Question about NEC PlasmaSync PX-61XM1A 61 in. Television
Not switching on
Led blinnking red and green but i cannot swith on the tv. i tried to reset the power but still same.So pls give me a solution for this
  • Tim Isaac Jan 09, 2008
    turns on have green which becomes red and blinking but never a picture. I did notice a whitish light upon turning on followed by a click and no more light nor picture not even the input display indicator
My NEC PlasmaSync did the same thing.  It's caused by not using a power filter on your AC input.  To reset your TV, turn off the power button on the bottom until no lights are flashing.  Then hold down the "Input Select" button while holding down the "power" button.  The tv should then reset.
Posted on Jan 26, 2008
Epson R230 with green led and red led blinking
This is general error of the printer. When you have to change the new mother board you should be initialized it then it can be ready mode. When you try to initialization you need printer printer adjustment program. You can batter find out from google & write down EPSON Stylus R230 Printer Adjustment program or ink reseat program.
Jun 12, 2013 | Epson STYLUS R230 InkJet Photo Printer
I have a D-link DSL-2750U router worked fine till yesterday, but now its power led keeps on giving a red light it should give green a second or two later but it keeps givings
Reset router. There are two resets. A simple push reboots and holding it in clears all custom settings. Try the first.
This is a quick fix and usually does it. Test with network cable and work your way backwards to modem if you still have problems.
Nov 11, 2012 | Computers & Internet
Sony 50" new bulb but powers off after 1 minute?
if you was sure about lamp defective the you replace the lamp if was giving the same problem before .if not check lamp switch in side close to of the swith may be not making contact
Mar 01, 2012 | Sony KDF-E50A12U 50" LCD HDTV
Sansui sy 20 eye tv- when power on/off only red led works, green led not working
Please give me sansui sy 20 eye service menu code...pls urgent
Jan 24, 2011 | Televison & Video
My TV is TH-P42C10M - When you switch on . Power LED keeps blining RED. No Picture No sound Pls Help Call me on 94488 30230 or mail me at Pls help
Tries tv unplug,replug it back like about an hour later.Now the tv is resetting itself back to the factory setting.The tv should work now.If still have the same problems,than it is the power supply board is the causes and the problems.Try to buy a whole refurbish power supply board for the replacement.That the board,where the power a/c cord plug into it.
Dec 02, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Sony KD-28DL11U switched off by itself (went for red light). when I try to switch it on again the control light is green but there is no picture nor sound. any idea what could have failed?
pls. cheks your tv main supplay pin is proper canacted.
IF ok .
then problum is inside of the tv set.
check EHT out put voltage pin Diode /ragistance/ capeceter is filed.
any out put voltage from EHT is Droping. then TV is swithed off by itself
Oct 19, 2009 | Sony Televison & Video
Hi there
The front panel connectors are mainly,
  • harddisk activity connector
  • power switch connector
  • reset switch connector
  • power LED connector
  • speakers connector
  • USB connector
Harddisk activity connector
This normally comes red in colour and is labeled as HDD-LED
Power switch connector
This comes green in colour and is labeled as POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled as RST-SW
Power LED connector
This is usually green in colour and is labled as PWR-LED
Speakers connector
This speaker will give different beep sounds during boot to tell the user if there is any errors. It occupies 4 pins, however only 2 is important for the function. Be sure to connect the red coloured cable to the positive polarity and the black to the negative.
front_panel_connectors.jpg Front panel connectors pins on the motherboard
front_panel.jpg Front panel connectors from the casing
Good luck and thanks for using FixYa!!
May 13, 2009 | eMachines T6420 PC Desktop
MSI MS6511 jumpers overview?
Dear User here is confiruration.
1.Orange with + sign and orange is for HDD LED.
2. Green with +Sign and Green is for Power LED.
3.Red is for Power switch.
4. Blue of Black is for Reset switch
Mar 29, 2009 | Computers & Internet
Open Questions:
NEC PlasmaSync PX-61XM1A 61 in. Television Logo
435 people viewed this question
Top NEC Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
