in the bottom of the machine activates. The flood switch activates when the bottom of the machine gets filled with water from a leak. I surgest you have a look underneth the machine for signs of water. I hope this helps regards Gary.
    May 04, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
    LG dishwasher error code E1
    E1 is a code that the dishwasher displays after detecting a leak. There is a sensor on the pan at the very bottom of the unit. Take the bottom front panel off, look under the unit at the hose coming off the pump and your fill line to be sure no water is dripping. Run the unit in a wash cycle while doing this if possible.
    Nov 21, 2017 | LG Dishwashers
    AE displayed on LG dishwasher
    Please look one more time. The LG LDS 5811 dishwasher error codes are:
    IE Error
    OE Error
    FE Error
    E1 Error
    HE Error
    tE Error
    It would also be helpful to know what happens when this error code displays. Please post back here, OK?
    Thanks.
    Apr 16, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
    Model LD-14AW2 alarms after 1 minute of startup and says E1
    The E1 error is telling you that there is a leak in the dishwasher. After confirming that there is no leak, even directly under the dishwasher (remove the kickplate and use a flashlight.)
    After ruling that out, your problem is almost certainly caused by the drain hose between your dishwasher and your drain. There MUST be a 30" rise in the drain hose between the DW and the drain. If the hose just lays there, causing a siphoning effect (law of physics) that WILL drain water out of the dishwasher into the drain as soon as a wash or rinse cycle begins (after 1 - 2 minutes after they begin. Then the E1 error will be displayed.
    The BEST way to fix this problem is to install an AirGap valve (almost free @ any hardware store) in your counter/sink and then running the short pipe to your disposal or sing drain inlet. If that is not possible or for a quick and dirty repair until you can install the AirGap, tie the drain hose to the bottom of the counter top so the rise is created.
    Good Luck!
    Apr 02, 2009 | LG Dishwashers
    LG Dishwasher making grinding noise then blinking E1 code 10 minutes later
    Well done by resolving this problem. The other way to avoid the siphoning problem through the drain hose is adding an air gap valve/connector (available at any hardware store). You can use it even if you don't have a garbage disposal in your kitchen sink. That will assure that you have the proper height of the drain hose.
    Hope this helps!
    Oct 22, 2008 | LG LDF6810ST Stainless Steel Built-in...
    LG LD-14AW2 (03 error)
    agreed O3 is not a LG error code. OE is more likely and if so it could be the main pcb faulty, a blocked drain pump or a blocked spigot under the sink where the drain hose connects onto.
    take care.
    May 11, 2008 | LG 24 in. LDF 7811 Built-in Dishwasher
    LG Dishwasher
    according to the manual that i have just downloaded from the net,E1 code means.water leakage in Hose connections.
    .water is leaked by damages
    hope this helps,
    keith
    Sep 20, 2007 | Dishwashers
    E1 Error Message
    agreed all LG d/w with E1 is the wash motor faulty.
    take care.
    Jan 12, 2007 | LG 24 in. LD-12BW5 Free-standing...
    LG 24 in. LD-12BW5 Free-standing Dishwasher Logo
    47,112 people viewed this question
    Top LG Dishwashers Experts
    Marvin
    Marvin
    Mike
    Are you a LG Dishwasher Expert? Answer questions, earn points and help others
