Question about Thetford Norcold RV Cooler/Freezer
Norcold 682 rv refrigerator does not auto change to electric mode
Last year there were no problems auto changing to electric mode. today I notice it will not change over to electric mode automatically or otherwise after several attempts keepsgoing back to check light warning. I am not new to rv repair problems as I do repairs, trouble shooting myself. Any help would be appreciated, also how can I acquire an electrical diagram on the above 682 norcold rv rerigerator. thanks in advance.
  • webmaster386 May 02, 2009
    I have a schematic for it. I have replaced the eyebrow board and the 2 way power supply. I have 110v at the recepticle in the service compartment. I also tested the other end of the 100v wire where it plugs onto the power supply. I have 110v there too. email me @ webmaster at armedflorida dot com
    I will send you over a scan of the schematic. Maybe we can help each other.
  • David Spradling
    David Spradling Dec 16, 2017
    see if fuse ok on board check heater element
    Top Expert:
  • Thetford Master
  • 9,786 Answers
Check heater element also
Posted on Jan 25, 2018
  • 51 Answers
SOURCE: norcold rv refrigerator freezer
Make sure the thermister is attached firmly to the fins in the back. The boards on a Norcold can be reset a service center familiar with this process is your best bet. It takes disconecting the board and then shorting it out best to leave it to some one who is familiar.
Posted on Sep 08, 2008
  • 15 Answers
SOURCE: my norcold frig(RV) freezes food in lower level
in your refridgerator there is an internal thermostat on the cooling fan u can move up or down it should be placed on the last finn to the right looking at the fridge
thanks
cruz
cruz's mobile rv repair
Posted on Jun 17, 2009
  • 62 Answers
SOURCE: i have a norcold refrigerator in my rv. it works
Check if you are getting voltage to the heating element should be 120 volts
Posted on Jul 22, 2009
bad smell in my norcold ref ,,
Posted on Aug 04, 2009
  • 159 Answers
SOURCE: rv fridge not working on electric
the element can be broken or the thermostat
Posted on Aug 13, 2009
Won't operate in gas mode. Get code with a "wrench 3."
time to get the service person back under warranty
don't try repairs yourself as that voids the warranty
because you had to replace the regulator so early after purchase , it suggests problem in the gas lines(dirt or filings) that have blocked up the gas jets . problems on the other circuits could be again installation faults
I'm sure that you will make your dissatisfaction known to the company
May 05, 2016 | Thetford Norcold 3-way RV Refrigerator...
I have a Winni Minni with Norcold refrigerator 682. I have change board and element,but its not working on electric only on gas, prpblems ?? I live in Norway.
Sounds like your selector knob may net be making proper contact with electricity. You have changed everything else. You could check power available with a multimeter to your element. If power not available to your element, back trace to source and check for burned wires or breaks in wiring.
Hope this helps!
Apr 18, 2016 | Refrigerators
Norcold 682 rv fridge on gas lights for 5 seconds then shuts off panel has red x
check for weak pilot check tube to ignitor if ok possible flame sensor dirty or bad
Sep 05, 2014 | Thetford Norcold RV Cooler/Freezer
Norcold model 1200LRIM. Unable to select AC or LP mode. Auto is only option. Fridge frequently quits in Auto mode. No error codes. Display just goes blank. Battery connections are good; voltage is good....
Try to unplug it from the battery a few hours and then plug it back in and see if you are now able to select the AC or LP mode. There has been a recall on the 1200LRIM, The defect is a potential cooling unit leak caused during AC electric mode operation. Click on the link below to read more:
http://www.texastriallawyer.com/norcold/index.html
Nov 21, 2010 | Thetford Norcold RV Cooler/Freezer
Were are the fuses located on a norcold 682 unit
They are located on the circuit board on the back side of the unit under the black plastic cover.
Jun 30, 2010 | Thetford Norcold RV Cooler/Freezer
Norcold 682 is 0 in freezer and 50 in fridge cranked all the way up over 48 hrs now where do i look now
How about checking the R12 charge? Or you can run the fridge on propane and see if it gets colder. Which might mean your compressor is going bad.
Apr 15, 2010 | Thetford Norcold RV Cooler/Freezer
Norcold Model 682 problem
no these units run on 12 volt aswell check your fuses or and be sure u are getting atleast 10.5 volts to that fuse
Sep 27, 2009 | Thetford Norcold RV Cooler/Freezer
RV freezer cools, but fridge section doesn't
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 09, 2009 | Thetford Norcold RV Cooler/Freezer
My norcold frig(RV) freezes food in lower level
thanks
cruz
Dec 16, 2008 | Thetford Norcold RV Cooler/Freezer
Thetford Norcold RV Cooler/Freezer Logo
662 people viewed this question
Top Thetford Refrigerators Experts
Steve Allison
Steve Allison
John Tripp
John Tripp
tom wright
tom wright
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
