Question about Mintek MDP-1815 Portable DVD Player
Screen is always dim
Whenever I insert a disk into the DVD player the screen goes dim even though the DVD is still playing. This dim screen is supposed to appear when the screen is closed against the base of the DVD player. For the first second the screen is normal but after that first split second it reverts back to the dim power saving screen. It should only do this when the white peg under the screen is pressed down but it does it whent he peg goes down and when it is up.???
  • Soonerou Mar 14, 2008
    I have the very same problem with the screen going black after the first second its opened. Also some squeeking as the disk turns and sound is very faint. Tried everything, brightness, recharge, discharge, change disc, etc.
  • Anonymous Jul 04, 2008
    I have the exact same "Screen Always Dim" problem. We only used the dvd player a few times since it was purchased. It was sitting on the shelf for about a year before I discovered the problem. Would love to know if it can be fixed.
silly girl
  • 513 Answers
SOURCE: Dim screen
This could either be an inverter issue, or a backlight issue. Lamp replacement varies from very easy, seconds, to impossible without returning the entire panel to a service depot. There are some other possibilities (cables, motherboard problems controlling the backlight) but they are RARE. Inverters are relatively cheap (they are not "cheap", but they are still 80% less than a new LCD panel and 75% less than replacement backlight IF you could get it replaced). A new inverter is likely to be in the $50-$75 range. Any difference when working with batteries as opposed to AC? If so then it could be related to a power saving setting. But if your screen is completely dark, only visible with a light flashed at the screen, then that's not it. Good luck post a comment for the result
Posted on May 08, 2006
  • 1153 Answers
SOURCE: DVD player isn't showing anything
do you hear movement inside like disc rotating, if so then the switch that closest lid is damaged. This is when you fold dvd down it hits this switch to turn monitor off. It could be damaged. If there is no noise or movement then power supply has damaged or batt dead and no power goes to it from power cord.
Posted on Aug 22, 2007
SOURCE: Will not play any DVD
Turn off and disconnect power from unit. Check laser shuttle worm gear, look for dirt or hair (as I found). Remove with tweezers carefully. Check lubrication of worm gear shaft. If gone or worn, use white lithium grease to lube (very little). Play music CD 2 - 3 x. Than DVD. Worked for me.
Posted on Jun 04, 2008
SOURCE: MINTEK DVD PLAYER MDP 1815 NOT PLAYING
Mine is doing the same thing. I turn it on, it lights up, it says open, but it won't play dvds or cds. Its not spinning and theres no sound. It used to be a good little player. Is it fixable for a reasonable price or is it shot? Thanks for your help, Jim
Posted on Jul 10, 2008
toy_ladi
  • 484 Answers
SOURCE: problem with reading disk
hello,
the reason your player will not play any disc is because there is a problem with the lens.
it is either weak or dirty.
try to use a lens cleaner, if it is dirty, after using a lens cleaner,it will work perfectly.
if it does not work after using the lens cleaner, then you try to replace the lens completely.
it will work work perfectly again.
take care
Posted on Jun 08, 2010
When i plug my AV coil in my philips TV the screen goes dark
If the DVD player is playing and you have the Scart lead plugged in, check what the playback system is, Your TV is probably Composite Video and the DVD player may be set to RGB for example.
Mar 14, 2014 | Televison & Video
Car dvd player cannot play disk
See if unit has a reset to factory defaults. Also check with Kenwood. If not results are achieved unit needs replacement
Crutchfield Car Stereo Speakers Home Theater Pro Audio 4k TV
Sep 21, 2017 | Kenwood Car Audio & Video
Disk rotating and a message "invalid disk"
you can try manually cleaning the laser lens ( gently wipe , do not press down hard , it is suspended by fine wires ) using a q-tip and a drop of that cleaning solution you got with the laser lens disc. ( fluff another q-tip a little ) then dry wipe it with another q-tip and try a disc.
you can look at the laser lens and see if you see the laser come on also to determine if that is working ( do not look directly into the laser ! )
if the laser works but it still does not read discs after cleaning it manually , then there is a problem with the focus coil on the laser or the signal board is bad
Jan 10, 2009 | Coby DVD-211
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
If the unit is showing "invalid disk" on every disk that you try to play, unfortunately, the unit has developed a defect and needs to be replaced. Our warranty is 90 days from the date of purchase. If you've had the player longer than 90 days, I regret to inform you it is out of warranty.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Jan 02, 2009 | Coby DVD-209
May samsung dvd player does not play any disk i always seen
Try with other disk . May be that particular disk is damaged .
If your problem still exists you need to clean the lens with lens cleaner kit .
Hope this helps.
Dec 03, 2008 | Akai DVDP5851 DVD Player
Black screen instead of DVD playback
try changing the dvd drive speed in the system configuration, it may be at standard, change it to fast
Jun 25, 2008 | Sony PlayStation 2 (PS2) Console
My Insignia 8" Portable dvd player does not detect dvd!
Try playing a regular CD first and take it out if it played. Then put the DVD and it will play fine because the player just realign its lense. Hope it will help
Jun 17, 2007 | Insignia PD10135 Portable DVD Player
Trouble with my cyberhome ch-dvd 300
I have the same model player it pauses some of the times on some disks in some locations, I read at videohelp.com a resolution for this for skip frames for those who use PAL and mine skip frames after pausing though I have not tried PAL perhaps this remote code solution might fix this or some have had firmware updates though I could not find any firmware updates as any solution by CyberHome being this happens only happens some of the time it might not be possible to resolve this and taking it to a repair shop likely would not be worth it I am unsure if some software versions helps this Please let me know what you find out, okay? Email does not always go through, hence if you do not get a reply in 24 hours after you email me please try to contact me else how, okay? What is your name address and telephone number?Simncerely, Steven Bolin (206)937-2467 2851 SW. Yancy St. Seattle, WA 98126-2543 (206)937-2467 videoperson@gmail.com
Mar 28, 2007 | Cyberhome CH-DVD 300 DVD Player
Mintek MDP-1815 Portable DVD Player Logo
60 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
