Question about Samsung HCN5529W 55" Rear Projection Television
Samsung 55" TV does not turn on
My samsung 55" rear projection tv will not turn on. When I plug it in, the musical chime sounds indicating it is turning on. The red light on the front will blink for a few seconds, then the tv powers off. No picture, no sound. The cycle just continues on and on until the tv is plugged in. A repair tech came out and replaced the power supply board. The tv worked for a couple hours and then I had the same problem again. The power supply board was replaced two more times before I was able to finally convince the repair tech that the problem was something else. He told me it was the digital control board. I was fed up with the service (and of not having my tv for over 6 months), so I told him I was going to try a different avenue or repair facility. Any help to at least confirm the issue before I try to get it repaired again will be greatly appreciated. Thanks in advance.
  • 1 more comment
  • joelfal Nov 19, 2007
    i have the same problem, the tv just keeps trying to turn on, but i never get a picture or sound, then the startup sound goes again and it tries to startup again.
  • journeyman22 Dec 23, 2007
    I have the same problem. I've been searching all over for one decent answer to why my TV will not turn on but nobody has the answer so far. Ireally don't want to dig into the set but i also don't want to pay a bunch of money if it's simple or they can't figure it out.
  • depfer Dec 20, 2008
    I have the same problem and initially BestBuy replaced one board without a fix. They then ordered 2 boards # Bp94-00505U and Bp91-00801S. After 3 months they said they couldn't get the second board and wouldn't be able to fix the TV. My Tv have been in my garage for about 10 months. Has anyone ever had this problem resolved ? I could order the first board for $131 if I knew it was a good fix, but I had no faith in the Bestbuy technician from day one, so I don't know if I would be wasting $131 or not.
CHECK YOUR RED ,GREEN AND BLUE CRT'S THERE MAY BE A SMALL CRACK ON THEM.MAKE SURE TO TAKE THE YOKE OFF AND INSPECT THE ENTIRE TUBE IF THER IS A CRACK IT IS CAUSING YOUR TV TO GO INTO SAFE MODE. ALSO CHECK THAT NONE OF THE COOLING FLUID HAS DRAINED OUT OF THE TUBES ON TO THE CRT BOARDS IF SO REPLACE THE BOARDS AND CRT IF CRACKED. YOU CAN FIND ALL THE PARTS AT PARTSTORE.COM HOPE THIS HELPS.
Posted on Nov 09, 2008
SOURCE:
Tv wont turn on
usually indicates that the lamp is burned out,the ballast is dead or the power supply board has failed. you can do the lamp yourself but the others would need a technician. call 1-800-samsung for nearest service center.
Nov 17, 2009 | Samsung HCJ552W 55" Rear Projection...
I have a Samsung hcm4215w you can hear samsung turn on chime but no picture.Please any advice would be appreciated.
Ur video backlight board is dead,not get power to the board to get picture,must replaced the backlight video board.
Another prob.u could have.
U have tv show sound,but no picture?
Ur inverter board it dead.
Oct 24, 2009 | Samsung HCM4215W 42" Rear Projection...
TV won't turn on after a repair
you changed all the eprom info but didn`t "save to ram" before un-plugging ac cord, you will have to call a tech and be sure to advise him what you have done so the tech will be sure to bring service manual, info will have to all be re-entered, video-tek
Jun 10, 2009 | Samsung HCM5525W 55" Rear Projection...
Samsung hc-p4241w - No picture
samsung tv model hc-p4241w good picture no sound
May 22, 2009 | Samsung HC-P4241W 42" Rear Projection...
Samsung HCN5529W rear projection TV has no picture but has sound
More likely its one of the Video output ICs which are located on the three CRT drive boards. I have seen that happen when one of the ICs fail they are TDA6111Q heres what they look like they are attached to the aluminum heat sink on the drive board617d21d.jpg
May 11, 2009 | Samsung HCM5525W 55" Rear Projection...
I have a Samsung HCL552W projection that wont turn on.
I have the same tv.. Does the power light even try to come on? or do you hear clicking sounds? let me know maybe i can help u out
Apr 26, 2009 | Samsung HCL552W 55" Rear Projection...
I have a Samsung HCN5529W projection tv. The
yeah plenty, on older rear projection t.v.'s the circuit boards tend to over heat as they get older. keep the t.v. off and unplugged. contact a local repair shop.
Feb 20, 2009 | Samsung HCN5529W 55" Rear Projection...
Samsung
have the power supply checked
Jun 16, 2008 | Samsung HCN4727W 47" Rear Projection...
Samsung HCM553W 55 in. Rear Projection Television - image duplicated
Hello, I am a Samsung TV repair man. What happened was one of your bulbs in your tv has burnt out. you have to contact your samsung repair phone line. how old is that tv? do you have a warranty? if you do, it might be repairable for free. I hope this info is useful!
Apr 20, 2008 | Samsung HCM553W 55" Rear Projection...
TV won't turn on.
Samsung Projection TV Model # is PCK5315R. It displays a light on the "timer" indicator on front of the TV but the TV doesn't respond, no picture or sound.
Mar 02, 2008 | RCA HD52W56 52" Rear Projection HDTV
Samsung HCN5529W 55" Rear Projection Television Logo
306 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
