Question about Seagate Barracuda 7200.10 500 GB SATA Hard Drive
Computer won't recognize my HDD in my external enclosure...
Hey everyone, just got a new Dynex USB 2.0 3.5" external enclosure and a 500 GB Seagate Barracuda 7200 RPM HDD and I set them both up, I've never had problems with an external HDD in the past but for some reason when I plus this one in the computer says that it's installing the standard drives and such to run it, then it says your hardware is setup or something like that. I go to "My Computer" and the HDD is no where in sight, and I have no clue how to fix this problem. It should be there right under My Computer right?
  • 2 more comments
  • Crono666 Sep 04, 2007
    Thanks Benimur I tried what you said but sadly nothing has changed, my computer has yet to recognize it. Any other advice?
    I did what you suggested I do but sadly it didn't work. Any other advice you can share with me?
  • Crono666 Sep 05, 2007
    Windows Vista Business, I also tried it on my friends computer which has Windows XP so I'm not sure what the problem is.
  • Crono666 Sep 06, 2007
    I don't know what you just said...but it's a laptop and I have no clue how I would hook it to my motherboard and if it won't just plug and play then the drive is bad and I'm sending it back at this point, thanks anyways.
    Brigadier General:
  • 6,966 Answers
Hi, Initially, allow Windows to install automatically drivers or needed configuration, then perhaps you need to reboot. Thereafter check if it can be seen in My Computer, otherwise, pls post back for any messages or errors. Good luck and kind regards.
Posted on Sep 04, 2007
  • 1 more comment
  • Louie  Role
    Louie Role Sep 04, 2007
    Understand, then will have to treat this problem as a repair problem and not an installation.
    Please refer to the steps I have posted in a similar problem >http://www.fixya.com/support/t191153-dev...
    Or perhaps since no data has been stored, claim warranty and have the unit replaced.
  • Louie  Role
    Pls, what OS are you running?
  • Louie  Role
    Louie Role Sep 05, 2007
    Could be a bad drive, try directly connecting to your motherboard either as IDE or SATA. Your motherboard so autodetect if not then you just have verified, if otherwise detected proceed and partition/format. This essentially would bypass the Dynex USB 2.0 3.5" external enclosure and its interface/cables.
    If the 500 GB Seagate Barracuda was detected by the motherboard at BIOS, then Windows should be able to detect it normally. If not accessible to Windows but detected by the motherboard, use a third party disk utility like Partition magic.
SOURCE:
Internal hdd made external
just buy an external enclosure with the correct output wires, most come with usb
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
May 11, 2012 | Seagate U6 (ST320410A) 20 GB Hard Drive
I have a dynex 2.0 usb external hard drive with files already loaded onto it. One day my computer just stopped recognizing it and since then I have not been able to get this, or any other computer, to...
Sounds like a dead drive.
Have you tried putting it into an external enclosure and seeing if it can be identified?
Does it spin up?
Do you hear and sounds coming from the drive? (clicking is bad)
Let me know and I will see what else I can do!
If my answered help give me four thumbs as thanks!!
Aug 30, 2011 | Seagate Barracuda 7200.10 500 GB SATA Hard...
My hdd 250 gb show error
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge guarantee".
Nov 13, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
My seagate external hdd 500gb is not working and is not detected and regonised in any pc..
* the USB cable
* the power-adapter
Nov 07, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate 120 gig HD in Dynex enclosure not recognized by XP system
Ok, you didn't say if the drive had data or not? Anyway, if it is a drive with no data etc, you will first need to Initialize, & Format the drive before use. Is there any way you can connect it up to an "Internal" or "External" SATA port, & "See" if the drive is recognized, then at least you know the drive is OK.. Also try another USB port if available. If you know it is OK, then go to device manager and Uninstall the entire USB layer, reboot, it will re-install the USB again, with default settings, it NOW may be "Seen".
Feb 22, 2010 | Dynex USB 2.0 Hard Drive Enclosure Kit...
How can i make my seagate hard disk an usb hard
It is quite easy, do not worry.
You only need to bought and USB enclosure, here is a link to many products on ebay
http://search.ebay.com/search/search.dll?from=R40&_trksid=p0.m37.l1313&satitle=hard+drive+enclosure+usb&category0=
then you have to connect your hard drive inside the enclosure and the enclosure to your computer using the usb cable and that's it.
Just be carefull about the enclosure, I guess it is a Hard drive from a desktop, is in it? because some enclosure are for laptop's hard drive.
Also you need to know if your hard drive is SATA or IDE, IDE is the normal gray bus cable with fourty some pins, and the SATA it is a really small cable (I do not use technicims to not confuse you even more).
Also, there are some adapters from IDE/SATA to USB that you can buy in your local computer store (do not go to bestbuy, compusa, ... they only sell external hd), or also get it from ebay.
The only diference between the enclosure and the adapter is that the enclosure looks better :D, and the adapter is just a bunch of cables.
Mar 19, 2009 | Seagate Barracuda 7200.10 320 GB SATA Hard...
3.5" Dynex USB 2.0 External Enclosure + Seagate Barracuda 7200 RPM 500 GB HDD problem with computer recognizing the HDD and the enclosure
 If your running XP , go to control panal , Admin tools>Computer Management >Storage > Disk Management . Look for it there . If its there see if it says what file system . If none format it . If it isnt there then chack the jumper on the hard drive it self . It should be set to master or cable select .
Sep 03, 2007 | Seagate USB 2.0 External Enclosure + 400GB...
Open Questions:
bricked hard drive? Would folling this lead to a full hard drive format or just unbricking a drive like people sat it does?? Also any other ways that might help would be great to know, heres what i'm talking about! "Fixing The Drive NOTE: Commands for you to type are in red boldface. Pay attention to upper & lower case - it is important. Turn on power to the RS232-to-TTL adapter and the hard drive. After a few seconds, Press CTRL+z. You should then see a prompt like this: F3 T> If not, swap TX & RX wires. Access Level 2 (type /2): F3 T>/2 (enter) F3 2> Then spin down the (disconnected) motor: F3 2>Z (enter) Spin Down Complete Elapsed Time 0.147 msecs F3 2> Very carefully, remove the cardstock that you placed between the PCB and the drive head contacts. Carefully replace and tighten the 3 loose screws. I suggest using a small piece of masking tape to help you hold the screws while you put them back in place. Then start the motor: F3 2>U (enter) Spin Up Complete Elapsed Time 7.093 secs F3 2> Next go to Level 1 (type /1): F3 2>/1 (enter) And do a S.M.A.R.T. erase (create S.M.A.R.T. sector): F3 1>N1 (enter) Cycle power to the drive, then do partition regeneration: F3 T>m0,2,2,0,0,0,0,22 (enter) After 15-30 seconds, you should see something like: Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 14, Max Certify Rewrite Retries = 00C8 User Partition Format 10% complete, Zone 00, Pass 00, LBA 00004339, ErrCode 00000080, Elapsed Time 0 mins 05 secs User Partition Format Successful - Elapsed Time 0 mins 05 secs Do not turn off drive until you see this message. Once seen, drive can be turned off. Power down everything, place drive back into your computer, and confirm that it's working." Thanks.
Apr 12, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate Barracuda 7200.10 500 GB SATA Hard Drive Logo
518 people viewed this question
Top Seagate Computers & Internet Experts
Ekse
Alun Cox
Argospete
Argospete
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
