Question about Siemens 24 in. SE26293 Free-Standing Dishwasher
Control Panel Gets Stuck!
The control panel on our dishwasher gets stuck with 1 minute remaining. The only way to clear it is to turn it off,then back on. Sadly this normal means it resets the time left anywhere up to 75 minutes! It may all be connected with a poorer wash and the contents not coming out clean or dry. Please help me save some money by having to call an engineer out!
  • Anonymous Dec 17, 2007
    siemens se24t250gb/17 control panel sticks on one minute,to clear i have to turn off machine which leaves contents soapy and wet.This is a problem with every program.
  • Anonymous Apr 21, 2008
SOURCE:
huuum
  • 750 Answers
SOURCE: main control panel
Hello Dennis,
Welcome
You said, You have no leds on the front of the panel. When i switch on the machine all i get in the screen is 188 a snow flake top right of this and an 's' shape top left. Cant reset it holding down the right buttons. Any ideas anyone, is it time to replace it. thanks Dennis
I need the model number and year!
Waiting your response!
Huuum
Posted on Oct 22, 2008
  • 3 Answers
SOURCE: Control Panel
See:
http://www.siemens-home.com/pdf/sl84a30xuc_manual.pdf
There is a pic with the buttons in there.
Posted on Dec 28, 2008
garing
  • 998 Answers
SOURCE: Our dishwasher was taking in
yes it's time to visit the dump
Posted on Aug 08, 2009
BIKER T
  • 909 Answers
SOURCE: poor washing quality and water left in the filters ets
My friend, that siemans is a night mare to open. Just done one recently. Anyway, looking at it simply, i would suggest you check the inlet water filter. if water is slow to come in it will cause this problem. Remoe the water pipe from the solonoid and look for sieve. clean it well retry.
Posted on Sep 21, 2009
Macmarkus
  • 2605 Answers
SOURCE: My dishwasher won't switch off
Welcome to FixYa.
Based on your description
I'd say the issue actually is with the control...unfortunately. This is commonly associated with a heating fault on Bosch built dishwashers ( various models including Bosch, Thermador, Siemens, Gaggenau, and Neff ).
Since the issue is likely within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
These are the steps you'll need to follow to resolve it or at least investigate.
If you feel capable of checking this on your own, there`s a way to visually inspect the control yourself...it really isn't very complicated.
It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board.
The culprit will 99% of the times be one of the pins from the heater relay,
**Flip this over and inspect the solder joints, it will be obvious when you see it.**
hence the unit sit`s and takes longer & longer to finish because it can`t heat to advance or unless the 2 buttons for "cancel" are pressed...this can also manifest as a long cycle time as I mentioned and eventually display's "1" on units with a display and usually very poor cleaning, no heating ( don't be fooled by the homes inlet hot water temperature ) as a result.
You can also run the unit through a regular or econo cycle ...any cycle with the exception of rinse & hold, and with the door panel removed place an ammeter on the gray/black wire it should draw 11 amps during the wash cycle...after it fills and the flow switch indicates it has adequate water to engage the heater.
i.e. ( this may differ from your specific model, but the same rules apply )
**My Opinion - if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...but it has to be done well...or it will not last.
Bosch recommend`s replacing the control and I don`t pretend to speak on their behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)
**Please disconnect the power or turn off the breaker before attempting any service to the dishwasher.**
If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau/Siemens, to service your machine.
Thank`s for visiting "FixYa" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness.
Good luck.
