Question about Intel ICP3 Webcam
Recording how can i record wit my cam and also can i get sound wit this wit me regular speaker
  • 12,061 Answers
You need to get the Drivers & Software for your particular unit. .They should be available from the manufacturers website If your webcam has an inbuilt microphone, then yes you will be able to hear sound. You also need A/V software... a good program to start with & test is Amcap, DL here ---> amcap.en.softonic.com/ below is a "How To" link... cowboyfrank.net/webcams/HowTo.htm
Posted on Sep 04, 2007
I do not have no sound when I play a video back you can not hear. This is on my Nikon coolpix P520 camera
hi,
did you test your cam with previously recorded memory stick ?
if it gives sound, it means the speaker and audio sections are working well, if newly recorded scene not gives sound means, there may be problem with the microphone, change it.
Oct 22, 2015 | Nikon Cameras
How do i make the sound record when I'm using the movie section on my camera
please note that the C913 hasn't got any speakers. When you use the video record section of your camera, the cam record the sound but when you want to hear the sound you have to transfer the video to your pc. When you use the camera review mode you won't hear any sound because the camera has no speakers ;-)
Oct 09, 2009 | Kodak EasyShare C913 Digital Camera
Sound not recorded during movie making
Sony DSC-S700 can record voice in video clips but you can listen sound of clip by exporting it to computer and playback there.
Camera has no built-in speaker to playback sound.
Nov 05, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Skype
Audio Setup for Windows XP and Vista
1. Audio settings, in Windows and Skype
XP: Windows Control Panel / Sounds, Speech and Audio Devices / Sounds & Audio Devices
or Right-click speaker icon in system tray and select "Adjust Audio Properties"
Volume / Device Volume: Make sure “Mute” is NOT checked in this window.
Volume / Device Volume / Advanced: If there is no “Microphone” section in this window, go to Options / Properties and check “Microphone” in the “Playback” list. Then make sure “Mute” IS checked in this window
Audio / Sound Playback: Your on board sound/Sound Card
Audio / Sound Recording: Your on board sound/Sound Card
Audio / Sound Recording / Volume: Make sure "Microphone" is selected and the volume slider is at the center or higher
Audio / Sound Recording / Volume / Advanced: If “Microphone Boost” or “20db Boost” is present, select it
Vista: Windows Control Panel / Hardware and Sound / Sound / Manage Audio Devices
or Right-click speaker icon in system tray and select "Playback devices"
Playback: Your speakers or on board sound/Sound Card must appear in this list, and must show “Working”
Playback: Select your speakers or on board sound/Sound Card, then click “Set Default”
Playback / Properties / General: Device Usage: “Use this device (enable)”
Playback / Properties / Levels: “Mute” is not on, volume slider in the middle
Recording: Your Microphone or on board sound/Sound card must appear in this list, and must show “Working”
Recording: Select your Microphone or on board sound/Sound Card, then click “Set Default”
Recording / Properties / General: Device Usage: “Use this device (enable)”
Recording / Properties / Custom: If “Microphone Boost” is present, select it.
Recording / Properties / Levels: Microphone volume should be centre or higher
Recording / Properties / Levels: If there is a “Mute” button, it must not be on
Skype / Tools / Options / Audio Settings:
Microphone: Your headset/mic or USB device or Web cam mic, as you prefer
Speakers: Your headset, USB device or speakers, as you prefer
Ringing: VoIPVoice USB Phone or on board sound/Sound Card; also tick Ring PC speaker
Note: The audio devices you want to use MUST be present in these Skype device lists. If they are not, check the device connections and driver installations again.
2. Microphone and Speaker connections
Check if your mic (pink) and speaker (lime) jacks are in the proper sockets (it is easy to reverse them) and fully inserted (they sometimes stick only partially inserted)
If your microphone or headset has a “Mute” switch, make sure it is not on
If your speakers or headset has a volume control, make sure it is turned up
For test only you can use an earphone instead of microphone (really)! Just unplug the microphone, plug the earphone into the microphone jack, and talk into your earphones. (I know it sounds silly, but it might tell you if your microphone is defective)
A standard microphone plugged into Line In will NOT work.
3. Check audio in Windows.
XP: Start / All Programs / Accessories / Entertainment / Sound Recorder
Vista: Start [Orb] / All Programs / Accessories / Sound Recorder
Make a short recording with the microphone; you should see the level meters moving as you speak. On Windows XP, you can then play back what you recorded.
4. Once done, test with Skype Test Call (echo123).
Oct 19, 2008 | Computers & Internet
Sound problem
ok well u need to save the music first den export it n save it on to ur computer den open it wit ur windows media player or wich ever player u have
Aug 04, 2008 | M-Audio Producer USB Microphone with...
Can i hookup extrnal speakers to my hi-fi vcr-dvd recorder without a tuner or a reciver, my model # drc8335. Think you.
I do not think so because the first problem is that the VCR recorder uses RCA audio cables (the White and Red colored cables) but the speakers use regular speaker wire. You cant convert from RCA to regular speaker wire. Second problem is even if you find a way to convert the wires, the DVD recorder does not amplify the sound signal. In fact all DVD players and recorders including VCR combos do NOT amplify the audio signal so you will barely hear it. The receiver does two jobs. First it converts from RCA cable to speaker cable and Second it also amplifies the signal before it sends it out to a speaker. Thats why a receiver is important.
May 01, 2008 | Televison & Video
My mic doesnt work
to put that in cam microphone working, you need to see on audio settings properties and change the "recording device" to usb audio device, instaid of the soundcard as is. That means that the sound recording will be from the cam's microphone.
The steps are:
1- rigth mouse click on the speaker next to the clock OPEN VOLUME CONTROL
2- OPTIONS - PROPERTIES - RECORDING
3 - in MIXER/RECORDING DEVICE (where is your soundcard's name) change to USB AUDIO DEVICE and then OK
4- In the remaining volume control window, select MICROPHONE and then close all the volume control windows
5- you can test the mic settings in messenger (any version) because of volume and to a clearest voice sound in your pc.
ATTENTION: carefull with the distance between your cam and your sound speakers because of distorcing sound and feedback
Jan 23, 2008 | Logitech QuickCam Fusion Webcam
LOGTECH WEBCAM
Hi Melissa,
to put that in cam microphone working, as I have an equal trade mark cam, you need to see on audio settings properties and change the "recording device" to usb device, instaid of the soundcard as is. that means that the sound recording goes to the cam's microphone.
the steps are:
3 - in MIXER/RECORDING DEVICE (where is your soundcard's name) change to USB DEVICE and then OK
4- select MICROPHONE and the close the volume control windows
Best complements
Jan 19, 2008 | Acer Aspire 3610 Notebook
SPEAKERS TO DMR E55 DVD RECORDER
Using a receiver to operate speakers?...accordianman
Nov 08, 2007 | Panasonic DMR-E55 DVD Recorder
New Vivtar Vivicam 5100 (a few minor issues)
NO SOUND well when recording video it records sound, but this camera does not have a speaker, it cannot play sound back, when you transfer your videos to PC you will hear sound PC CAM You cud use the windows 98 mass storage device driver to make the webcam work, but the picture will be very dark, i suggest you look on ebay for the vivicam 5100 and ask one of the seller if they can sell u the CD, this is a very hard driver to find, ive had no luck either
Dec 29, 2006 | Vivitar ViviCam 5100 Digital Camera
Intel ICP3 Webcam Logo
140 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
