The turntable is probably frozen and needs to be serviced. The platter need to be removed and the old grease removed and new grease applied. The rubber idler wheel may also be hard and it should be soft, This wheel turns against the platter and is attached to the motor. All of this is located under the record platter after the rubber mat has bee removed.
SOURCE: Numark TTX1 Turntable Problem-Platter stops
This is a drive issue. Unfortunately the TTX direct drive system isn't the greatest. It's good, but it's no Technics 1200. The only way to 'fix' this issue is to have a professional look at main circuit board to see if there are any components which are burned, or damaged in any way.
Hope this helps some.
- OPTiC.
Digital Analog Therapy
www.djprolab.com
SOURCE: Numark ttx turntable
More than likely the drive IC (integrated circuit) has shorted, and needs to be replaced. Not an easy fix, and you'll have to take it to a service center for replacement.
This is a common problem on this turntable.
- OPTiC
Turntable Repair Expert
SOURCE: Dual 1228 turntable platter not spinning, the motor will not turn
This particular unit uses an idler wheel to drive the table. Remove the platter and check the rubber wheel. It may be dirty, or just dry and slick. This part may need to be replaced or treated.
Dan
SOURCE: JVC Turntable won't turn, motor works, can't remove platter
http://www.vinylengine.com/library/jvc/jl-a20.shtml
Looks like this is a belt drive model.
http://www.turntablebasics.com/belts/jvc.html
This site claims to provide installation instructions with belt purchase. Good Luck.
