Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Hardware Malfunction Error
I purchased a 500gb My Book in July which has been running fine for two months. However yesterday an error message appeared stating that "USB Device Not Recognized" and that the device had malfunctioned. I have tried reconnecting to different USB ports and rebooting and re connecting with no luck. I have used approx 60gb of the 500gb memory, and had no warning of any impending problems.
    Brigadier General:
  • 6,966 Answers
Hi, This is a common problem with external storage. Please refer to http://www.fixya.com/support/t191153-device_recognized Below is a copy of my response to a similar post. Based on your post/description: 1. Your PC does not recognize the external hard drive via its USB connection - try on a different computer - if it is still a no go, then it's not a PC problem; 2. Try replacing the cable - again if a no go, so it's not an interface/cable problem; 3. That leaves you only with the My Book itself as the possible at fault. An external hardrive would consist of 2 main parts, the electronic board and the hard disk itself. The board seldom (if ever) fails. Its function is to provide conversion/interface from the SATA/IDE connectors of the HD to the out USB/Firewire. The HD more often than not fails. Most external storage uses a standard HD inside the enclosure. Your possible options aside from running manufacturer's diagnostic and/or third party recovery software are: a. Claim warranty/replacement; b. Replace the HD only; c. Physically remove the HD and connect it direct inside a desktop either as IDE or SATA; d. Seek services of professional data recovery firms (if data/files are mission critical); Hope this be of some help/idea. Post back should you need further information. Good luck and kind regards.
Posted on Sep 04, 2007
I am not very tech savvy. I purchased a new Mac Book pro and My Passport for Mac 500GB in JUly and have had no problems since my husband accidentally disconnected My Passport while it was in process of...
Use the disk utitlity to repair the disk, when your husband unplugged it while it was attempting a backup, it corrupted part of the disk the disk utility will fix it for you and correct the errors
Apr 02, 2011 | Western Digital Passport WDXML800UE...
Frequent hard disk failure
check your hard disk cable first and replace it.if this isn' stopin your problem then make a new bios flash. may be ypur bios is reporting your hdd wrong so make a new one. if even after this you can not stoping your problem bay another mb.
Apr 05, 2009 | Intel D945GNT Motherboard
500GB MY BOOK hard drive.how to clear "disk error" & use again?
when you reboot your computer, do not have the hard drive attached. As far as the error goes, im not to sure about that.
Jan 27, 2009 | Western Digital 500GB My Book World...
Nikon LS-2000 scanner gives error 0x04620000
Stepper Motor Failures
Within the first 6 months of purchase I had to return the scanner twice to replace the stepper motor. The symptoms of stepper motor failure are a loud grinding noise during scanning followed by the enlightening message:
"The scanner has reported a hardware error. The present function cannot be continued. Sense: 0x04620000"
service required to fix stepper motor
Jan 07, 2009 | Nikon LS 2000 Film Scanner
My drive won't start up
Don't use a power strip or surge protector.... try to connect the power supply adapter directly to a wall socket. Always safely remove hardware after use
Aug 14, 2008 | Western Digital My Book Essential Edition...
Hardware malfunction
From the error report, it sounds like you have a bad memory chip (RAM).
If it's under warranty, contact Dell for a replacement.
If it is out of warranty, go to a vendor that sells RAM and replace it (such as www.crucial.com)
Jul 28, 2008 | Computers & Internet
HARDWARE MALFUNCTION CALL YOUR HARDWARE VENDOR FOR SUPPORT NMI : PARITY CHECK / MEMORY PARITY ERROR THE SYSTEM HAS HALTED
Dec 07, 2007 | Dell Inspiron 6400 Notebook
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
528 people viewed this question
Top Western Digital Computers & Internet Experts
Alun Cox
Marvin
Marvin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
