Question about WYSE Winterm 3235LE Network Terminal
I have a 3235le with wince 2.12. How can I upgrade the RDP client to 5.1 or 5.1+?
Hi! I have a Wyse Winterm 3235le with 32MB RAM, 16MB flash, and WinCE 2.12 installed. First I flashed the image using 441.22Wyse3235.exe downloaded from wyse.com, so the system should be simple and clean. Then, I want to upgrade the RDP client from 5.0 build 4 to 5.1 or 5.1+. I tried both Addon_RDP_B0017_B.exe and Addon_RDP_B0012.exe using ftp pull method, but it always said that the firmware is incompatible. Could anyone help me solving this problem? How about merging the addon images into the system image? Thanks for your help! (P.S. The download page for 3235le is at http://wyse.com/serviceandsupport/support/dlOraFW.asp?which=27&model=3235LE) tictic
  • Anonymous Mar 29, 2014
    "Flash memory corrupted : the terminals flash file system has been corrupted.normally this problem can be corrected by reloading the terminals firmware" what is the solution for this issue
I tried to do the same thing but ran into the same problem - I gave up. However, I have been successful in loading RDP 5.1 onto a Wyse 8235LE. Works great with full resolution RDP sessions!
Posted on Sep 10, 2007
Hangs splash screen
hanging on splash could mean failure in the ram, video card or CPU cache. Try new ram. Good luck.
Aug 04, 2014 | WYSE Winterm V90LE Thin Client - Thin...
USB port on Wyse VX0 is not enabled. How do I access control panel to manage settings?
You have to enable it in BIOS. Look up how to get to BIOS on your particular computer. (Make & model)
Oct 24, 2013 | WYSE Winterm V90LE Thin Client - Thin...
My wyse laptop turns on but my screen stays black
try undo things..if problem solved then,try use different cards
May 17, 2012 | WYSE Winterm V90LE Thin Client - Thin...
I have a wyse winterm v30 thin client. what steps will it take in order to reload the firmware?
you can download this pdf guide from
https://support.wyse.com/OA_HTML/cskmbasicsrch.jsp?jttst0=6_23871%2C23871%2C-1%2C0%2C&jtfm0=&etfm1=&jfn=ZG455B66622DEA31A7AE70467E3EBEC537FE9176B1484EFD6E483B952B0ED1CF6F10611204C7B33B20AA233809D7249C41FE&oas=etuN3Cl3pQgYaOxTZDlD7w..&categoryId=10820
this will show you the steps to do a USB firmware upgrade.
Mar 20, 2011 | WYSE Winterm V30 Thin Client - Thin Client...
Purchased used wt9235le and don't know logon id or password,how do i crack
Hi, if it is similar to the 3235LE you can reset them by holding down the "p" key whilst powering on the device.
Jan 20, 2010 | WYSE Winterm 3235LE (90202401R) PC Desktop
How can i reset S30 wyse box
Try a G-key reset.
Failing that use WSI and an S30 image from the wyse Website.
WDM also has the option to to re-image the client.
You may also be able to get into the control panel of the terminal, and download an FTP image and set the terminal to upgrade from the image when uploaded to your ftp site. From the control panel, you can initate the upgrade manually
Mar 24, 2009 | WYSE Winterm S30 Thin Client - Thin Client...
I have a WYSE 3235LE thin client in a Sears retail environment. I need to reset the bios. There is a way to flash it from another terminal but the bad box won't boot. It stops with keyboard/mouse error....
The best solution for resetting the bios is to do a hard restart. This requires you to get to the motherboard and take out the battery for about 15-30 seconds before replacing it. By doing so, the temporary memory in the BIOS is erased and you will have you factory settings.
Dec 01, 2008 | WYSE Winterm 3235LE (90202401R) PC Desktop
Getting connected
Build a Windows server with DHCP and DNS and install Terminal Services. Open config on the winterms and setup the RDP client. Follow the prompts, it's pretty straight forward.
Term Service requires license after 90 days AFAIK, so you better have a plan by then.
Thats the easiest way to setup and connect, it is a far from complete solution, though.
I would suggest you google upgrading the winterm firmware using FTP, the older firmware is poor and slow.
Otherwise, these are great little termianls that will last forever and work well.
Mar 17, 2008 | WYSE Winterm 3350SE Network Terminal
Unusual problem
Perhaps the systems have accumulated dust on the inside, and therefore the unit could be overheating.
Oct 16, 2007 | WYSE Winterm 3235LE Network Terminal
No display in monitor
This may be the problem with the WYSE driver. Ensure that correct driver is intalled and colour profile is compitable. Syncmaster is auto detected by window based OS.the message "Sync out of range" comes due to improper out put video signal.
Jul 24, 2007 | WYSE Winterm 3235LE Network Terminal
WYSE Winterm 3235LE Network Terminal Logo
642 people viewed this question
Top WYSE Computers & Internet Experts
Archie Ferrarini
Archie Ferrarini
Daniel
Daniel
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