Regards,
Macmarkus :)
Posted on Feb 26, 2011
Kenmore ultra wash dishwasher gets stuck at 42 on the control panel
Be aware that all (well, almost all) dishwashers have a "thermal hold" period in their cycles. This is the point in the main wash cycle where the heater is turned on to heat the water to the optimum wash temperature (about 150 to 160 deg F), and during this time, the timer will stop advancing. Once the water has reached the desired temperature, the cycle will continue. IF it does not, then you have a water heating problem. This could be caused by a bad heating element, a bad controller, a bad thermostat or temperature sensor.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Mar 20, 2015 | Kenmore Dishwashers
How do i repair fisher paykel dd603 problem top drawer stuck on fast cycle, bottom drawe stuck on normal cycle
you will need to replace both draws control boards, with the dd603 control boards they have a small touch button panel on the top of the board which they didn't put a protective layer or plastic over and basically what happens is steam gets on the copper tracking and corrodes it hence the fact it doesn't work anymore, all new control boards even the replacement for yours comes with a plastic strip over the board. hope this helped
Oct 06, 2014 | Fisher and Paykel Dishwashers
Stuck in drain cycle
Hello Vicki. If the drain pump sounds like it is running and will not shut off, you are on "flood mode" There is standing water in the bas pan of the dishwasher. sometimes water can get down there due to an overfill, or not draining completely between cycles. You can either wait for 2 or 3 days and the water will evaporate and should run normally. You can remove the bottom access panels and either vacuum out of dry the water (REMOVE POWER FIRST !) . If it does not clear on its own or if removing the water manually does not work, then the float switch will need to be replaced that activates the flood mode. There is a small possibility you have a bad control .
Apr 09, 2014 | Viking DFUD142D Built-in Dishwasher
Dishwasher malfunction
follow this steps and fix it. God bless you
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. Check the tutorial and the video for checking this part.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace timer/electronic control board.
Jul 08, 2013 | Dishwashers
Our Kenmore dishwasher model number 665.13163K701 display is always showing the heater cycle indicator on. Tried some reset instructions I found online and turned off breaker for a few minutes and still...
please follow the next steps and fix it. God bless you
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. 87af5b68-272e-404a-951c-cd453d3cd7fe.jpg
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer/electronic control
Jul 06, 2013 | Dishwashers
Zanussi dishwasher ZSF6161 starts program then stops after 15 minutes
check this steps and fix it. God bless youFloat Switch
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer /electronic control.
Apr 02, 2013 | Zanussi Dishwashers
Dishwasher will not run through its cycle
Hi
If the cycle doesn't complete, check these:
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Please revert for further assistance and Do rate the solution as "FixYa" if found useful.
Thanks
Rylee
Mar 26, 2009 | Dishwashers
Whirlpool gold dishwasher gets stuck at 53 minutes left for an hour
Try "resetting" the control board by running the diagnostic cycle. The cycle completes in 15 minutes.
The details are in the service manual. The manual can be found hidden behind the tow plate (at the very bottom front of the washer).
The diagnostic cycle may tell you the problem. It also helps clear up some of the software gltiches.
It is easy to run the diagnostic cycle.
Just the buttons in the following sequence. The sequence should be complete within 6 sec.
heated dry -> Normal -> heated dry -> Normal
This will trigger diagnostic cycle of 19 intervals. Pay special attention to the intervals 18, 17, 9, 6, 4.
Interval 18 - displays your controller module number (should be letter 'd' followed by number 0 or 1 or 2 or something. Note that down for future reference.
Interval 17 displays 'software generation number' Note that down for future reference.
Then wait until you reach interval 9.  --- clean LED turns on - then an open or shorted thermister is detected.
-- Sanitized LED turns on - then the washer detected greater than 100 deg F temperature
Interval 7
-- Soaking/sensing LED should NOT come on (unless food soil is present).
Interval 4 -- Soaking/sensing LED should come on
Let the cycle complete and then try running the normal wash. Hopefully the possible glitches are cleared by now and you should have no problem.
If this doesn't work, time to call the expert tech.
Nov 08, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Asko D1706
I also had this problem. Support person couldn't tell me if the pump was supposed to run even when setting the control knob to 'off' (bar before (1)). After draining the pan, the control knob functioned normally. So apparently any power to the unit will run the pump when the overflow pan is filled, no matter the position of the knob.
Sep 10, 2008 | Asko D1706 Built-in Dishwasher
Alarm sounds as F7 appears when oven is about 90 minutes into self clean
you may need to replace the main control..
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Mar 11, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Siemens 24 in. SE26293 Free-Standing Dishwasher Logo
53 people viewed this question
Top Siemens Dishwashers Experts
luvduct-tape
Level 1 Expert
Mike
Paul Bade
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
